Sorry, this is just a frustrated rant, but, Well why??
VW are the worst.
IME Hex socketed fasteners only have a very limited ability to withstand torque. They strip out very easily.
They are only suitable for cosmetic applications. Not serious engineering.
Especially the smaller sized ones 5/6mm.
VW crank pulleys are a constant ballache. they always strip out (When you want to do the cam belts etc) and subsequently have to be drilled/chiselled. (Aggressive heat solutions are not always practical and don't always work anyway)
My latest grumble, trying to do a timing chain (How did manufacturers forget how to do timing chains properly anyway) on a VAG 1.2.
The timing cover is retained by a multitude of 5mm hex socketed fasteners.
Of course they have all been loctited too!
Most came undone (Though I had to use the oxy torch on 4 of them before they went)
But three will not go under any circumstances and will have to be drilled! (Including the really awkward one in a deep recess just above the crankshaft)
Probably half of the labour for this job is going to be down to undoing 3 sodding bolts!
Had VW used Torx headed fasteners this would be a non-problem!
(It also wouldn't be a problem if the fasteners were made of steel that was actually harder than cream cheese, but typically the steel used seems to be particularly low grade. (The tool should strip before the job IYSWIM))
Bah!
Rant Over!
VW are the worst.
Bah!
Rant Over!
