- 17 Sep 2012
- Derby
Oh yes looking rather dandy my friend![]()
Thanks John!!
Damn, that looks good.
Wanted to do white and purple to replace my white and red theme.
But after looking at this, mine won't have anything on it!
aaah, im sure you can do far better buddy! If i can do it anyone can!!
Right, so some progress!!!
A huge thanks again to BitFenix! I forgot to grab some fans and LEDS when i grabbed my bits from them last time, so I rang OcUK yesterday and they sent them out for me, BitFenix picked up the bill <3!
So, the fans:
I have never used these on radiators so it will be interesting to see how they do. This build really will be a challenge to cool, the loop layout isnt the best, but with such a small case i have to make some little sacrifices.
I also picked up a 60cm white Alchemy LED strip
with the fans fitted, I could finally see where im going to place the radiators!
The 240mm one will be going at the front, the fans fit perfectly fine, however the radiator doesn't. Im going to have to make a bracket or find another way to attach it as due to me flipping the motherboard tray, the radiator now wont sit flush with the fan holes. Its annoying, but hey, this is modding!
I needed the top rad to go here, unfortunatly this area is reserved for SSDs... Not any more!!
I drilled holes where the red circles are, i also cut away where the red crosshash is so that the PSU will fit in a little better...
Now the fan can sit inbetween the top cover and the chassis.
and the radiator sits pretty underneath
I have also sorted out the placement of the GPU!!!!!!!! WOOOOOOOOOOOOHOOOOOOO!!!!
i fitted the CPU block, and started to add some tubing, its started to finally come together!
The rez is attached directly to the radiator with 2 90 degree fittings and a male to male fitting.
I need to change these fittings to some black chrome ones, but for now, i think im going to do a parallel loop, it looks so much cleaner in this case.
How the GPU will sit, ok, I do need to redo the bend from the block to the rez, tbh, i wasnt expecting to be able to even start doing the loop for a couple of weeks yet!!!!
Excuse the mess!, here you can see how close the 2 radiators are, and also how close the PSU is to everything.
The radiators, PSU, GPU and case will soon be white and Mayhems are busy making me some purple coolant ready to fill it up!
Its starting to get there now! Exciting!
