I don't play Arma3 much. But you should be able to alter the friendly & enemy skills in your game config (probably in your docs 'Arma 3'). It will have your user name on it. Make a copy first of the one there and put it in another folder (backup). Then alter the new copy renaming it to the original user name, then in properties mark it as 'Read Only' so the game doesn't overwrite it each time you exit. That way the settings should stick with your game.
Might have to keep going back to tweak, but its worth a try.
Better to try use an ai mod, many change the skill setting and you can tweak these via the userconfig in your game folder.
Just learned today something that will make many players happy that have wanted it for so long. There will be a KAI/lite version for arma 3 for sp/mp use. That is a real game changer, well the full version is, so I expect the lite version will change it considerably too. Not sure if it will be campaign friendly though.
I am also hooked but I'm hooked on watching the video's of people who can actually play this game properly where as I am truly special at this bugger and keep getting destroyed.
Best game involving guns ever...... I'm just no good at it though.
If you've played arma before then the learning curve shouldn't be *too* steep, but do be prepared to to give it a bit of time for all the quirks to sink in. Depends on the kinds of missions you fancy playing tbh.
Seeing as that extended edition gives you all the DLC for a fiver I'd say its well worth the extra.
You can go full arm chair general with trackir or you can just play something simple like king of the hill.
However don't expect a slick experience, it's buggy as hell.
Yeah see mission wise etc I have absolutely no idea. I take it there is a server browser and I just pick from there. And then mission instructions when it start ?
Im going to have to do some more research tonight and watch some streams..
Oh right ok. Hmmm I was hoping it would be a little more complete than that..
Would you be after Coop type of game (players vs AI) or more PvP orientated? Oh and it's really not as buggy as people make out![]()
Cobra-UK
Try AhoyWorld servers for Player vs AI.
DX12 coming to ArmA 3.
