Not happy with Nvidia`s hardware implementation 8 pack.![]()
Actually no. Very cheap components used on PCB. Every expense spared.
I have just had a quick go on the training ground with 2160p and 135% resolution scaling which is about the same pixels as three swifts. Everything maxed using about 11 million pixels I was averaging about 120 fps.
I tried playing a multiplayer game but kept getting kicked out, I don't think it liked the resolution I was using.
Thanks for trying it out for me.
Im getting three so I will see how many fps i get and make a decision.
Thanks for your help
hopefully i will be able to play online in surround
Question for you, there's this distinct smell coming from my case when I'm running a very high OC. Not burnt smell no smoke either (stock bios and temps are ok under 75c) can't exactly describe it. Is this a "burn in" heat smell or something to be worried about?
1453/7828 just for reference
Edit: It's that smell/feel when you enter a really hot ACed room![]()
Christ, you guys have loads of expendable income!
*sell kidney *buy titan* *sell kidney *buy titan.... find other sellable body parts *rinse-repeat
Cards on fire in 5....4.....3.....![]()
You will have 1 GPU per 1440p monitor, so it's relatively simple to calculate with a well optimized game.
Edit: You going for 4 ?
see how three goes.
I am concerned with heat / noise tbh my rig is in the dining room next to the lounge. Dont want to disturb the wife too much![]()
4 x TitanX @1400/2002
5960X @4.5
1440p
Still bottlenecked.![]()
Both my cards have been emitting that sort of smell you described. So it's not just you. Hopefully nothing to worry about, just fresh components bedding in.
Titan X - (1439/7856)
Dying Light
Bench Methodology : Using Be The Zombie mode start recording FPS from the tunnel and just run like there's no tomorrow for 60 seconds. (killed 2 people btw while I was at it)
2560x1600 (Everything Maxed And On - View Distance 100%)
Min: 74
Avg:97.28
Max: 145
DA: Inquisition
Bench Methodology : Running around in the Hinderlands
2560x1600 Ultra Preset
Avg FPS 57.6 (calculated from Frametimes)
Link to perfoverlay file here
Thanks so much for doing this, now to justify the cost to the wife!!
This is me now every time I launch a game that previously ran crap.
