Caporegime
- 30 Jul 2013
hardline much different from the beta?
Only played the campaign so far.
Looks really good at 4k though.
Hardline is good fun and is running very well on Mantle.![]()
Is it mine has constant micro stuttering on 290x, single player and BF4 MP fine with mantle, but BFH MP just stuttering using the same user.cfg and the overlay file i use for bf4![]()
Update punkbuster.
How you playing it already Matt, I can't seem to play it until Friday?
.How you playing it already Matt, I can't seem to play it until Friday?
He's Bil Gates illegitimate son and gets all the goodies early.
VPN gate, gives you a Korean IP. Once you've got into Battlelog disconnect the VPN and you can play normally.
Normally I'd just wait, but curiosity and Mantle got the better of me. The Frostbite engine runs so much better on Mantle than alternative solutions that i couldn't wait.
I'll take a leaf outta your book, cheers!
Update punkbuster.
ok ill give it a try thanks
Hi MAtt yeah thats what i do i cap 100 as i have 120hz monitor with a mixture of high settings in my user.cfg file. Just trie dthe Punkbuster update by manually updating game and pointing PB to the exe and trying the older beta driver but still constant microstutterIf that does not work, try a combination of Vsync and or an FPS cap. I found these can smooth things out if the game is not running well.
GameTime.MaxVariableFPS 60
Or whatever FPS cap you want. Place in a User.Cfg file or type into the console.
Like i say BFH Single is fine the yellow CPU line is flat and on BF4 MP but on BFH its just up and down.
THanks for the advice though![]()
Could be a server issue then maybe. What was the server size, as i noticed some weird lag on a 64 man server.
If AMD could upstage nVidia in this I'm sure you'd get legions of simmers swapping allegiance when they realise that AMD are supporting them properly! It's good business sense
