Cities: Skylines
I can't use edge scrolling since then it just goes onto my other monitor :(
Am I missing some obvious option in the settings menu or do I have to use Primary Lock for this? Disappointing if so.
just bought on Kinguin, just awaiting the order to go through now to get my key. Hopefully it doesn't take to long, they're normally really good.
ninja edit : got the key, now downloading :)
Yeah, theres a very small area where the scrolling happens without pushing against the edge and ending up on the other monitor, but at the same time, just coming on here to reply i moved my mouse over to the right screen and causes my CSL screen to scroll away on its own.
I tried Primary Lock, its horrible. We need something like Borderless Gaming, where it knows what apps to apply the attribute too, so if CSL is the active window, lock the mouse to it. If you tab out, then its not locked to anything (until you tab to something you've told it to be locked within).
I'll stick with WASD for movement primarily.
Yea I'm using WASD too since those small areas only work if you don't go too far. Hopefully they will fix it in the near future.
Primary lock is indeed horrible. I got it for some game I can't remember ages ago because it was the only thing that worked.
I have been testing this so far, figuring things out, and it is absolutely wonderful.
Fantastic game.
I decided to just go for it, so waiting for it to download :)
Also looks like they really are allowing modders to go to town on this game which is nice.
Damn, traffic problems delaying my journey home. I'll try to design my roads to be better then those in Bristol, shouldn't be hard!!!
