Hey Kaap, have you tried benching 3x 4K monitors yet?
Silent_Scone should be able to help you out for 3 GPUs.
Backplates don't help much in terms of temps on these cards other than looks and avoiding damage from leaks.
I interchange GPUs frequently so water is not the best option for me sadly![]()
Well i think these cards will be in for a couple of years so I could water cool them. I am a plumber by trade but I dont like to mix business with pleasure lol.
I will check with silent scope on the parts when it comes to it.
Will run on air for a few weeks see how it goes.
One piece of advice, get quick disconnects.
Is anyone else Geforce Experience saying that both Shadowplay and LED Visualizer are "Not Ready!"?
Obviously my hardware is well above the requirements, so just wondering if it's something obvious I am missing or if it is simply because Titan X isn't fully supported by Geforce Experience yet?
This is my 24/7 on air
My 24/7 clocks are 1409/4010 on both cards. Not a single crash with those at all.
I just use the aggressive fan profile in Precision X. Gets up to around 70% with a 1400/2000 overclock, it's quite loud but not irritating for me.
I run a 1:1 fan profile on my SLI system and the noise is quite loud but not obtrusive![]()
Wow, 70% fan speed is too loud for my ears. Can I just check, when you say 1400/2000 what does that translate too?
- Is 1400 the permanent core boost speed? What value are you adding to the core for that (200?)
- 2000 for the memory? What does that equate to? I use afterburner and a GPU monitoring widget on a second screen whilst gaming. At the default clock speeds it is shown as 3500 for the memory.
