- 25 Nov 2011
- The KOP
Its because it was rubbish, that's why. They'd be in court if they tried to push a marketing angle on something that wasn't true as its essentially slander.
As for the BenQ monitors with their insane AMA ghosting and horrid presets, I'd avoid if I were you guys! Theres bound to be better monitors being released over the next few months so its just a matter of being patient for that one that suits your needs the most. Being a gsync user, I'm pigeonholed into Nvidia tech, which isn't a great position to be in if I'm honest. However, I can't game on my pc now without gsync enabled in pretty much any game as the image quality is genuinely terrible without it! I suspect you freesync guys are experiencing the same or very similar things when using the tech too!
This my 3rd BenQ display and can't fault them.. The only downside would be there choice of stock preset, but being a competitive gaming monitor you can understand why.
If you understand your way around display test patterns you can get some really decent image quality..
The ghosting am seeing on stock preset I also get on my other BenQ xl2420t but instead of lowing contrast switching off ama fixed that..
