Snappy Driver Installer (uses Driverpacks)
Don
21 Oct 2002
Parts Unknown
Normally, I will install drivers individually, but you get the odd one that can be hard to find.
This tool is awesome. It needs about 10GB of space to hold all the drivers, so it's worth keeping it on a large USB stick or external drive.
http://snappy-driver-installer.sourceforge.net/en/index.php
The tool itself is tiny.
Quite a few similar programs out there, but they usually try and bundle in extra things with them.
Great tool
And yes, the website is criminally poor :p
Been using it for months at work and it's freakin' epic! I have had one or two issues with it though to some extent but it could be the machine being picky. For example the HP DC7900 won't install the audio driver via SDI since it's not signed so I had to get it from the HP website (I think the DC7800 is the same too).
Other than though it's superb! As I understand it the guy who makes it was a developer of DriverPack Solutions and he went off and wrote his own app from scratch.
Stoner81.
Stoner81.
That was a great bit of software! if a little buggy and never quite comfortable with it changing windows logo and a few other bits unless you dug through the settings to tell it not to!
Will check out the OP, these tools are handy to have on the network drive!
Noob question alert: Would this be a suitable tool for using on laptops?
Especially useful on laptops, they tend to have more obscure hardware which this thing picks up..
Because of the shotgun blast approach, there is always a possibility of installing an incorrect driver, so bear that in mind.
I use it on a fresh install. I'd take a backup before running it on a working system.
I have found it to work very well on laptops but I mainly deal with HP and Dell machines at work. The main thing it doesn't find is the Hot Key Support software for some of the HP machines but that isn't really a driver per se.
Other than that though it is fantastic! Been a ton of updates since I started using it and it gets better and better.
Stoner81.
