Windows 8.1 licence question
5 Nov 2011
Derbyshire
I'm building a pc for a friend who wants Windows 8.1 but also looking at buying a netbook for myself (installed with 8.1).
I'll be installing Ubuntu on the netbook so windows key will be surplus, can I move the key onto the new build pc to save buying a key?
***also can this be done with windows 7
Thanks
If you bought retail Windows 7, 8 or 8.1 then the license is transferable but if you bought OEM version then the license is non transferable.
That is not true for 8 and 8.1 since retail versions were scrapped, and purchased OEM versions can be moved to another computer as long as it's removed from the other computer.
It might be a different kettle of fish for pre-installed versions since the license key is coded in the BIOS and is probably not transferable to another computer.
As the licence and the operating system was pre-installed by the manufacturer you cant move the licence to a new machine, if you bought a Windows from Ocuk then you can move the licence to a new machine.
