**** The Official Note 4 thread ****
Not had a lot of time with it but everything looks a lot more coherent. Animations are slicker, everything is quicker. Keyboard looks better. Had some issues initially with the play store but a cache clear solved that.
Don't know if battery life will be any different yet but it certainly looks good and feels pretty slick :)
Not sure about the floating notifications though. Need to see if I can change that!
KK to LP for me has been quite a big difference for battery life, plus everything just seems a lot more responsive and slicker.
I am considering rooting and flashing a rom but I currently don't have any problems with how it's performing on stock surprisingly
Well what a deal on mobiles.co.uk Unlimited text,mins 5GB 4G Data £31.99
Hmmm it's OK I guess, total cost over 2 years is £722.76. Unlimited sim only deals run around £168 for those two years (or my Virgin Media one does anyway), making the effective handset cost £555, which ain't that great.
£168? £7/m for Unlimited text,mins 5GB 4G Data?
Got a link?
Do the tempered glass screen protectors affect s-pen use in any way?
If not, could someone please recommend one or perhaps a standard screen protector?
My Tech21 protector doesn't seem to affect s-pen use, but I haven't used it much so far.
Just got a galaxy note 4!
Managed to get on three for £36 a month, unlimited 4g, texts and 600 minutes.
Anyone recomend a decent lightweight case for the thing?
Cheers,
Grady
Ringke cases on rainforest fits very well and sturdy.
Dont think the tech 21 screen protector is tempered glass. I havent found any good fitted glass yet without halo effect.
Thanks you both :) I may get an el cheapo screen protector to start with to tide me over until i find something better. I'll be getting some sort of flip case most likely so probably not that critical it being glass.
Has anyone else been seeing really poor battery life? Thus is a lot worse than the M8... Average SoT is 3-4 hours... Generally 12 hours usage before I'm down to 20%
I had really bad battery life on mine. I had Vodafone firmware on it. When I flashed the stock BTU firmware my battery life improved by about 50%
Only had the Note 4 on KK a few days but whilst I was getting an actual full day of battery, the screen time wasn't the 5-7 hours I've seen reported by other users. Installed Lollipop today but that was at lunch time so I can guide properly tomorrow. I'm struggling to see how I'll get more than 4-5 hours.
