nVidia announce the Titan X at GDC 2015
Problem Exists Between Keyboard And Chair.
He already knew that, and if he didn't - two seconds of google would have shown that. He's using it as a means to feel offended, if you play the victim you're more likely to be listened to ;)
Remember, he's writing a formal complaint :D
He's pulling your leg :)
i'm not.
I only come on these forums to stalk (list getting huge now....) Humbug, ALX, Shanks and now Mal :rolleyes::rolleyes:
Everyone i quote, it somehow means i'm stalking them...like their posts are hidden and i actively need to search for them to respond, not like its a public forum.
Can't believe all the talk of backplates... Nvidia spent a lot of money designing it, if it needed one it would have it, also they may have left it off for a good reason, backplates don't always help.
Word. The Nvidia engineers (should) know what they're doing.
For that kind of money they could easily have included a backplate. They obviously think its better without.
They may have forgot to notify the relevant department that it should have. Back plate :eek:
Worst thing on the 980 is the backplate, it makes the card run hotter and looks rubbish too.
With the Titan having a higher TDP the heat problem would only get worse if a backplate was included.
i've just reported you for intimidation and stalking.
no, it's only you that continually attacks others and you've just listed their names .... well done that's very clever of you. :rolleyes:
i'm not.
i think you're forgetting that you got me suspended on purpose and you laughed at me whilst doing it, but what you havent realised is, the proof is here on the treads that you do this to others as well.
I remember that, LOL!
Well worth the deliberate quote. I didn't RTM though, remember that ;)
You forgot the sarcasm smilies, that quote is now out of context.
i'm not.
@Mal X
The best way to deal with posts you don't like is to ignore them.
In the next few weeks I expect to be the target of quite a lot of offensive posts and trolling on several different forums, I don't give a ^%&$ and will just laugh at them. The more abuse I get the better, I like a good laugh.:D:)
The backplate dissipates heat away from components on the PCB, it's not just there for ***** and giggles.
That's why NVidia have made it easy to remove a bit of it to improve cooling lol.:p
The GTX 980 backplate is very cheap and nasty compared to the ones EK make for example.:)
As far as I'm aware , backplates in SLI ( at least in some cases ) is detrimental to cooling ... And with a 12gb vram buffer I can only imagine people will be buying it in pairs more so than on their own .
@Mal X
Why?
