- 3 Jun 2014
Got my sli X's installed and case spring cleaned. Now ready to test some games at 4k
Can not get my gigabyte tx to boost past 1215ghz
Borderlands pre sequel on max settings brings it down to 29 fps in places, must be
the x5650 @4ghz bottlenecking![]()
It's a 5 year old Xeon so not surprising.
The boxes in their now empty glory.
My Titan X arrivedAt work currently, looking forward to playing tonight
Pairs Nvidia Titan X with age old Xeon CPU. Yup that makes perfect sense
Time to upgrade your Mobo and CPU buddy
The dips are probably due to the CPU bottleneck...
For the OC have you tried 110% power limit and using a custom profile so your card doesn't throttle?
Does PhysX use cpu or gpu power as the pre sequel is ok with PhysX on medium
How in the hell is that turd COD using 10 gigs of ram? That makes no sense at all.
