Anyone Using an Asus DSL-AC68U
21 Mar 2015
BT TV with DSL-AC68U?
My DSL-AC68U is running nicely with BT Infinity 2 and the YouView box - except that none of the extra/internet channels work (#406+). Freeview channels work perfectly.
BT say those channels will only work with the HH5 (which I think is funny, because my HH5 was useless in every way).
Anyone have experience of this?
R.
28 Mar 2015
Yeah. On mine when I forced fastpath for 24 hours I had no spikes whatsoever, virtually identical results to the HG612. I think ASUS may have resolved the problem. I'm back on DLM's settings for now which will test if FEC errors go abnormally high, so far it's remaining consistent and normal.
hi how did you force fastpath please
29 Sep 2014
A slight nervousness with the latest stats: The CRC down count was certainly ahead of 20 per hour when I had turned on G.Inp and G.Vector. However, it now stands at 75 an hour. It seems to be accelerating.
Code:
outDiscards=689
inDiscards=35
outBytes=2196747590
inBytes=3995367291
outPkts=4096387
inPkts=9454224
fwVer= FwVer:5.5.1.127_B_A60901 HwVer:T14.F7_0.1
lineState=up
Opmode=ITU G.993.2(VDSL2)
SNRMarginDown=5.8 dB
AttenDown=9.3 dB
SNRMarginUp=6.1 dB
AttenUp=0.1 dB
DataRateDown=71335 kbps
DataRateUp=20000 kbps
WanListMode=1
FECDown=7844
FECUp=461
CRCDown=827
CRCUp=79
HECDown=0
HECUp=0
ADSLUpTime=11:15, 50 secs
ADSLActiveTime=0 min, 19 secs
PowerDown=13.3 dbm
PowerUp=4.4 dbm
ATURID=26005443434e0000
ATUCID=b5004946544eb204
AttainUp=20630
AttainDown=85412
ShowtimeStart=19
TotalStart=39
ATURANSIRev=0
ATUCANSIRev=0
ATURANSIStd=0
ATUCANSIStd=0
InterleaveDepth=1
AdslStandard=VDSL2
AdslType=ANNEX_B
mtenStandard=G.dmt.bisplus (Annex L)
4 Jan 2015
Code:
outDiscards=689
inDiscards=35
outBytes=2196747590
inBytes=3995367291
outPkts=4096387
inPkts=9454224
lineState=up
AttenDown=9.3 dB
SNRMarginUp=6.1 dB
AttenUp=0.1 dB
WanListMode=1
FECDown=7844
FECUp=461
CRCDown=827
CRCUp=79
HECDown=0
HECUp=0
PowerDown=13.3 dbm
PowerUp=4.4 dbm
AttainUp=20630
AttainDown=85412
ShowtimeStart=19
TotalStart=39
ATURANSIRev=0
ATUCANSIRev=0
ATURANSIStd=0
ATUCANSIStd=0
InterleaveDepth=1
AdslStandard=VDSL2
AdslType=ANNEX_B
i think you need to start worrying when u hit about 2000 CRC in 24hours
8 Jul 2010
Not unless you lose connection. If you do not for a week or so you could probably drop the SNR Margin a bit to gain some more bandwidth.
over 2 days uptime
i have 25 crc down errors and 717 up errors
any idea how i can reduce these? or is it acceptable
19 Apr 2012
I've read of some people mentioning on other forums that you should avoid this unit on longer lines due to the mediatek chip set. Does this even apply to VDSL as I would have thought most long lines would be at least halved with sticking in a cab along the way. What would be deemed a long line anyway?
20 Oct 2014
I think that's a bit of old news, considering that the problems now appear to be resolved with ESNP. MediaTek has a reputation of being unstable on long lines but there's no sufficient proof yet to say that it's unstable on this particular chipset model (other than before ESNP was implemented).
19 Apr 2012
OK. Just thought I should find out if there was any truth in the information people were dishing out. So I gather Asus recommends the currently released firmware and if issues remain then use the beta that was issued with the ESNP?
20 Oct 2014
Yes. If you're experiencing stability problems or abnormal rises in the FEC errors then you should try the latest beta on this forum thread (ESNP) and set ESNP to stable on the DSL settings page. It's solved all my stability problems here, including the FEC error count which no longer rockets upwards :).
2 Jan 2015
over 2 days uptime
Thats more than acceptable that is in fact very good even the 717 up errors based on 2 days is less that 15 per hour average. Of course this is assuming the stats on this new firmware are accurate.
Id say that is pretty much hearsay rather than evidence. Also you can in theory be on a longer line with vdsl than you were on adsl.
Example you live really close to the exchange and the old adsl cabinet was almost outside your house but the new fibre cabinet is further up or down the road (say on the opposite side of the road or junction to the old cabinet). The copper loop involved could be longer (it would depend on the distance between old and new cabinet).
OR to visualise it easier...
old adsl setup...
telephone exchange -- adsl/old cabinet -- house
New vdsl setup...
telephone exchange +++ vdsl/new cabinet ----- house
Where "-" equals copper and "+" equals fibre and each "+" and each "-" equals 50 Metres of copper and fibre respectively.
In the above, with the old adsl set up you would technically have less copper in your line. (200 Metres) compared to the vdsl setup (250 Metres).
This would not be very common i grant but entirely possible. I can think of a road not that far from me near the exchange something very similar.
Can you when/if interleaving gets removed with this new firmware check to see how it performs on fastpath over a 72 hour period. Or force fastpath again after a few days if it does not put you back on it.
I have a theory on what they may had done to keep the errors down, im hoping im wrong, because if im right the errors are only going to remain low for around 24-48 hours before they rise again. (my theory... they have altered tone allocation/bit loading to favour a specific frequency range, again will mask issues until after 48 ish hours when it can no longer allocate properly, bit load to those frequencies in the manner they have altered).
Linksys done something similar with a device a few years back, ultimately they introduced a "v2" or "B" model in the end when savy users still moaned lol I hope im wrong though. This would also explain now why people are seeing higher CRC and FEC in general on the up rather than down stream, you can actually have higher up errors but not commonly.
This theory would explain things. For most people before it was higher FEC/CRC on the downstream (which despite the prior silly figures in the millions is typically the common scenario for FEC and CRC IE more on downstream) seems funny now its the up stream, i doubt that many lines have issues with WORSE/HIGHER upstream errors rather than downstream.... Im watching with interest. I hope Asus have not tried to be clever and failed! I (AGAIN) really hope im wrong cos im ready to pull the trigger and buy one again, but if they have pulled a bodge rather than real fix on it then ill be going Billion or TP-Link.
4 Jan 2015
will this explain anything? there something in here about changing tones.
Code:
1. Realtek RTL8139/810x Family Fast Ethernet NIC                                    (Microsoft's Packet Scheduler)
MAC address: 00-03-0d-55-a3-79
Search ADSL modem...
ADSL Router...
Connect to ADSL modem...
TC Console function ON..
tc>Program will take around >>>    20    <<< hours
/bin/sh: Syntax error: redirection unexpected
tc>[OVHD_DBG] Rx MGCNT_READ Req(rx_sf=104, rx_sb=256)
[OVHD_DBG] Tx MGCNT_READ_ACK(rx_sf=104, rx_sb=256)
[OVHD_DBG] Rx PMD_TEST_SINGLE_READ Req(rf=104, rb=256)
[OVHD_DBG] Tx PMD_TEST_SINGLE_READ_ACK(rf=104, rb=256)
admin
/bin/sh: admin: not found
tc>admin
tc>[OVHD_DBG] Tx MGCNT_READ Req...(tx_sf=176, tx_sb=224)
[OVHD_DBG] Rx MGCNT_READ_ACK(rx_sf=177, rx_sb=256)(tx_sf=177, tx_sb=223)
[OVHD_DBG] Tx PMD_TEST_PARAM_SINGLE_READ Req...(tx_sf=177, tx_sb=224)
[OVHD_DBG] === Rx PMD_TEST_SINGLE_READ_ACK(rf=178,rb=256)(tf=178,tb=223)
[OVHD_DBG] latn (LATN*10 dB) =>    1  167  268    0    0
[OVHD_DBG] satn (SATN*10 dB) =>    1  166  268    0    0
[OVHD_DBG] snrm (SNRM*10 dB) => 62 75 66 60 0 0
[OVHD_DBG] attndr(ATTNDR) = 22355250 (bps)
[OVHD_DBG] Near-end actatp = 125 (ACTATP*10 dBm)
[OVHD_DBG] Far-end actatp = 46 (ACTATP*10 dBm)
/bin/sh: Syntax error: newline unexpected
tc>[OVHD_DBG] Rx MGCNT_READ Req(rx_sf=182, rx_sb=256)
[OVHD_DBG] Tx MGCNT_READ_ACK(rx_sf=182, rx_sb=256)
[OVHD_DBG] Rx PMD_TEST_SINGLE_READ Req(rf=182, rb=256)
[OVHD_DBG] Tx PMD_TEST_SINGLE_READ_ACK(rf=182, rb=256)
Tx_CRC[0]  = 0
Tx_FEC[0]  = 152
Tx_ERR_SEC = 0
Tx_FEC_SEC = 22
Rx_CRC[0]  = 2
Rx_FEC[0]  = 32628
Rx_ERR_SEC = 1
Rx_FEC_SEC = 579
Near-end total: los=0, sef=0, lpr=0
Far-end  total: los=1, sef=1, lpr=0
VDSL2 Sync-Up Time:  0 Day(s)  6: 8:11
[Vcxo]=10754835
##TASK:Vdsl2LogShowTimeErrPwr done [5 symbols]
Pilot info:[146] SNRM=48.06,SNR=50.56,Bit= 0,ErrPwr=16,FFTout(222/-405)
SNRM:Ave= 5.61-> 5.8, Max[3200]=10.99, Min[518]= 2.89
SNRM_Band[0]= 5.6-> 5.8
SNRM_Band[1]= 5.5-> 5.7
SNRM_Band[2]= 5.6-> 5.8
US SNRM = 6.2
##TASK:Vdsl2TaskPMDSNRSNRMCalc done [15 symbols]
[ST_TASK] OLR_EXEC (1)
CG=7, NM=2, CG-NM=4
##TASK:Vdsl2NearACTATP done [29 symbols]
[END] SSCN/STSSC (DS SSC) = 1024/1023 (0)
[OVHD_DBG] Rx MGCNT_READ Req(rx_sf=4, rx_sb=256)
[OVHD_DBG] Tx MGCNT_READ_ACK(rx_sf=4, rx_sb=256)
[OVHD_DBG] Rx PMD_TEST_SINGLE_READ Req(rf=4, rb=256)
[OVHD_DBG] Tx PMD_TEST_SINGLE_READ_ACK(rf=4, rb=256)
[OVHD_DBG] Tx PMD_TEST_PARAM_SINGLE_READ Req...(tx_sf=81, tx_sb=224)
tc>[OVHD_DBG] Rx MGCNT_READ Req(rx_sf=82, rx_sb=256)
[OVHD_DBG] Tx MGCNT_READ_ACK(rx_sf=82, rx_sb=256)
[OVHD_DBG] Rx PMD_TEST_SINGLE_READ Req(rf=82, rb=256)
[OVHD_DBG] Tx PMD_TEST_SINGLE_READ_ACK(rf=82, rb=256)
[OVHD_DBG] === Rx PMD_TEST_SINGLE_READ_ACK(rf=82,rb=256)(tf=82,tb=223)
[OVHD_DBG] snrm (SNRM*10 dB) => 62 74 66 60 0 0
[OVHD_DBG] attndr(ATTNDR) = 22342950 (bps)
Tx_CRC[0]  = 0
Tx_FEC[0]  = 152
Tx_ERR_SEC = 0
Tx_FEC_SEC = 22
Rx_CRC[0]  = 2
Rx_FEC[0]  = 32628
Rx_ERR_SEC = 1
Rx_FEC_SEC = 579
VDSL2 Sync-Up Time:  0 Day(s)  6: 8:21
[Vcxo]=10754817
tc>
Pilot info:[146] SNRM=48.06,SNR=50.56,Bit= 0,ErrPwr=19,FFTout(223/-404)
SNRM:Ave= 5.58-> 5.7, Max[3179]=11.99, Min[518]= 2.89
SNRM_Band[1]= 5.4-> 5.6
US SNRM = 6.2
CG=7, NM=2, CG-NM=4
##TASK:Vdsl2FarACTATP done [53 symbols]
w tc sh fw
FW version : V5.5.1.126_20141202
Compile option : c3c0a
Release Testlab NUM : All
FW version[ADSL] : V3.12.8.0_MT7510
tc>w rt db off
RTS debug message OFF!
tc>w ad p
near-end FEC error fast: 0
near-end FEC error interleaved: 32680
near-end CRC error fast: 0
near-end CRC error interleaved: 2
near-end HEC error fast: 0
near-end HEC error interleaved: 0
far-end FEC error fast: 0
far-end FEC error interleaved: 152
far-end CRC error fast: 0
far-end CRC error interleaved: 0
far-end HEC error fast: 0
far-end HEC error interleaved: 0
ADSL uptime : 6:19, 42 secs
tc>w ad c
near-end interleaved channel bit rate: 62200 kbps
near-end fast channel bit rate: 0 kbps
far-end interleaved channel bit rate: 19000 kbps
far-end fast channel bit rate: 0 kbps
tc>w vdsl2 set sync_sym 0
Showtime sync sym update by pattern on!
tc>w ad r
string: ad
tc>
PTM reset hold
tpstc_txRxReset
Link State: DSL link down.
w rt db on
RTS debug message ON!
tc>Tx 10000 RTones_Req Symbols * 0
### TONES_REQ            0     50000 14783
   Change to SILENT0      (1)         SILENT1     (10001)
-------GhsHwReset------
	AFE TX_A_PATH_RX_A_PATH
ANNEXAIJLM
unitgain= 200
unitgain_v43= 80
	CARRIER_SET_A43
HwFeqWatchToneCtrl1 tone = 64 mode = 1(0:FEQ_out 1:FEQ_in 2:FEQ_coef)
HwFeqWatchToneCtrl2 tone = 64 mode = 0(0:FEQ_out 1:FEQ_in 2:FEQ_coef)
HwFeqWatchToneCtrl3 tone = 63 mode = 1(0:FEQ_out 1:FEQ_in 2:FEQ_coef)
HwFeqWatchToneCtrl4 tone = 65 mode = 1(0:FEQ_out 1:FEQ_in 2:FEQ_coef)
##T:GhsHwReset D [15037][202 symbs]
Tx 2176 RSilent0 Symbols
### SILENT0              2176  10000 16959
   Change to TONES_REQ    (1)         SILENT1     (1)
	Reset rx gain !
rtone_req_paramreset done!!
##T:GhsReduceRxGain D [16969][0 symbs]
clip:0 , adc 49 ,cnt :(50,50)!
	Reduce rx gain 1 !
##T:GhsReduceRxGain D [17014][0 symbs]
clip:0 , adc 50 ,cnt :(100,100)!
	Reduce rx gain 2 !
##T:GhsReduceRxGain D [17061][0 symbs]
RxFilter ReAdjust to RXFLTR_COEFF_33_150_ADSL_309x
A43 CTONES Detected
a43 paccu = 77420063
SymbolCount = 20363, R_State = 2(1: TX_VDSL / 2: TX_ADSL / 3: TX_ACT)
read A43 DPSKdecodeddata
###         SILENT1      32411 2578  37322
   Change to TONES        (129)         TONES_REQ   (20364)
temp_cnt = 20363
### TONES_REQ            20613 50000 37572
   Change to SILENT1      (1)         TONES       (379)
S:LNA:
lna g=0db,a=0db;hpf=off,g=-2db;aaf g= -10db;aaf_sf = off,total g=-10db,cnt=397state = 2,cnt = 1, max_pwr= 542,afe_pwr = 4257,4257,4257,need_gain = 24
lna g=18db,a=0db;hpf=off,g=-2db;aaf g= -10db;aaf_sf = off,total g=8db,cnt=402
state = 2,cnt = 4, pwr= 4258,afe_pwr = 4265
state = 2,cnt = 5, pwr= 4266,afe_pwr = 4265
state = 2,vref= 9600, pwr= 4266,afe_pd_en = 1, now_module= 18db, need= 7db
S:LNHPF:
lna g=15db,a=0db;hpf=on,g=-2db;aaf g= -12db;aaf_sf = off,total g=1db,cnt=411
state = 4,cnt = 1, max_pwr= 1049,afe_pwr = 8718,8718,8718,need_gain = 19
lna g=15db,a=0db;hpf=on,g=16db;aaf g= -12db;aaf_sf = off,total g=19db,cnt=415
state = 4,cnt = 4, pwr= 8630,afe_pwr = 8656
state = 4,cnt = 5, pwr= 8657,afe_pwr = 8656
state = 4,vref= 9600, pwr= 8657,afe_pd_en = 1, now_module= 16db, need= 0db
S:AAF:
lna g=15db,a=0db;hpf=on,g=16db;aaf g= -12db;aaf_sf = off,total g=19db,cnt=424
state = 6,cnt = 1, max_pwr= 7908,afe_pwr = 7912,7912,7912,need_gain = 1
lna g=15db,a=0db;hpf=on,g=16db;aaf g= -12db;aaf_sf = off,total g=19db,cnt=429
state = 6,cnt = 4, pwr= 7913,afe_pwr = 7916
state = 6,cnt = 5, pwr= 7917,afe_pwr = 7916
state = 6,vref= 9600, pwr= 7917,afe_pd_en = 1, now_module= -12db, need= 1db
##T:GhsAgcTrain D [37627][49 symbs]
AGC done = 56
sys_param->vcxo_for_boot = 9197
GhsSymGetPaccu r_state_cnt = 454
##T:GhsSymGetPaccu D [38210][172 symbs]
Select loop info from Table a43 with feet: (10kft/3000m)
##T:GhsGetLoopLen D [38240][0 symbs]
### SILENT1              1956  2578  39528
   Change to TONE1        (1)         TONES       (2335)
unitgain= 200
unitgain_v43= 80
	CARRIER_SET_A43
##T:GhsTxTabSetInit D [39550][6 symbs]
###         TONES        2505  2578  39699
   Change to GALF1        (1)         TONE1       (172)
Insert AEC task in GHS!!!
>>>>> AFEA60901 EC !! <<<<<
>>>>> Ec Global Search Start !! <<<<<
%ec_pwrdn_avg_pwr = (1559067),start tone : 29 , end tone : 31
EC method = EC Lookup Table !
%  0 10  1  2  1  4 (  143476)
%  1 11  1  2  1  6 (  222233)
%  2 15  1  8  0  1 ( 7665274)
%  3 15  1  6  0  5 ( 4694272)
%  4 10  1  3  1  6 (  250342)
%  5  9  1  5  1  4 (  949409)
%  6  7  1  6  1  6 ( 1282287)
%  7  6  1  7  1  4 ( 2060542)
%  8  3  1  9  1  5 ( 3441863)
%  9  5  0 13  1  5 ( 8353544)
% 10 10  0 14  1  7 ( 9870051)
% 11 15  0 15  1  0 (34888299)
% 12 15  0 11  1  7 ( 7785437)
% 13 15  0  2  1  7 ( 6452396)
Ec Code Search Loop Type is SG
% init ec1_pole = 250, 10 1 2 1 pwr(143476)
% ec0_value                    -10 (EC0:10/16)
% ec1_value                    -2 (EC1:2/16)
% ec1_pole                     4 (EC1_POLE:250KHz)
% range 2,3 5 8 12 0 4
% finial ec1_pole = 200, 8 1 2 1, pwr (22409)
% finial ec1_pole form sw = 5
%=> EC active
##T:HwAfeInternalEchoCancel D [40683][968 symbs]
##T:HwAfeWritePerfParam D [40683][0 symbs]
### TONE1                1835  2749  41363
   Change to FLAG1        (1)         GALF1       (1665)
vco value=00a41d12
###         GALF1        0     2578  41555
   Change to FLAG1        (1857)         FLAG1       (193)
### FLAG1                384   2578  41747
###         FLAG1        0     2578  41747
   Change to HSINIT       (1)         HSINIT      (2049)
   Change to HSINIT       (2049)         HSINIT      (1)
Tx CLR
ATUR REVISION_NUM=03
### HSINIT               576   2578  42323
preset_std=33
Not support G.INP!!
Not support G.INP!!
Not support G.INP!!
Not support G.INP!!
ATUR total Msg. len=183
Tx Seg. 1
##T:GhsMsgEncode D [42323][0 symbs]
   Change to HSCLR        (1)         HSINIT      (2625)
Rx msg len=4
ATUC revision no.=3
Rx HS_ACK2,Tx CLR next seg.
Tx Seg. 2
w ad diag
wan rts dbg off =>
wan hwdmt show clip =>
IFFT: max_output = 0xe623(Max:0x7ffff)
IFFT: ovfl_cnt	 =  0
TxWindow: max_dout = 0x1e623(Max:0x7ffff)
TXFltr: max_dout	= 0x36417(Max:0x3ffff)
TxFltr: clip_cnt	=    0
TxFltr: ovfl_cnt	=    0
TxFltr: lpf_ovfl_cnt	=    0(Adsl Path with ASIC)
TxFltr: lpf1_ovfl_cnt	=    0(Adsl Path with ASIC)
TxFltr: hpf_ovfl_cnt	=    0(VLR)
TxFltr: lpf1_ovfl_cnt	=    0(VLR)
TxFltr: lpf2_ovfl_cnt	=    0(VLR)
TxFltr: lpf3_ovfl_cnt	=    0(VLR)
AFE: dac_max_value = 0x6c82(Max:0x7fff)
AFE: adc_max_value = 0x62fd(Max:0x7fff)
AGC: clip_cnt =        0
RxFltr: clip_cnt	=    0
RxFltr: ovfl_cnt	=    0
RxFltr: max_dout	= 0x6195(Max:0x7fff)
RxFltr: lpf1_ovfl_cnt	=    0(ASIC only)
RxFltr: hpf1_ovfl_cnt	=    0(ASIC only)
Teq: maxdout 				= 0xc32a(Max:0xffff)
Teq: clip_cnt 				=    0(V2)
Teq: teq_in_ready_error_flag 		=    0(VLR)
Teq: dvga_input_truncate_error_flag 	=    0(VLR)
Teq: dvga_output_truncate_error_flag 	=    0(VLR)
RxWindow: max_dout = 0xc32a(Max:0xffff)
FFT: ovfl_cnt =  0
wan tcif show fw =>
wan adsl chandata =>
near-end interleaved channel bit rate: 62353 kbps
wan adsl perfdata =>
near-end FEC error interleaved: 126
near-end CRC error interleaved: 0
far-end FEC error interleaved: 0
ADSL uptime :0 min, 59 secs
wan ghs show opm =>
VDSL2(Multi)
Annex B
STD: G.993.2
Profile: 17a
wan vdsl2 show mgcnt =>
near-end path0 fec:	126(245084)
near-end path0 crc:	0(560)
near-end fec sec: 	2(5635)
near-end err sec: 	0(2)
near-end ses sec: 	0(1)
near-end los sec:  	0(0)
near-end ua  sec: 	0(226)
far-end path0 fec:	0(100922)
far-end path0 crc:	0(514)
far-end fec sec: 	0(5305)
far-end err sec: 	0(178)
far-end ses sec: 	0(0)
far-end los sec:  	0(499)
far-end ua  sec: 	0(19497)
wan vdsl2 show st_avg_snrm tx =>
TX SNRM:Ave=  6.2
TX SNRM_Band[1]=  8.0
TX SNRM_Band[2]=  6.6
TX SNRM_Band[3]=  6.0
TX SNRM_Band[4]=  0.0
TX SNRM_Band[5]=  0.0
wan vdsl2 show st_avg_snrm rx =>
RX SNRM:Ave=  5.9
RX SNRM_Band[1]=  5.7
RX SNRM_Band[2]=  5.9
RX SNRM_Band[3]=  5.9
wan vdsl2 show dmt =>
=============== TX_MOD_PARAMS ==================
tx_window_len   =  224
tx_window_type 	=    7
ce_len          =  640
cp_len          =  320
cs_len          =  544
hw_idft_size    =    7
idft_size       =   13
hw_ifft_size    =    0
ifft_size       =   13
ifft_factor     =    0
symbol_len      = 8832
ifft_bit_stealing      =     1aaa
shift_direction =  Right shift
=============== RX_MOD_PARAMS ==================
tx_window_len 	=  240
rx_window_len 	=  400
rx_window_type 	=    7
ce_len 		=  640
cp_len 		=  440
cs_len 		=  440
hw_idft_size 	=    7
idft_size 	=   13
hw_fft_size 	=    0
fft_size 	=   13
fft_factor 	=    0
symbol_len      = 8832
=============== FILTER ==================
tx_fltr_type = 0x       b
tx_fltr_gain = 0x   e8eee
rx_fltr_type = 0x       b
rx_fltr_gain = 0x     fee
=============== BAND ==================
TX BAND : start_idx, stop_idx, period
 0-th TX band :   10    31    22
 1-th TX band :  882  1193   312
 2-th TX band : 1984  2770   787
 TX band total tone num = 1121
RX BAND : start_idx, stop_idx, period
 0-th RX band :   33   857   825
 1-th RX band : 1218  1959   742
 2-th RX band : 2795  4083  1289
 RX band total tone num = 2856
RFI BAND : start_idx, stop_idx
=============== PILOT & WATCH TONE ==================
 IT pilot_tone_num =  1
 ST pilot_tone_num =  1
 pilot tone :   130
 RX watch tone :    40    50    60    70
 TX watch tone :   882   883
===== MESSAGE_TONE =====
  0-th Tone_Set :   61    63    65    67
  1-th Tone_Set :   71    73    75    77
  2-th Tone_Set :   81    83    85    87
  3-th Tone_Set :   91    93    95    97
  4-th Tone_Set :  101   102   103   104   106   107   108   109
  5-th Tone_Set :  111   112   113   114   116   117   118   119
===== SYNCHRO_TONE =====
  60  62  64  66  68  70  72  74  76  78  80  82  84  86  88  90  92  94  96  98
=============== GHS_PARAMS ==================
 all_digital_mode 	 = 1
 support_ds_vnoise 	 = 0
 lineprobe 		 = 0
 ldm_mode 		 = 0
 support_psd_shaping_us0 = 1
 support_us0_flag 	 = 1
=============== TX_PARAMS ==================
 TX_TCM_MODE 		= ENABLED
 tx_sig_without_ce 	= 1
 qam_unit_gain_psd_level = -71.3 dBm/Hz
 tx_gain_offset = 0.0 dB
 tx_pwr_limit_manual_flag = FALSE
 tx_pwr_limit = 10.1 dBm
 tx_pwr_limit_hw = 10.1 dBm
 tx_pwr_actual = 4.9 dBm
 tx_comp_flag = 1
 tx_comp_tone = 1050,2000,3200
 tx_comp_value =  0,10,15
 tx_comp_offset(non-upbo/upbo) =  0, 0
=============== RX_PARAMS ==================
 agc_vref 		= 28160  0  0  0
 agc_gain 		= 8  6  7  6
 RX_TAR_SNRM		= 3072
 RX_TCM_MODE 		= ENABLED
 rx_sig_without_ce 	= 1
 hw_rx_without_ce_limit = 0
=============== OTHERS ==================
 tx_win_en = 1
 rx_win_en = 1
 ta_operation = 1
 rfi_cancel = 0
 amd_type = 3
 tone_spacing_ghs_30a_4k_flag = 1
 profile = 17a
 DMT symbol rate(f_dmt) = 4.   0 (Ksymb/sec)
 Data symbol rate(f_s)  = 3.9844 (Ksymb/sec)
================== PhyR ======================
wan hwdmt afe show param =>
==== AFE EC Measure Setting =====
% ec_start_tone                29
% ec_end_tone                  31
% ec_calc_start_tone           29
% ec_calc_end_tone             31
% ec_lookup_table_flag         1(Look Up Table)
% ec_lookup_table_loop_type    0(SG)
% paccu                        0x3d534(54 db)
==== AFE AGC Setting =====
% agc_manual_cfg               (Disable)
% agc_gain                 6 dB
===== A60901 COMMON Setting =====
% DT Power ON/OFF:			0
% DT Mode(0: Auto Mode/1: SCM Mode)	1
===== A60901 RXV Setting =====
% AFEA60901_VLNA_ONOFF:		1
% AFEA60901_VLNA_DCCAL_EN:	0
% AFEA60901_VLNA_ATT:		0 (-0 db)
% AFEA60901_VLNA_GAIN:		4(8 db)
% AFEA60901_VLNA_COMP:		1
% AFEA60901_VAAF_ONOFF:		1
% AFEA60901_VAAF_ENABLE:	1
% AFEA60901_VAAF_ATT:		1 (-6 db)
% AFEA60901_VAAF_GAIN:		4 (4 db)
% AFEA60901_VAAF_HPF_SEL:	3 (HPF 2MHz)
% AFEA60901_VAAF_LPF_SEL:	1 (LPF 17MHz)
% AFEA60901_VAAF_COMP:		4
% AFEA60901_ALNA_BIAS:		2
===== A60901 RXA_0 Setting =====
% AFEA60901_ECALNA_ATT, 	3 (-3 db)
% AFEA60901_ECALNA_STB, 	3
% AFEA60901_ECALNA_GAIN ,	0 (0 db)
===== AFE EC Setting =====
% ec0_value                    +0 (EC0:0/16)
% ec1_value                    +0 (EC1:0/16)
% ec1_pole                     0 (EC1_POLE:450KHz)
% AFEA60901_ECALNA_ENABLE	0
% AFEA60901_ECALNA_HYB_SW	1
% AFEA60901_ECALNA_COMOP	15
% AFEA60901_ECALNA_COMFB	15
===== A60901 RXA_1 Setting =====
% AFEA60901_ECALNA_SOP,      	0
% AFEA60901_LNHPF_ONOFF,     	0
% AFEA60901_LNHPF_MODE_SEL,  	0 (HGM)
% AFEA60901_LNHPF_GAIN,      	0 (-8 db)
% AFEA60901_LNHPF_BC,        	3 (340KHz)
% AFEA60901_AAAF_ONOFF,		0
% AFEA60901_HPF_BYPASS,		3 (Bypass)
% AFEA60901_AAAF_GAIN,		0 (-14 db)
% AFEA60901_AAAF_HPF_BC,	1 (Bypass)
% AFEA60901_AAAF_LPF_BC,	0 (2.5MHz)
===== A60901 DTADC Setting =====
% AFEA60901_DTADC_RSTB_DWA		1
===== A60901 TX Setting =====
% AFEA60901_CLK_MODE_SEL,		0
% AFEA60901_DAC_ATT_GAIN,  	2 (-2db)
% AFEA60901_I2V_ENABLE,       	0
% AFEA60901_I2V_MODE_SEL,     	0
% AFEA60901_DAC_MODE_SEL_BIAS,	1
% AFEA60901_DAC_I2V_BYPASS,   	1
===== MT7555 All Reg Setting From SW =====
% VLD Gain:		0 (12 db)
% VLD ONOFF:		1
% ALD ONOFF:		0
% LD SEL:		0
% TXNF ONOFF:		0
% TXNF FC:		7 (222KHz)
wan vdsl2 show pms_pmd tx =>
<<< TX PMSTC Parameters >>>
MSGLP 	  = 0
MappingLp = 0x f
Nlp       = 1
Nbc       = 1
Path[0]   = ENABLE
Path[1]   = DISABLE
Bearer[0] =  0 (mapped onto LP #0)
Bearer[1] = ff (disabled)
B[0] 	  = 48
B[1] 	  = 0
PMSTC Primary Parameters
T[0]      = 3
G[0]      = 1
F[0]      = 1
M[0]      = 1
L[0]      = 6369
R[0]      = 16
I[0]      = 65
D[0]      = 294
q[0]      = 1
PMSTC Derived Parameters
Lmin[0]   = 4707
Lmax[0]   = 4704
ceil(G/T) = 1
MDF       = 49
K         = 49
N         = 65
PERB      = 16965 (bytes)
U         = 87
SEQ       = 87
MSGc      = 81
S         =  0.081
OR        = 130.137 (Kbps)
NDR       =  19000.117 (Kbps)
TDR       =  25376.871 (Kbps)
msgOR     = 121.162 (Kbps)
PER       =  5.348 (ms)
CRCsec    = 0.35
INP       =  2.95 (symbols)
delay     =  5.91 (ms)
<<< TX Line Bit Information >>>
TCM       = ENABLE
Nsc       = 1121
Seg_Num   = 9
nc_load   = 1118
nc_used   = 1118
nc_1bit   = 2
tcm_tones = 1117
line_bits = 6932
tcm_ovhd  = 563
L_total   = 6369
wan vdsl2 show pms_pmd rx =>
<<< RX PMSTC Parameters >>>
MSGLP 	  = 0
MappingLp = 0x f
Nlp       = 1
Nbc       = 1
Path[0]   = ENABLE
Path[1]   = DISABLE
B[0] 	  = 45
B[1] 	  = 0
T[0]      = 28
G[0]      = 1
F[0]      = 255
M[0]      = 1
L[0]      = 21109
R[0]      = 16
I[0]      = 31
D[0]      = 2652
q[0]      = 2
Lmin[0]   = 20914
Lmax[0]   = 21216
ceil(G/T) = 1
MDF       = 46
K         = 46
N         = 62
PERB      = 15624 (bytes)
U         = 9
SEQ       = 9
MSGc      = 3
S         =  0.023
OR        =  48.448 (Kbps)
NDR       =  62353.851 (Kbps)
TDR       =  84107.453 (Kbps)
msgOR     =  16.149 (Kbps)
PER       =  1.486 (ms)
CRCsec    = 0.09
INP       =  4.02 (symbols)
delay     =  7.56 (ms)
<<< RX Line Bit Information >>>
TCM       = ENABLE
Nsc       = 2856
Seg_Num   = 23
nc_load   = 2855
nc_used   = 2856
nc_1bit   = 0
tcm_tones = 2855
line_bits = 22541
tcm_ovhd  = 1432
L_total   = 21109
wan vdsl2 show st_soc_info =>
<<< ST SOC INFO - Channel Discovery Phase>>>
SNRM_MODE            = 0 (0: SNRM_MODE1  1: SNRM_MODE2)
RX_SUPPORTED_SET_NUM = 3
start_idx[0]=  33  end_idx[0]= 857
start_idx[1]=1218  end_idx[1]=1959
start_idx[2]=2795  end_idx[2]=4083
TX_SUPPORTED_SET_NUM = 3
start_idx[0]=   6  end_idx[0]=  31
start_idx[1]= 882  end_idx[1]=1193
start_idx[2]=1984  end_idx[2]=2770
RX_CD_PSD_BKPT_NUM = 32
psd_level[   1]= -99 (dBm/Hz)
psd_level[   6]= -53 (dBm/Hz)
psd_level[  32]= -54 (dBm/Hz)
psd_level[  33]= -54 (dBm/Hz)
psd_level[  36]= -54 (dBm/Hz)
psd_level[  38]= -56 (dBm/Hz)
psd_level[  81]= -60 (dBm/Hz)
psd_level[ 109]= -62 (dBm/Hz)
psd_level[ 144]= -65 (dBm/Hz)
psd_level[ 239]= -72 (dBm/Hz)
psd_level[ 267]= -73 (dBm/Hz)
psd_level[ 301]= -79 (dBm/Hz)
psd_level[ 332]= -83 (dBm/Hz)
psd_level[ 375]= -89 (dBm/Hz)
psd_level[ 378]= -89 (dBm/Hz)
psd_level[ 462]= -95 (dBm/Hz)
psd_level[ 510]= -95 (dBm/Hz)
psd_level[ 541]= -53 (dBm/Hz)
psd_level[ 679]= -53 (dBm/Hz)
psd_level[ 857]= -55 (dBm/Hz)
psd_level[ 869]= -55 (dBm/Hz)
psd_level[ 870]= -99 (dBm/Hz)
psd_level[1206]= -99 (dBm/Hz)
psd_level[1207]= -57 (dBm/Hz)
psd_level[1218]= -57 (dBm/Hz)
psd_level[1959]= -59 (dBm/Hz)
psd_level[1970]= -59 (dBm/Hz)
psd_level[1971]= -99 (dBm/Hz)
psd_level[2782]= -99 (dBm/Hz)
psd_level[2783]= -60 (dBm/Hz)
psd_level[4083]= -60 (dBm/Hz)
psd_level[4084]= -99 (dBm/Hz)
RX_MEDLEY_REF_PSD_BKPT_NUM = 31
RX_MEDLEYSET_NUM = 3 TOTAL_TONE_NUM(DsNsc) = 2856
start_idx[0]=  33  end_idx[0]= 857  period[0]= 825  period_sum[0]= 825
start_idx[1]=1218  end_idx[1]=1959  period[1]= 742  period_sum[1]=1567
start_idx[2]=2795  end_idx[2]=4083  period[2]=1289  period_sum[2]=2856
RX_TSSI_NUM =  0
TX_MEDLEY_REF_PSD_BKPT_NUM =  6
psd_level[   6]= -99 (dBm/Hz)
psd_level[  31]= -53 (dBm/Hz)
psd_level[ 882]= -54 (dBm/Hz)
psd_level[1193]= -54 (dBm/Hz)
psd_level[1984]= -56 (dBm/Hz)
psd_level[2770]= -60 (dBm/Hz)
TX_MEDLEYSET_NUM = 3 TOTAL_TONE_NUM(UsNsc) = 1121
start_idx[0]=  10  end_idx[0]=  31  period[0]=  22  period_sum[0]=  22
start_idx[1]= 882  end_idx[1]=1193  period[1]= 312  period_sum[1]= 334
start_idx[2]=1984  end_idx[2]=2770  period[2]= 787  period_sum[2]=1121
TX_TSSI_NUM =  4
TSSI[   1]=  -3 (dB)
TSSI[  10]=   0 (dB)
TSSI[  31]=   0 (dB)
TSSI[  63]=  -5 (dB)
<<< ST SOC INFO - Channel Analysis & Exchange Phase >>>
TARSNRMrx     = 60
MINSNRMrx     = 0
MAXSNRMrx     = 310
RA_MODErx     = 2 (1: fixed rate 2: adaptive rate 3: dynamically adaptive rate)
NTR           = DISABLE
RX_DYNAMIC_framing (amd3) = DISABLED
RX_SRA_DYNAMIC_L   (amd3) = DISABLED
RX_DYNAMIC_D       (amd3) = DISABLED
RX_SOS_support     (amd3) = DISABLED
RX_REOC_support    (amd3) = DISABLED
TX_DYNAMIC_framing (amd3) = DISABLED
TX_SRA_DYNAMIC_L   (amd3) = DISABLED
TX_DYNAMIC_D       (amd3) = DISABLED
TX_SOS_support     (amd3) = DISABLED
TX_REOC_support    (amd3) = DISABLED
RX_MSG_OR     = 16 (kbps)
TX_MSG_OR     = 16 (kbps)
RX MAX_NDR[0] = 30000 (x8 kbps)
RX MAX_NDR[1] = 30000 (x8 kbps)
RX_MAX_1_S    = 48
TX_MAX_1_S    = 24
RX_ROC_SNRMO  = 3072
RX_BEARER[0]  = 2 (0: inactive  2: PTMTC  4: ATMTC  8: STMTC)
RX_BEARER[1]  = 0 (0: inactive  2: PTMTC  4: ATMTC  8: STMTC)
TX_BEARER[0]  = 2 (0: inactive  2: PTMTC  4: ATMTC  8: STMTC)
TX_BEARER[1]  = 0 (0: inactive  2: PTMTC  4: ATMTC  8: STMTC)
RX_RA_RATIO   = 100
*** RX BEARER[0] Capabilities ***
NET_MIN[0]        =    16 (x8 kbps)
NET_MAX[0]        =  9250 (x8 kbps)
NET_RESERVE[0]    =     0 (x8 kbps)
MAX_INTL_DELAY[0] =    16 (ms)
INP_MIN[0]        =     4 (DMT symbol)
INP_NO_ERASURE[0] = NOT REQUIRED
TPSTC_OPT[0]      = 0
*** RX BEARER[1] Capabilities ***
NET_MIN[1]        =     0 (x8 kbps)
NET_MAX[1]        =     0 (x8 kbps)
NET_RESERVE[1]    =     0 (x8 kbps)
MAX_INTL_DELAY[1] =     0 (ms)
INP_MIN[1]        =     0 (DMT symbol)
INP_NO_ERASURE[1] = NOT REQUIRED
TPSTC_OPT[1]      = 0
TX_REOC_enable (amd3) = DISABLED
RX_REOC_enable (amd3) = DISABLED
TX_SOS_enable  (amd3) = DISABLED
RX_SOS_enable  (amd3) = DISABLED
RX_MAX_INTL_DELAY_PATH[0] = 0x 136c0( 79552)
RX_MAX_INTL_DELAY_PATH[1] = 0xffffff(Autonomous Partition)
wan vdsl2 show o_signature =>
=== O_Signature Msg ===
SUPPORTEDCARRIERSds num = 3
 0-th DS band start idx =   33, stop idx =  857
 1-th DS band start idx = 1218, stop idx = 1959
 2-th DS band start idx = 2795, stop idx = 4083
SUPPORTEDCARRIERSus num = 3
 0-th US band start idx =    6, stop idx =   31
 1-th US band start idx =  882, stop idx = 1193
 2-th US band start idx = 1984, stop idx = 2770
PSDMASKds num = 32
 0-th DS band tone idx =    1, psd level = - 95.0 dBm/Hz
 1-th DS band tone idx =    6, psd level = - 49.5 dBm/Hz
 2-th DS band tone idx =   32, psd level = - 50.0 dBm/Hz
 3-th DS band tone idx =   36, psd level = - 50.0 dBm/Hz
 4-th DS band tone idx =   38, psd level = - 52.0 dBm/Hz
 5-th DS band tone idx =   81, psd level = - 56.5 dBm/Hz
 6-th DS band tone idx =  109, psd level = - 58.5 dBm/Hz
 7-th DS band tone idx =  144, psd level = - 61.5 dBm/Hz
 8-th DS band tone idx =  239, psd level = - 68.0 dBm/Hz
 9-th DS band tone idx =  267, psd level = - 69.5 dBm/Hz
10-th DS band tone idx =  301, psd level = - 75.0 dBm/Hz
11-th DS band tone idx =  332, psd level = - 79.0 dBm/Hz
12-th DS band tone idx =  375, psd level = - 85.5 dBm/Hz
13-th DS band tone idx =  378, psd level = - 85.5 dBm/Hz
14-th DS band tone idx =  462, psd level = - 91.5 dBm/Hz
15-th DS band tone idx =  510, psd level = - 91.5 dBm/Hz
16-th DS band tone idx =  541, psd level = - 49.5 dBm/Hz
17-th DS band tone idx =  679, psd level = - 49.5 dBm/Hz
18-th DS band tone idx =  857, psd level = - 51.5 dBm/Hz
19-th DS band tone idx =  869, psd level = - 51.5 dBm/Hz
20-th DS band tone idx =  870, psd level = - 95.0 dBm/Hz
21-th DS band tone idx = 1206, psd level = - 95.0 dBm/Hz
22-th DS band tone idx = 1207, psd level = - 53.0 dBm/Hz
23-th DS band tone idx = 1218, psd level = - 53.5 dBm/Hz
24-th DS band tone idx = 1959, psd level = - 55.0 dBm/Hz
25-th DS band tone idx = 1970, psd level = - 55.0 dBm/Hz
26-th DS band tone idx = 1971, psd level = - 95.0 dBm/Hz
27-th DS band tone idx = 2782, psd level = - 95.0 dBm/Hz
28-th DS band tone idx = 2783, psd level = - 56.5 dBm/Hz
29-th DS band tone idx = 2795, psd level = - 56.5 dBm/Hz
30-th DS band tone idx = 4083, psd level = - 56.5 dBm/Hz
31-th DS band tone idx = 4084, psd level = - 95.0 dBm/Hz
PSDMASKus num = 22
 0-th US band tone idx =    1, psd level = - 90.0 dBm/Hz
 1-th US band tone idx =    2, psd level = - 68.5 dBm/Hz
 2-th US band tone idx =    3, psd level = - 56.0 dBm/Hz
 3-th US band tone idx =    4, psd level = - 47.0 dBm/Hz
 4-th US band tone idx =    5, psd level = - 40.0 dBm/Hz
 5-th US band tone idx =    6, psd level = - 35.0 dBm/Hz
 6-th US band tone idx =   31, psd level = - 35.0 dBm/Hz
 7-th US band tone idx =   32, psd level = - 35.0 dBm/Hz
 8-th US band tone idx =   40, psd level = - 57.5 dBm/Hz
 9-th US band tone idx =   48, psd level = - 76.5 dBm/Hz
10-th US band tone idx =   56, psd level = - 92.5 dBm/Hz
11-th US band tone idx =   62, psd level = - 93.5 dBm/Hz
12-th US band tone idx =   63, psd level = -117.0 dBm/Hz
13-th US band tone idx =  881, psd level = -117.0 dBm/Hz
14-th US band tone idx =  882, psd level = - 51.0 dBm/Hz
15-th US band tone idx = 1193, psd level = - 52.5 dBm/Hz
16-th US band tone idx = 1194, psd level = -117.0 dBm/Hz
17-th US band tone idx = 1983, psd level = -117.0 dBm/Hz
18-th US band tone idx = 1984, psd level = - 54.5 dBm/Hz
19-th US band tone idx = 2318, psd level = - 55.5 dBm/Hz
20-th US band tone idx = 2770, psd level = - 55.5 dBm/Hz
21-th US band tone idx = 2771, psd level = -117.0 dBm/Hz
CDPSDds num = 32
 0-th DS band tone idx =    1, psd level = - 98.5 dBm/Hz
 1-th DS band tone idx =    6, psd level = - 53.0 dBm/Hz
 2-th DS band tone idx =   32, psd level = - 53.5 dBm/Hz
 3-th DS band tone idx =   33, psd level = - 53.5 dBm/Hz
 4-th DS band tone idx =   36, psd level = - 53.5 dBm/Hz
 5-th DS band tone idx =   38, psd level = - 55.5 dBm/Hz
 6-th DS band tone idx =   81, psd level = - 60.0 dBm/Hz
 7-th DS band tone idx =  109, psd level = - 62.0 dBm/Hz
 8-th DS band tone idx =  144, psd level = - 65.0 dBm/Hz
 9-th DS band tone idx =  239, psd level = - 71.5 dBm/Hz
10-th DS band tone idx =  267, psd level = - 73.0 dBm/Hz
11-th DS band tone idx =  301, psd level = - 78.5 dBm/Hz
12-th DS band tone idx =  332, psd level = - 82.5 dBm/Hz
13-th DS band tone idx =  375, psd level = - 89.0 dBm/Hz
14-th DS band tone idx =  378, psd level = - 89.0 dBm/Hz
15-th DS band tone idx =  462, psd level = - 95.0 dBm/Hz
16-th DS band tone idx =  510, psd level = - 95.0 dBm/Hz
17-th DS band tone idx =  541, psd level = - 53.0 dBm/Hz
18-th DS band tone idx =  679, psd level = - 53.0 dBm/Hz
19-th DS band tone idx =  857, psd level = - 55.0 dBm/Hz
20-th DS band tone idx =  869, psd level = - 55.0 dBm/Hz
21-th DS band tone idx =  870, psd level = - 98.5 dBm/Hz
22-th DS band tone idx = 1206, psd level = - 98.5 dBm/Hz
23-th DS band tone idx = 1207, psd level = - 56.5 dBm/Hz
24-th DS band tone idx = 1218, psd level = - 57.0 dBm/Hz
25-th DS band tone idx = 1959, psd level = - 58.5 dBm/Hz
26-th DS band tone idx = 1970, psd level = - 58.5 dBm/Hz
27-th DS band tone idx = 1971, psd level = - 98.5 dBm/Hz
28-th DS band tone idx = 2782, psd level = - 98.5 dBm/Hz
29-th DS band tone idx = 2783, psd level = - 60.0 dBm/Hz
30-th DS band tone idx = 4083, psd level = - 60.0 dBm/Hz
31-th DS band tone idx = 4084, psd level = - 98.5 dBm/Hz
CDMAXMASKds = -49.5 dBm/Hz
MAXNOMATPds =  14.5 dBm
UPBOPSD num = 2
 0-th US band a =   60.0, b =   21.0
 1-th US band a =   60.0, b =    8.0
max_target_total_data_rate = 240000 kbit/s
ds_max_snrm 		= 31.0 dB
ds_target_snrm		= 6.0 dB
ds_tx_window_len 	= 240
ds_cp_len 		= 440
VTU-R shall select the initial setting of the timing advance
TXREFVNds num 		= 0
SNRM_MODE 		= 0
Downstream SNRM_MODE	= 1
Upstream SNRM_MODE 	= 1
TXREFVNUs num 		= 0
UPBO Band Number (amd2) = 0
wan vdsl2 show r_msg1 =>
--- R_Msg1 Msg ---
Estimate of electrical length		= 9.8 dB
Initial US PSD ceiling(CDMAXMASKus) = -49.5 dBm/Hz
CDPSDus num = 21
 0-th US breakpoint tone index =    1, psd level = - 93.5 dBm/Hz
 1-th US breakpoint tone index =    2, psd level = - 72.0 dBm/Hz
 2-th US breakpoint tone index =    3, psd level = - 59.5 dBm/Hz
 3-th US breakpoint tone index =    4, psd level = - 53.0 dBm/Hz
 4-th US breakpoint tone index =    5, psd level = - 53.0 dBm/Hz
 5-th US breakpoint tone index =    6, psd level = - 60.6 dBm/Hz
 6-th US breakpoint tone index =   31, psd level = - 60.6 dBm/Hz
 7-th US breakpoint tone index =   32, psd level = - 53.0 dBm/Hz
 8-th US breakpoint tone index =   40, psd level = - 61.0 dBm/Hz
 9-th US breakpoint tone index =   48, psd level = - 80.0 dBm/Hz
10-th US breakpoint tone index =   56, psd level = - 96.0 dBm/Hz
11-th US breakpoint tone index =   62, psd level = - 97.0 dBm/Hz
12-th US breakpoint tone index =   63, psd level = -120.5 dBm/Hz
13-th US breakpoint tone index =  881, psd level = -120.5 dBm/Hz
14-th US breakpoint tone index =  882, psd level = - 81.9 dBm/Hz
15-th US breakpoint tone index = 1193, psd level = - 85.5 dBm/Hz
16-th US breakpoint tone index = 1194, psd level = -120.5 dBm/Hz
17-th US breakpoint tone index = 1983, psd level = -120.5 dBm/Hz
18-th US breakpoint tone index = 1984, psd level = - 60.6 dBm/Hz
19-th US breakpoint tone index = 2770, psd level = - 60.6 dBm/Hz
20-th US breakpoint tone index = 2771, psd level = -120.5 dBm/Hz
Initialization pilot tone num = 1
1-th pilot tone idx = 136
Timing advance = 266
Pilot tones shall be allocated power in O-P_PILOT1
Pilot tones shall be allocated power in O-P_PILOT2
Pilot tones shall be allocated power in O-P_PILOT3
US Tx window length = 224
US CP length 	 = 320
wan vdsl2 show o_update =>
=== O_Update Msg ===
final_elect_len	 	= 9.8 dB
MAXMASKus 		= -51.0 dBm/Hz
us_highest_tone_idx	= 2770
us_lowest_tone_idx	= 10
BLACKOUTUs num 		= 0
correction_ta		= -199
wan vdsl2 show r_update =>
--- R_Update Msg ---
No limit on the downstream PSD ceiling level
Proposed highest DS sub-carrier = 4083
Proposed lowest DS sub-carrier  =   33
BLACKOUTds num = 0
Suggested CE value	= 5
wan vdsl2 show o_prm =>
=== O_Prm Msg ===
MREFPSDds num = 31
 3-th DS band tone idx =   36, psd level = - 53.5 dBm/Hz
 4-th DS band tone idx =   38, psd level = - 55.5 dBm/Hz
 5-th DS band tone idx =   81, psd level = - 60.0 dBm/Hz
 6-th DS band tone idx =  109, psd level = - 62.0 dBm/Hz
 7-th DS band tone idx =  144, psd level = - 65.0 dBm/Hz
 8-th DS band tone idx =  239, psd level = - 71.5 dBm/Hz
 9-th DS band tone idx =  267, psd level = - 73.0 dBm/Hz
10-th DS band tone idx =  301, psd level = - 78.5 dBm/Hz
11-th DS band tone idx =  332, psd level = - 82.5 dBm/Hz
12-th DS band tone idx =  375, psd level = - 89.0 dBm/Hz
13-th DS band tone idx =  378, psd level = - 89.0 dBm/Hz
14-th DS band tone idx =  462, psd level = - 95.0 dBm/Hz
15-th DS band tone idx =  510, psd level = - 95.0 dBm/Hz
16-th DS band tone idx =  541, psd level = - 53.0 dBm/Hz
17-th DS band tone idx =  679, psd level = - 53.0 dBm/Hz
18-th DS band tone idx =  857, psd level = - 55.0 dBm/Hz
19-th DS band tone idx =  869, psd level = - 55.0 dBm/Hz
20-th DS band tone idx =  870, psd level = - 98.5 dBm/Hz
21-th DS band tone idx = 1206, psd level = - 98.5 dBm/Hz
22-th DS band tone idx = 1207, psd level = - 56.5 dBm/Hz
23-th DS band tone idx = 1218, psd level = - 57.0 dBm/Hz
24-th DS band tone idx = 1959, psd level = - 58.5 dBm/Hz
25-th DS band tone idx = 1970, psd level = - 58.5 dBm/Hz
26-th DS band tone idx = 1971, psd level = - 98.5 dBm/Hz
27-th DS band tone idx = 2782, psd level = - 98.5 dBm/Hz
28-th DS band tone idx = 2783, psd level = - 60.0 dBm/Hz
29-th DS band tone idx = 4083, psd level = - 60.0 dBm/Hz
30-th DS band tone idx = 4084, psd level = - 98.5 dBm/Hz
MEDLEYds set num = 3
ce_len 				=    640
ds_cp_len 			=    440
vtu_o_idft_size 		=   8192
vtu_o_ec_period 		=   1024
vtu_o_teq_request_period 	=   6400
vtu_r_teq_request_period 	=      0
min_periodic_signal_period 	=    512
Log_tssi ds num 		= 0
wan vdsl2 show r_prm =>
--- R_PRM Msg ---
MREFPSDus num = 6
 0-th US band tone idx =    6, psd level = - 60.6 dBm/Hz
 1-th US band tone idx =   31, psd level = - 60.6 dBm/Hz
 2-th US band tone idx =  882, psd level = - 81.9 dBm/Hz
 3-th US band tone idx = 1193, psd level = - 85.5 dBm/Hz
 4-th US band tone idx = 1984, psd level = - 60.6 dBm/Hz
 5-th US band tone idx = 2770, psd level = - 60.6 dBm/Hz
MEDLEYus set num = 3
 0-th US band start idx =   10, stop idx =   31
us_cp_len 		= 320
us_tx_window_len 	= 224
vtu_r_idft_size 	= 8192
vtu_r_ec_period 		=   1024
vtu_r_teq_request_period 	=   1024
vtu_o_teq_request_period 	=   1024
min_periodic_signal_period =   1024
min_r_p_train_period 	=   5120
Log_tssi us num = 4
0-th US breakpoint idx =    1, log_tssi value = -  3.0 dB
1-th US breakpoint idx =   10, log_tssi value = -  0.0 dB
2-th US breakpoint idx =   31, log_tssi value = -  0.0 dB
3-th US breakpoint idx =   63, log_tssi value = -  5.0 dB
wan vdsl2 show r_taupdate =>
--- R_Ta_Update Msg ---
Current timing advance 	=   67
Timing advance correction  =    0
Max timing advance 	= 8191
B_ex_ds_r = 2
B_ex_us_r = 2
wan vdsl2 show o_taupdate =>
=== O_Ta_Update Msg ===
timing_advance_correction 	= -  68
B_ex_ds_o 		= 2
B_ex_us_o 		= 2
wan vdsl2 show o_msg1 =>
=== O_Msg1 Msg ===
ds_target_snrm (TARSNRM_ds) 		= 6.0 dB
ds_min_snrm (MINSNRM_ds) 		= 0.0 dB
ds_max_snrm (MAXSNRM_ds) 		= 31.0 dB
RA_MODE = AT_INIT(adaptive rate and does not change)
NTR 					= 0
--- TPS-TC Capabilities ---
Maximum number of downstream TPS-TCs of each type
Maximum number of downstream STM TPS-TCs = 0
Maximum number of downstream ATM TPS-TCs = 0
Maximum number of downstream PTM TPS-TCs = 1
Maximum number of upstream TPS-TCs of each type
Maximum number of upstream STM TPS-TCs = 0
Maximum number of upstream ATM TPS-TCs = 0
Maximum number of upstream PTM TPS-TCs = 1
Supported combinations of ds bearer channels and TPS-TCs
Support PTM on ds bearer channel 0
Supported combinations of us bearer channels and TPS-TCs
Support PTM on us bearer channel 0
Downstream PTM TPS-TC chennel 0 Capabilities
Min_net_data_rate	 		=    128 kbit/s
Max_net_data_rate	 		=  74000 kbit/s
Rederved_net_data_rate	 		=      0 kbit/s
Max_interleaving_delay	 		=     16 ms
INP_min		 			=      4 symbols
Dynamic interleaver reconfig(amd1)	= N
INP no erasure 				= N
Pre-emption 				= N
Short packet				= N
CIpolicy(amd1)				= Mandatory
Upstream PTM TPS-TC chennel 0 Capabilities
Max_net_data_rate	 		=  19000 kbit/s
Max_interleaving_delay	 		=      8 ms
INP_min		 			=      4 symbols
INP no erasure 				= N
Pre-emption 				= N
Short packet				= N
--- PMS-TC Capabilities ---
ds_olr_capability[rrufdsii] = 0x 0
us_olr_capability[rrufdsii] = 0x 0
DS framing reconfig(change of Tp, Gp, Bp0)(amd1) = N
DS SRA(change of Lp, bi, gi)(amd1)		 = N
DS interleaver reconfig(change of Dp)(amd1)	 = N
DS SOS(amd3) = N
DS ROC(amd3) = N
US framing reconfig(change of Tp, Gp, Bp0)(amd1) = N
US SRA(change of Lp, bi, gi)(amd1)		 = N
US interleaver reconfig(change of Dp)(amd1)	 = N
US SOS(amd3) = N
US ROC(amd3) = N
DS Min Message Overhead Data Rate 		=       16 kbit/s
US Min Message Overhead Data Rate 		=       16 kbit/s
Max DS net data rate for latency path 0 	=   240000 kbit/s
Max US net data rate for latency path 0 	=   240000 kbit/s
Max DS net data rate for latency path 1 	=   240000 kbit/s
Max US net data rate for latency path 1 	=   240000 kbit/s
DS (1/S)max 	= 48
US (1/S)max 	= 24
RA-DSNRMds(amd1) = 0.0 dB
RA-DTIMEds(amd1) = 0 sec
RA-USNRMds(amd1) = 0.0 dB
RA-UTIMEds(amd1) = 0 sec
flexible_OH_frame_type2(amd3) = N
DS SOS MULTISTEP ACTIVATION(amd3) = DS All tones
US SOS MULTISTEP ACTIVATION(amd3) = US All tones
Mini Net Data Rate(DS)(Bearer Channel 0)(amd3) = 0 kbit/s
Mini Net Data Rate(DS)(Bearer Channel 1)(amd3) = 0 kbit/s
DS SOS triggering criteria(amd3) = N
DS SOS-NTONES used in the decision criteria(amd3) = N
DS SOS-CRC(amd3) = 0. 0
No limit of DS MAX-SOS(amd3)
DS SNRMOFFSET-ROC(amd3) = 0.0
DS INPMIN-ROC(amd3) = 0
wan vdsl2 show r_msg2 =>
--- R_Msg2 Msg ---
Maximum number of downstream PTM TPS-TCs = 2
Maximum number of upstream PTM TPS-TCs = 2
Supported combinations of DS bearer channels and TPS-TCs
Support PTM on ds bearer channel 1
Supported combinations of US bearer channels and TPS-TCs
Support PTM on us bearer channel 1
Min_net_data_rate	 		=      0 kbit/s
Max_net_data_rate	 		= 240000 kbit/s
Max_interleaving_delay	 		=      0 ms
INP_min		 			=      0 symbols
INP no erasure 				= N
Pre-emption 				= Y
Short packet				= Y
CIpolicy(amd1)				= Optional
Downstream PTM TPS-TC chennel 1 Capabilities
INP_min		 			=      0 symbols
INP no erasure 				= N
Pre-emption 				= Y
Short packet				= Y
INP_min		 			=      0 symbols
INP no erasure 				= N
Pre-emption 				= Y
Short packet				= N
Upstream PTM TPS-TC chennel 1 Capabilities
INP_min		 			=      0 symbols
INP no erasure 				= N
Pre-emption 				= Y
Short packet				= N
DS dynamic interleaver depth = 0xf5
US dynamic interleaver depth = 0xf5
DS framing reconfig(change of Tp, Gp, Bp0)(amd1) = Y
DS SRA(change of Lp, bi, gi)(amd1)		 = Y
DS interleaver reconfig(change of Dp)(amd1)	 = one latency path
DS SOS(amd3) = Y
DS ROC(amd3) = both support DS ROC and dual latency mode
US framing reconfig(change of Tp, Gp, Bp0)(amd1) = Y
US SRA(change of Lp, bi, gi)(amd1)		 = Y
US interleaver reconfig(change of Dp)(amd1)	 = one latency path
US SOS(amd3) = Y
US ROC(amd3) = both support US ROC and dual latency mode
DS SOS MULTISTEP ACTIVATION(amd3) = (DS) No Limitation
US SOS MULTISTEP ACTIVATION(amd3) = (US) No Limitation
DS (1/S)max = 64
US (1/S)max = 64
wan vdsl2 show o_tps =>
=== O_TPS Msg ===
Mapped configurations of DS bearer channels and TPS-TC types
PTM-TC is mapped to DS bearer channel 0
DS bearer channel 1 is inactive
Mapped configurations of US bearer channels and TPS-TC types
Rate adaptation ratio of DS bearer channel 0 = 100
The whole excess capacity is allocated to bearer channel 0
DS bearer channel 0 configuration
INP_min		 			=      4 symbols
INP no erasure 				= N
Pre-emption 				= N
Short packet				= N
US bearer channel 0 configuration
INP_min		 			=      4 symbols
INP no erasure 				= N
Pre-emption 				= N
Short packet				= N
DS_MDV_BC#0(amd1) = 0.0 ms
ROC(amd3) = disable
SOS(amd3) = disable
wan vdsl2 show o_pms =>
=== O_PMS Msg ===
MSG_LP : latency path = 0 (Selected for OH frames of Type1 in the US direction)
Mapping of bearer channels to latency paths
Bearer channel 0 is carried in latency path 0
Bearer channel 1 is disable
Bx0 =   48 (octets shall be transported in each MDF in US from ch-0)
Bx1 =    0 (octets shall be transported in each MDF in US from ch-1)
PMS-TC parameters for latency path 0 in the US direction
T =      3 (Number of MDFs in an OH sub-frame)
G =      1 (Total number of overhead octets in an OH sub-frame)
F =      1 (Number of OH frames in the OH superframe)
M =      1 (Number of MDFs in an RS codeword)
L =   6369
R =     16
I =     65
D =    294 (Interleaver depth)
PMS-TC parameters for latency path 1 in the US direction
T =      0 (Number of MDFs in an OH sub-frame)
G =      0 (Total number of overhead octets in an OH sub-frame)
F =      0 (Number of OH frames in the OH superframe)
M =      0 (Number of MDFs in an RS codeword)
L =      0
R =      0
I =      0
D =      0 (Interleaver depth)
Maximun interleaver delay for LP#0(DS) = 0x   136c0
Maximun interleaver delay for LP#1(DS) = 0x  ffffff
Maximun interleaver delay for LP#0(US)(amd1) = 0x       0
Maximun interleaver delay for LP#1(US)(amd1) = 0x       0
US SOS tone group(amd3) = 0
ROC parameters for latency path 0 in the US direction(amd3)
L =      0
R =      0
I =      0
wan vdsl2 show r_pms =>
--- R_PMS Msg ---
MSG_LP : latency path = 0 (Selected for OH frames of Type1 in the DS direction)
Bx0 = 45 (octets shall be transported in each MDF in DS from ch-0)
Bx1 = 0 (octets shall be transported in each MDF in DS from ch-1)
PMS-TC parameters for latency path 0 in the DS direction
T =     28 (Number of MDFs in an OH sub-frame)
F =    255 (Number of OH frames in the OH superframe)
L =  21109
R =     16
I =     31
D =   2652 (Interleaver depth)
PMS-TC parameters for latency path 1 in the DS direction
T =      1 (Number of MDFs in an OH sub-frame)
L =      0
R =      0
I =      0
D =      1 (Interleaver depth)
Erasure decoding is not used on any DS latency path
DS SOS tone group(amd3) = 0
ROC parameters for latency path 0 in the DS direction(amd3)
L =      0
R =      0
I =      0
wan vdsl2 show bgtbl tx =>
TX :
Bit Table:
 0-th band(  10~  31) :
10  ~19  : 1    1    2    2    3    4    4    5    5    6
20  ~29  : 6    6    6    7    7    7    7    8    7    8
30  ~39  : 8    8
 1-th band( 882~1193) :
882 ~891 : 5    5    5    5    5    5    5    5    5    5
892 ~901 : 5    5    5    5    5    5    5    5    5    5
902 ~911 : 5    5    5    5    5    5    5    5    5    5
912 ~921 : 5    5    5    5    5    5    5    5    5    5
922 ~931 : 5    5    5    5    5    5    5    5    5    5
932 ~941 : 5    5    5    5    5    5    5    5    4    5
942 ~951 : 5    5    5    5    5    5    5    4    5    5
952 ~961 : 4    4    4    4    4    5    4    5    4    4
962 ~971 : 4    4    5    4    4    4    4    5    5    4
972 ~981 : 4    4    4    4    4    4    4    4    4    4
982 ~991 : 4    4    4    4    4    4    4    4    4    4
992 ~1001: 4    4    4    4    4    4    4    4    4    4
1002~1011: 4    4    4    4    4    4    4    4    4    4
1012~1021: 4    4    4    4    4    4    4    4    4    4
1022~1031: 4    0    0    4    4    4    4    4    4    4
1032~1041: 4    4    4    4    4    4    4    4    4    4
1042~1051: 4    4    4    4    4    4    4    4    4    4
1052~1061: 4    4    4    4    4    4    4    4    4    4
1062~1071: 4    4    4    4    4    4    4    4    4    4
1072~1081: 4    4    4    4    4    4    4    4    4    4
1082~1091: 3    4    4    4    3    4    4    4    4    4
1092~1101: 4    4    4    4    4    4    4    4    4    3
1102~1111: 4    3    4    4    3    4    3    4    4    3
1112~1121: 4    4    3    3    4    3    3    3    3    3
1122~1131: 3    4    3    3    3    3    3    3    3    4
1132~1141: 3    3    3    3    3    4    3    3    3    3
1142~1151: 3    3    3    3    3    3    3    3    3    3
1152~1161: 3    3    3    3    4    4    4    4    4    4
1162~1171: 4    4    4    4    4    4    4    4    4    4
1172~1181: 4    4    4    4    4    4    4    4    4    4
1182~1191: 4    4    4    4    4    4    4    4    4    4
1192~1201: 4    3
 2-th band(1984~2770) :
1984~1993: 8    8    8    8    7    8    7    7    8    8
1994~2003: 7    8    8    8    8    8    8    8    8    8
2004~2013: 7    8    8    8    8    8    8    8    8    8
2014~2023: 7    7    8    8    8    8    7    8    8    7
2024~2033: 8    8    8    8    8    8    8    8    7    7
2034~2043: 8    7    7    7    8    8    8    8    7    8
2044~2053: 8    8    8    0    8    8    8    7    8    8
2054~2063: 8    7    8    8    7    8    8    7    8    8
2064~2073: 8    7    8    8    8    8    7    8    8    8
2074~2083: 8    8    8    8    8    8    8    8    8    8
2084~2093: 8    8    8    8    8    7    8    7    7    7
2094~2103: 8    7    8    8    8    8    8    7    8    8
2104~2113: 8    8    7    8    7    8    7    8    8    7
2114~2123: 8    7    7    7    7    8    8    7    7    7
2124~2133: 7    7    8    7    8    7    8    7    7    7
2134~2143: 7    7    7    8    7    7    7    7    7    7
2144~2153: 7    7    7    7    7    7    7    7    7    7
2154~2163: 7    7    7    7    7    7    7    7    7    7
2164~2173: 7    7    7    7    7    7    7    7    7    7
2174~2183: 7    7    7    7    7    7    7    7    7    7
2184~2193: 7    7    7    7    7    7    7    7    7    7
2194~2203: 7    7    7    7    7    7    7    7    7    7
2204~2213: 7    7    7    7    7    7    7    7    7    7
2214~2223: 7    7    8    7    7    7    8    7    7    7
2224~2233: 7    7    7    7    7    7    7    7    7    7
2234~2243: 7    7    7    7    7    7    7    7    7    7
2244~2253: 7    7    7    7    7    7    7    7    7    7
2254~2263: 7    7    7    8    7    7    7    7    7    7
2264~2273: 7    7    7    7    7    7    8    7    7    7
2274~2283: 7    7    7    7    7    7    7    7    7    7
2284~2293: 7    7    7    7    7    7    7    7    7    7
2294~2303: 7    7    7    7    7    7    7    7    7    7
2304~2313: 7    7    7    7    7    7    7    7    7    7
2314~2323: 7    7    7    7    7    7    7    7    7    7
2324~2333: 7    7    7    7    7    7    7    7    7    7
2334~2343: 7    7    7    7    7    7    7    7    7    7
2344~2353: 7    7    7    7    7    7    7    7    7    7
2354~2363: 7    7    7    7    7    7    7    7    7    7
2364~2373: 7    7    7    7    7    7    7    7    8    7
2374~2383: 7    7    7    7    7    8    7    8    8    8
2384~2393: 8    8    8    7    7    8    8    8    8    8
2394~2403: 8    8    8    8    8    7    8    8    8    7
2404~2413: 8    8    8    8    8    8    8    8    7    8
2414~2423: 8    8    8    7    8    7    8    7    7    8
2424~2433: 8    7    8    7    8    7    7    7    8    8
2434~2443: 8    8    8    8    8    7    7    8    8    8
2444~2453: 8    7    7    8    7    7    7    7    7    8
2454~2463: 8    8    7    7    7    7    8    7    7    7
2464~2473: 7    7    7    8    7    7    8    7    8    7
2474~2483: 8    8    7    7    7    7    7    7    7    7
2484~2493: 7    7    7    7    7    8    7    7    7    7
2494~2503: 7    7    7    7    7    7    7    7    7    7
2504~2513: 7    7    7    7    7    7    7    7    7    7
2514~2523: 7    7    7    7    7    7    7    7    7    7
2524~2533: 7    7    7    7    7    7    7    7    7    7
2534~2543: 7    7    7    7    7    7    7    7    7    7
2544~2553: 7    7    7    7    7    7    7    7    7    7
2554~2563: 7    7    7    7    7    7    7    7    7    7
2564~2573: 7    7    7    7    7    7    7    7    7    7
2574~2583: 7    7    7    7    7    7    7    7    7    7
2584~2593: 7    7    7    7    7    7    7    7    6    7
2594~2603: 7    7    7    7    7    7    7    7    7    7
2604~2613: 7    7    7    7    7    7    7    7    6    6
2614~2623: 7    7    7    7    7    7    7    7    7    7
2624~2633: 7    7    6    6    7    7    6    6    6    6
2634~2643: 7    7    7    7    6    7    7    6    7    6
2644~2653: 6    7    6    6    6    6    7    6    6    6
2654~2663: 6    6    7    6    6    6    6    7    6    7
2664~2673: 7    7    6    6    6    6    7    6    6    6
2674~2683: 6    7    6    6    7    7    7    6    6    6
2684~2693: 6    7    6    7    6    6    6    6    6    6
2694~2703: 6    6    6    6    6    6    6    6    6    6
2704~2713: 6    6    6    6    6    6    6    6    6    6
2714~2723: 6    6    6    6    6    6    6    6    6    6
2724~2733: 6    6    6    6    6    6    6    6    6    6
2734~2743: 6    6    6    6    6    6    6    6    6    6
2744~2753: 6    6    6    6    6    6    6    6    6    6
2754~2763: 6    6    6    6    6    6    6    6    6    6
2764~2773: 6    6    6    6    6    6    6
Gain Table:
10  ~19  : 960  974  1009 1044 1108 1165 1172 1269 1270 1387
20  ~29  : 1315 1315 1315 1342 1315 1315 1315 1380 1315 1315
30  ~39  : 1315 1315
882 ~891 : 124  117  116  113  117  117  112  112  113  113
892 ~901 : 116  116  110  111  110  116  112  110  113  111
902 ~911 : 113  114  113  116  109  109  113  109  114  108
912 ~921 : 108  110  108  113  111  106  106  111  107  110
922 ~931 : 110  111  113  114  113  113  106  113  112  117
932 ~941 : 109  116  114  109  112  110  112  112  104  107
942 ~951 : 111  111  110  114  115  112  108  103  109  110
952 ~961 : 102  102  102  102  102  110  102  111  100  100
962 ~971 : 100  100  110  100  100  100  100  105  106  99
972 ~981 : 99   99   99   99   99   99   98   98   98   98
982 ~991 : 98   98   98   98   97   97   97   97   97   97
992 ~1001: 97   97   97   96   96   96   96   96   96   96
1002~1011: 96   95   95   95   95   95   95   95   95   95
1012~1021: 94   94   94   94   94   94   94   94   94   93
1022~1031: 93   0    0    93   93   93   93   92   92   92
1032~1041: 92   92   92   92   92   92   91   91   91   91
1042~1051: 91   91   91   91   91   90   90   90   90   90
1052~1061: 90   90   90   88   88   88   88   92   88   88
1062~1071: 88   88   88   88   91   88   88   88   88   88
1072~1081: 90   91   90   87   87   88   88   92   89   86
1082~1091: 85   90   92   86   85   92   91   91   88   90
1092~1101: 87   87   88   85   85   88   89   85   86   84
1102~1111: 89   84   85   91   84   85   82   86   85   82
1112~1121: 84   89   82   82   85   82   82   82   82   82
1122~1131: 82   88   81   81   81   81   81   81   81   87
1132~1141: 81   80   80   80   80   86   80   80   80   80
1142~1151: 79   79   79   80   80   80   80   80   79   79
1152~1161: 79   79   79   79   88   95   90   91   92   94
1162~1171: 91   96   96   97   95   92   90   90   91   90
1172~1181: 95   94   95   89   96   93   101  97   97   99
1182~1191: 95   99   97   96   106  108  107  107  103  108
1192~1201: 112  95
1984~1993: 2181 2188 2264 2264 1701 2143 1701 1697 2291 2204
1994~2003: 1678 2284 2249 2196 2238 2181 2205 2259 2259 2286
2004~2013: 1686 2178 2344 2221 2259 2332 2278 2329 2286 2175
2014~2023: 1751 1705 2198 2059 2302 2263 1736 2340 2286 1678
2024~2033: 2355 2305 2128 2259 2332 2355 2090 2205 1701 1736
2034~2043: 2259 1751 1716 1686 2255 2098 2290 2186 1689 2175
2044~2053: 2086 2121 2144 0    2032 2275 2363 1740 2198 2336
2054~2063: 2167 1693 2336 2082 1724 2232 2178 1689 2305 2271
2064~2073: 2167 1682 2121 2205 2186 2186 1724 2317 2232 2271
2074~2083: 2178 2329 2201 2271 2309 2232 2255 2094 2252 2178
2084~2093: 2167 2329 2163 2278 2101 1716 2305 1701 1747 1840
2094~2103: 2355 1682 2336 2305 2209 2236 2332 1713 2194 2228
2104~2113: 2151 2071 1674 2332 1678 2298 1682 2244 2240 1689
2114~2123: 2317 1674 1720 1705 1701 2332 2255 1728 1763 1686
2124~2133: 1686 1778 2340 1689 2278 1843 2336 1747 1743 1736
2134~2143: 1763 1674 1770 2332 1774 1878 1709 1728 1724 1716
2144~2153: 1697 1824 1813 1782 1736 1790 1728 1790 1813 1809
2154~2163: 1678 1747 1867 1774 1759 1847 1843 1790 1886 1832
2164~2173: 1793 1897 1836 1874 1786 1705 1920 1820 1763 1766
2174~2183: 1886 1874 1674 1994 1974 1890 1863 1901 1867 1867
2184~2193: 1882 1828 1894 1955 1986 1847 1920 1940 1932 1971
2194~2203: 1917 2013 2017 2024 1913 1951 1836 1947 1817 1967
2204~2213: 1917 1986 1924 1959 1928 1940 2059 1990 2009 1905
2214~2223: 1997 1986 2363 1774 1793 2009 2309 1890 1786 1801
2224~2233: 1867 1905 1851 2044 1990 1836 1924 2051 1986 1994
2234~2243: 1994 1697 1686 1843 1689 1701 1693 1888 1872 1900
2244~2253: 1814 1829 1759 1693 1732 1720 1701 1845 1701 1701
2254~2263: 1744 1814 1853 2355 1752 1720 1888 1755 1755 1709
2264~2273: 1783 1876 1833 1907 1911 1720 2297 1744 1701 1740
2274~2283: 1806 1903 1861 1942 1865 1907 1974 1896 1798 1845
2284~2293: 1954 1923 1822 1849 2106 1907 1931 1903 1915 1732
2294~2303: 1868 1950 1880 1970 1915 2009 1981 1888 1837 1865
2304~2313: 1829 2114 1892 1935 1919 1865 1802 1837 2001 1900
2314~2323: 1865 1724 1822 1857 1915 1993 1845 2094 1903 1962
2324~2333: 1962 1818 1970 1931 1829 1818 1833 1837 1974 1861
2334~2343: 1938 2098 1993 1985 1822 2001 1903 1814 1829 1833
2344~2353: 1779 1861 1857 1755 1923 1942 1903 1896 1849 1693
2354~2363: 1896 1728 1713 1802 1775 1744 1771 1907 1853 1806
2364~2373: 1693 1791 1748 1845 2040 1810 1697 1732 2359 1837
2374~2383: 1697 1752 1818 1717 1740 2359 1697 2386 2382 2382
2384~2393: 2355 2258 2316 1775 1713 2382 2343 2242 2211 2390
2394~2403: 2297 2371 2367 2293 2312 1755 2351 2277 2343 1787
2404~2413: 2359 2269 2320 2301 2308 2242 2293 2312 1709 2343
2414~2423: 2378 2262 2164 1736 2363 1755 2336 1709 1705 2320
2424~2433: 2343 1709 2308 1728 2351 1767 1759 1717 2289 2386
2434~2443: 2363 2382 2324 2336 2386 1697 1767 2242 2371 2316
2444~2453: 2355 1724 1705 2332 1822 1728 1736 1720 1763 2269
2454~2463: 2266 2289 1713 1728 1771 1814 2390 1798 1779 1740
2464~2473: 1818 1724 1763 2336 1693 1775 2328 1771 2375 1767
2474~2483: 2371 2355 1709 1709 1724 1736 1823 1898 1776 1803
2484~2493: 1776 1717 1768 1792 1795 2382 1760 1831 1843 1717
2494~2503: 1847 1815 1855 1815 1843 1792 1858 1831 1961 1780
2504~2513: 1788 1756 1760 1776 1823 1780 1788 1792 1819 1827
2514~2523: 1866 1807 1780 2004 1878 1807 1882 1803 1992 1890
2524~2533: 1902 1839 1831 1906 1890 1866 2087 1988 1874 1843
2534~2543: 1910 2012 2059 2134 1933 1933 2134 2012 1996 1981
2544~2553: 2000 1890 2103 2170 2044 1988 1996 2008 1858 1996
2554~2563: 2095 1918 2028 2028 2012 1953 2075 2197 2107 2067
2564~2573: 2126 2048 1961 1992 2126 1988 2154 2051 2201 2170
2574~2583: 2146 2355 2044 2280 2059 2315 2114 2118 2150 2016
2584~2593: 2051 2256 2189 2280 2177 2288 2181 2339 1709 2284
2594~2603: 2288 2347 2394 2351 2292 2418 2264 2276 2363 2323
2604~2613: 2197 2122 2296 2300 2217 2205 2225 2363 1756 1752
2614~2623: 2355 2311 2240 2256 2394 2319 2209 2276 2284 2162
2624~2633: 2307 2374 1784 1713 2237 2331 1752 1717 1811 1764
2634~2643: 2335 2418 2347 2406 1776 2284 2406 1732 2398 1713
2644~2653: 1709 2406 1721 1811 1717 1705 2406 1709 1705 1784
2654~2663: 1709 1795 2359 1756 1792 1835 1847 2268 1803 2374
2664~2673: 2382 2406 1811 1772 1736 1713 2272 1784 1768 1937
2674~2683: 1858 2406 1811 1831 2406 2382 2311 1756 1713 1843
2684~2693: 1780 2264 1709 2288 1788 1748 1728 1772 1890 1780
2694~2703: 1776 1795 1918 1732 1839 1756 1713 1855 1933 1882
2704~2713: 1819 1689 1819 1705 1788 1764 1855 1843 1752 1949
2714~2723: 1929 1732 1697 1827 1902 1941 1781 1717 1852 1836
2724~2733: 1908 1892 1904 1952 2028 2087 1872 2008 1880 1980
2734~2743: 2012 2095 1992 1900 2028 2036 1968 1944 1920 1932
2744~2753: 1980 1916 2071 2024 1960 1964 1860 2087 2000 2051
2754~2763: 1956 2103 2055 2008 2175 2119 2091 2131 2187 2211
2764~2773: 2036 2079 2083 1972 2095 2203 2008
wan vdsl2 show bgtbl rx =>
RX :
Bit Table:
 0-th band(  33~ 857) :
33  ~42  : 14   15   15   15   15   15   15   15   15   15
43  ~52  : 15   15   15   15   15   15   15   15   15   15
53  ~62  : 15   15   15   15   15   15   15   15   15   15
63  ~72  : 15   15   15   15   15   15   15   15   15   15
73  ~82  : 15   15   15   15   15   15   15   15   15   15
83  ~92  : 15   15   15   15   15   15   15   15   15   15
93  ~102 : 15   15   15   15   15   15   15   15   15   15
103 ~112 : 15   15   15   15   15   15   15   15   15   15
113 ~122 : 15   15   15   14   15   14   15   15   15   14
123 ~132 : 15   14   14   15   15   15   14   0    15   14
133 ~142 : 15   14   15   14   14   14   14   14   14   14
143 ~152 : 14   14   14   14   14   14   14   14   14   14
153 ~162 : 14   14   14   14   14   14   14   14   13   14
163 ~172 : 14   14   14   14   14   13   14   14   14   14
173 ~182 : 13   14   14   14   14   13   13   13   13   13
183 ~192 : 13   13   13   13   13   13   14   13   13   13
193 ~202 : 13   14   13   14   13   13   13   13   13   13
203 ~212 : 13   13   13   13   13   13   13   12   8    12
213 ~222 : 13   13   13   13   13   13   13   13   13   13
223 ~232 : 13   13   13   13   13   13   13   13   13   13
233 ~242 : 13   13   13   13   13   13   12   12   13   13
243 ~252 : 12   13   12   12   13   13   12   12   12   11
253 ~262 : 11   12   12   12   12   13   12   13   12   12
263 ~272 : 12   12   12   12   12   12   12   12   11   12
273 ~282 : 12   12   12   12   12   11   12   12   12   11
283 ~292 : 11   12   12   12   11   11   11   12   11   12
293 ~302 : 11   11   11   11   11   11   11   11   11   11
303 ~312 : 11   11   10   11   11   11   11   11   11   10
313 ~322 : 10   10   10   10   10   10   10   10   10   10
323 ~332 : 10   10   10   9    10   10   10   10   10   10
333 ~342 : 10   10   10   10   9    10   10   9    10   9
343 ~352 : 9    9    10   9    9    9    9    9    9    9
353 ~362 : 9    9    9    9    9    9    8    9    8    8
363 ~372 : 8    8    8    8    8    8    8    8    7    8
373 ~382 : 8    8    8    8    8    8    8    8    8    8
383 ~392 : 8    8    7    7    8    7    7    7    7    7
393 ~402 : 7    7    7    7    7    7    7    7    7    7
403 ~412 : 7    7    7    7    7    7    7    7    7    7
413 ~422 : 7    7    6    7    7    7    7    7    7    7
423 ~432 : 7    7    7    7    7    7    7    7    7    7
433 ~442 : 6    6    6    7    6    6    7    6    6    6
443 ~452 : 6    6    6    6    6    6    6    6    6    6
453 ~462 : 6    6    6    6    6    6    6    6    6    6
463 ~472 : 6    6    6    6    6    6    5    6    6    6
473 ~482 : 6    6    6    5    5    6    6    5    6    5
483 ~492 : 6    6    5    5    6    5    6    5    6    6
493 ~502 : 6    6    6    5    6    5    6    6    5    5
503 ~512 : 6    6    6    5    6    6    6    6    6    7
513 ~522 : 7    7    8    8    8    9    9    10   10   10
523 ~532 : 10   10   11   11   11   11   11   11   11   12
533 ~542 : 11   11   12   12   11   12   12   12   12   12
543 ~552 : 12   12   11   12   11   12   12   12   12   11
553 ~562 : 12   12   11   12   12   12   11   11   11   11
563 ~572 : 12   11   11   11   11   11   11   12   12   11
573 ~582 : 11   12   12   11   11   11   11   12   11   11
583 ~592 : 11   11   11   11   11   12   11   12   11   11
593 ~602 : 11   12   12   12   11   11   11   12   11   11
603 ~612 : 11   11   11   11   12   11   11   12   11   11
613 ~622 : 12   11   12   12   11   12   12   12   12   12
623 ~632 : 11   11   11   12   11   11   11   12   11   12
633 ~642 : 11   11   11   11   11   11   11   11   11   11
643 ~652 : 11   11   11   11   11   11   11   11   11   11
653 ~662 : 11   12   11   11   11   10   11   11   11   11
663 ~672 : 11   11   11   11   11   11   10   11   11   11
673 ~682 : 11   11   11   11   11   11   11   11   11   11
683 ~692 : 11   11   11   11   11   11   11   11   11   11
693 ~702 : 11   11   11   11   11   11   11   11   11   11
703 ~712 : 11   11   11   11   11   11   11   11   11   11
713 ~722 : 11   11   11   11   11   11   11   11   11   11
723 ~732 : 11   11   11   11   11   11   11   11   11   11
733 ~742 : 11   11   11   11   11   11   11   11   10   11
743 ~752 : 11   11   11   11   11   10   11   10   11   11
753 ~762 : 11   11   11   10   11   10   11   11   11   11
763 ~772 : 11   11   11   10   11   10   11   11   11   11
773 ~782 : 11   11   11   11   11   10   11   11   10   10
783 ~792 : 11   11   10   11   11   11   10   10   10   10
793 ~802 : 11   10   11   11   11   11   10   10   10   10
803 ~812 : 11   11   10   10   11   10   10   11   10   11
813 ~822 : 10   11   11   10   10   11   11   11   11   11
823 ~832 : 10   10   11   10   11   11   11   10   11   11
833 ~842 : 10   11   11   11   10   10   11   11   10   10
843 ~852 : 11   10   10   10   11   11   10   11   10   11
853 ~862 : 11   10   11   11   11
 1-th band(1218~1959) :
1218~1227: 9    9    9    9    9    9    8    8    9    8
1228~1237: 9    8    9    9    9    9    8    9    9    9
1238~1247: 9    9    8    8    8    9    8    8    9    9
1248~1257: 8    8    9    9    9    9    9    9    8    8
1258~1267: 8    9    8    8    9    9    8    9    8    8
1268~1277: 8    8    8    8    8    8    8    9    8    8
1278~1287: 8    8    8    8    8    8    8    8    8    8
1288~1297: 9    9    8    9    8    8    8    9    8    8
1298~1307: 8    8    9    8    8    8    8    8    8    9
1308~1317: 8    8    8    8    8    8    8    9    8    9
1318~1327: 9    8    8    8    8    8    8    8    8    8
1328~1337: 8    9    8    8    8    8    8    8    8    9
1338~1347: 8    8    8    9    8    8    8    8    9    9
1348~1357: 9    8    9    8    8    8    9    9    8    8
1358~1367: 8    8    8    8    7    8    8    8    8    8
1368~1377: 8    8    8    9    8    8    9    8    8    8
1378~1387: 8    8    8    8    9    8    8    8    9    9
1388~1397: 8    8    9    8    8    9    8    8    8    8
1398~1407: 8    9    8    8    8    8    8    8    8    8
1408~1417: 8    8    8    8    8    8    8    9    8    8
1418~1427: 8    8    8    8    8    8    8    8    8    8
1428~1437: 8    8    8    8    8    8    8    8    8    8
1438~1447: 8    8    8    8    8    8    8    8    8    8
1448~1457: 9    8    8    9    8    8    8    8    8    8
1458~1467: 9    8    8    9    8    8    8    8    8    8
1468~1477: 9    8    9    9    8    8    8    9    8    8
1478~1487: 8    8    8    8    8    8    9    8    8    9
1488~1497: 8    8    8    8    8    8    8    8    8    8
1498~1507: 8    8    8    8    8    8    8    8    8    8
1508~1517: 8    8    8    8    8    8    9    8    8    8
1518~1527: 8    8    9    8    8    8    9    8    9    8
1528~1537: 8    9    8    8    8    9    8    9    8    8
1538~1547: 8    8    8    9    9    9    8    9    9    8
1548~1557: 8    9    8    8    8    8    9    9    8    8
1558~1567: 8    9    8    9    9    9    8    8    9    8
1568~1577: 8    8    8    8    9    8    9    8    9    8
1578~1587: 8    9    9    8    9    8    9    8    8    8
1588~1597: 8    8    8    8    8    8    8    8    8    8
1598~1607: 8    8    8    8    8    8    8    9    8    8
1608~1617: 8    8    8    8    8    8    8    8    8    8
1618~1627: 8    8    8    8    8    8    8    8    8    8
1628~1637: 8    8    8    8    8    8    8    8    8    8
1638~1647: 8    8    8    8    8    8    8    8    8    8
1648~1657: 8    8    8    8    8    8    8    8    8    8
1658~1667: 9    8    8    8    8    8    8    8    8    8
1668~1677: 8    8    8    8    8    8    8    8    8    8
1678~1687: 8    8    9    8    8    8    8    8    8    8
1688~1697: 8    8    8    8    8    8    8    8    8    8
1698~1707: 9    8    8    9    9    9    8    8    8    8
1708~1717: 8    8    8    8    8    9    9    9    9    8
1718~1727: 8    8    8    8    9    9    8    8    8    8
1728~1737: 8    8    9    8    8    8    8    8    8    8
1738~1747: 8    8    9    8    8    8    8    8    8    8
1748~1757: 8    8    8    8    8    8    8    8    8    8
1758~1767: 8    8    8    8    8    8    8    8    8    8
1768~1777: 8    8    8    8    8    8    8    8    8    8
1778~1787: 8    8    8    8    8    8    8    8    8    8
1788~1797: 8    8    7    8    8    8    8    8    8    8
1798~1807: 8    8    8    8    8    7    8    8    8    8
1808~1817: 8    8    8    8    8    8    8    8    8    8
1818~1827: 8    8    8    8    8    8    8    8    8    8
1828~1837: 8    8    8    8    8    8    8    8    8    8
1838~1847: 8    8    8    8    8    8    8    8    8    8
1848~1857: 8    8    8    8    8    8    8    8    8    8
1858~1867: 8    8    8    8    8    8    8    8    8    8
1868~1877: 8    8    8    7    8    8    8    8    8    8
1878~1887: 8    8    8    8    7    8    8    8    7    8
1888~1897: 7    8    7    8    8    7    8    8    8    8
1898~1907: 8    8    7    8    8    8    8    8    8    8
1908~1917: 7    8    8    7    8    8    8    8    8    8
1918~1927: 8    7    8    7    8    8    8    8    8    8
1928~1937: 8    8    8    7    8    8    8    8    8    8
1938~1947: 8    8    7    8    8    8    8    8    8    8
1948~1957: 7    8    8    8    8    8    8    8    8    8
1958~1967: 8    8
 2-th band(2795~4083) :
2795~2804: 7    8    7    7    7    7    7    7    7    7
2805~2814: 7    7    7    7    7    7    7    7    6    7
2815~2824: 7    7    7    7    7    7    7    7    7    7
2825~2834: 7    7    7    7    7    7    7    7    6    7
2835~2844: 7    7    7    7    7    7    7    7    7    7
2845~2854: 7    7    7    7    7    7    7    7    7    7
2855~2864: 7    7    7    7    7    7    7    7    7    7
2865~2874: 7    7    7    7    7    7    7    7    6    7
2875~2884: 7    7    7    7    7    7    7    7    7    7
2885~2894: 7    7    7    7    7    7    7    7    7    7
2895~2904: 7    6    6    7    7    7    7    7    7    7
2905~2914: 7    7    7    7    7    7    7    6    7    7
2915~2924: 7    7    7    7    7    7    7    7    7    7
2925~2934: 7    7    7    7    7    7    7    7    7    7
2935~2944: 7    7    7    7    7    7    7    7    7    7
2945~2954: 7    7    7    7    6    7    7    7    7    7
2955~2964: 6    7    7    7    7    7    7    7    7    7
2965~2974: 7    7    7    7    7    7    7    6    7    7
2975~2984: 7    7    7    7    7    6    7    7    7    7
2985~2994: 7    7    7    7    7    7    7    7    7    7
2995~3004: 7    7    7    7    7    7    7    7    6    7
3005~3014: 7    7    7    7    7    7    7    7    7    7
3015~3024: 7    7    7    7    7    7    7    7    6    7
3025~3034: 7    6    7    6    7    6    7    6    7    7
3035~3044: 7    7    7    6    7    7    7    7    7    7
3045~3054: 7    6    7    7    6    7    7    7    7    7
3055~3064: 7    7    7    7    7    7    7    7    6    7
3065~3074: 7    7    6    7    7    7    7    7    7    7
3075~3084: 7    7    7    7    7    7    7    6    7    7
3085~3094: 7    7    6    7    6    7    6    6    6    6
3095~3104: 7    7    6    7    6    6    7    7    7    7
3105~3114: 7    6    6    6    7    7    6    7    6    7
3115~3124: 6    7    7    6    7    7    6    7    6    7
3125~3134: 6    7    6    7    7    7    6    6    6    6
3135~3144: 7    7    7    7    7    7    7    6    6    6
3145~3154: 7    7    7    7    6    6    6    6    6    7
3155~3164: 6    7    6    6    6    6    7    7    6    6
3165~3174: 7    7    6    7    7    7    7    7    7    7
3175~3184: 7    6    7    6    5    6    7    7    7    7
3185~3194: 7    6    6    7    7    7    7    6    7    7
3195~3204: 7    7    7    7    7    7    7    7    7    7
3205~3214: 7    7    6    7    7    7    7    7    7    7
3215~3224: 6    7    7    7    7    7    7    7    7    6
3225~3234: 6    7    7    7    7    7    7    6    7    6
3235~3244: 7    6    7    7    7    6    7    6    7    7
3245~3254: 7    7    6    7    7    7    7    7    6    7
3255~3264: 6    7    6    6    7    7    6    7    6    6
3265~3274: 6    6    6    6    6    6    6    6    6    6
3275~3284: 6    6    6    6    6    6    6    7    6    6
3285~3294: 6    6    6    7    6    6    6    6    7    6
3295~3304: 6    6    6    6    7    6    6    6    7    6
3305~3314: 6    6    6    6    6    6    6    6    5    6
3315~3324: 6    6    6    6    6    6    6    7    6    6
3325~3334: 6    6    6    6    6    6    6    6    6    6
3335~3344: 6    6    6    6    6    6    7    6    6    6
3345~3354: 6    6    6    6    6    6    7    6    6    6
3355~3364: 6    7    6    6    6    6    6    6    6    6
3365~3374: 6    6    5    6    6    6    5    6    6    6
3375~3384: 6    6    6    6    6    6    6    6    6    6
3385~3394: 6    6    6    6    6    6    6    6    6    6
3395~3404: 6    5    6    6    6    6    6    6    6    5
3405~3414: 6    5    6    5    6    6    6    6    5    5
3415~3424: 6    6    6    5    6    6    6    5    6    5
3425~3434: 5    5    5    6    6    5    6    6    5    6
3435~3444: 6    5    6    5    5    6    6    6    5    6
3445~3454: 5    6    6    6    5    5    5    5    5    5
3455~3464: 6    6    5    5    5    5    5    6    5    5
3465~3474: 6    5    5    5    5    5    5    5    5    6
3475~3484: 5    5    5    5    5    6    5    5    5    6
3485~3494: 5    5    6    5    5    5    5    6    5    5
3495~3504: 5    5    5    5    5    5    5    5    6    5
3505~3514: 6    5    5    5    5    5    5    5    5    5
3515~3524: 5    5    5    5    6    5    6    5    5    5
3525~3534: 5    5    5    6    5    5    5    6    5    5
3535~3544: 5    6    6    6    6    6    5    6    5    6
3545~3554: 6    5    5    5    5    6    6    6    5    5
3555~3564: 5    6    6    5    6    6    6    6    6    6
3565~3574: 6    5    6    6    6    6    6    6    6    5
3575~3584: 6    6    5    5    5    6    5    6    6    6
3585~3594: 6    6    6    6    5    6    6    6    6    6
3595~3604: 6    6    6    5    6    5    5    5    5    6
3605~3614: 6    5    5    6    6    5    5    5    5    5
3615~3624: 6    5    6    5    6    6    5    6    5    5
3625~3634: 5    6    5    6    5    5    5    5    5    6
3635~3644: 5    5    5    5    5    5    6    6    6    5
3645~3654: 5    6    5    6    6    5    5    6    5    5
3655~3664: 5    5    5    5    6    5    5    5    5    5
3665~3674: 5    5    5    5    6    6    5    5    5    5
3675~3684: 6    5    5    5    5    5    5    5    5    5
3685~3694: 5    6    5    5    5    5    5    5    5    5
3695~3704: 5    5    5    5    5    5    5    5    5    5
3705~3714: 5    5    5    5    5    5    5    5    5    5
3715~3724: 5    5    5    5    5    5    5    5    5    5
3725~3734: 5    5    5    5    5    5    5    5    5    5
3735~3744: 5    5    5    5    5    5    5    5    5    5
3745~3754: 5    5    5    5    5    5    5    5    5    5
3755~3764: 5    5    5    5    5    5    5    5    5    5
3765~3774: 5    5    5    5    5    5    5    5    5    5
3775~3784: 5    5    5    5    4    5    5    5    5    5
3785~3794: 5    5    5    4    5    5    4    4    4    4
3795~3804: 5    5    4    4    5    4    4    5    5    5
3805~3814: 5    4    5    4    5    5    5    4    5    5
3815~3824: 5    4    4    5    4    5    5    4    5    5
3825~3834: 5    5    4    5    5    5    5    4    5    5
3835~3844: 5    5    5    5    5    5    5    5    5    5
3845~3854: 5    5    5    5    5    5    5    4    5    5
3855~3864: 4    5    4    5    5    5    5    5    5    5
3865~3874: 5    5    5    5    5    5    5    5    5    5
3875~3884: 5    5    5    5    5    5    5    5    5    5
3885~3894: 5    5    5    5    5    5    5    5    5    5
3895~3904: 5    5    5    5    5    5    5    5    5    5
3905~3914: 5    5    5    5    5    5    5    5    5    5
3915~3924: 5    5    4    5    5    5    5    5    5    5
3925~3934: 5    5    5    5    5    5    5    5    5    5
3935~3944: 5    5    4    5    5    5    5    5    5    5
3945~3954: 5    5    5    5    5    5    5    5    5    5
3955~3964: 5    5    5    5    5    5    5    5    5    5
3965~3974: 5    5    5    5    5    5    5    5    5    5
3975~3984: 5    5    5    5    5    5    5    5    5    5
3985~3994: 5    5    5    5    5    5    5    5    5    5
3995~4004: 5    5    5    5    5    5    5    4    5    5
4005~4014: 5    5    5    5    5    5    5    5    5    5
4015~4024: 5    5    5    5    5    5    5    5    5    5
4025~4034: 5    5    5    5    5    5    5    5    5    5
4035~4044: 5    5    5    5    5    5    5    5    5    5
4045~4054: 5    5    5    5    5    5    5    5    5    5
4055~4064: 5    5    5    5    5    5    5    5    5    5
4065~4074: 5    5    5    5    5    5    5    3    5    5
4075~4084: 5    5    6    5    5    6    5    5    5
Gain Table:
33  ~42  : 469  558  526  512  497  591  512  558  497  558
43  ~52  : 512  483  526  542  483  483  430  497  430  430
53  ~62  : 430  430  443  430  443  469  574  443  483  483
63  ~72  : 483  469  456  456  456  512  526  456  526  512
73  ~82  : 497  497  526  469  512  469  526  542  512  512
83  ~92  : 526  469  512  497  512  542  526  512  497  512
93  ~102 : 497  558  558  574  558  497  497  526  574  542
103 ~112 : 542  542  526  558  608  574  542  591  574  644
113 ~122 : 608  644  558  469  626  469  644  608  626  483
123 ~132 : 626  497  497  626  626  608  542  512  608  512
133 ~142 : 644  469  644  469  469  512  483  512  469  483
143 ~152 : 497  483  526  497  497  483  497  497  558  558
153 ~162 : 497  512  512  542  512  542  558  558  497  574
163 ~172 : 512  512  574  558  542  430  526  574  574  574
173 ~182 : 418  558  591  574  542  418  418  430  418  418
183 ~192 : 456  430  430  497  443  418  574  443  497  526
193 ~202 : 483  558  456  574  430  483  430  443  497  456
203 ~212 : 469  591  591  497  497  542  526  591  443  469
213 ~222 : 558  497  591  483  542  512  526  512  526  526
223 ~232 : 574  591  512  497  542  512  526  526  512  574
233 ~242 : 591  574  558  591  591  542  469  443  591  574
243 ~252 : 483  574  443  456  591  591  497  430  512  512
253 ~262 : 526  469  430  443  443  591  430  591  456  526
263 ~272 : 542  443  469  443  526  456  469  483  430  497
273 ~282 : 469  483  483  512  542  469  542  574  542  497
283 ~292 : 469  542  558  574  443  497  443  591  430  574
293 ~302 : 430  483  542  542  456  456  456  526  512  483
303 ~312 : 483  526  443  591  542  526  542  558  558  497
313 ~322 : 430  443  430  456  430  456  456  443  483  430
323 ~332 : 443  456  483  456  512  542  542  512  512  591
333 ~342 : 512  558  526  542  456  574  558  443  574  456
343 ~352 : 512  443  591  469  483  469  512  574  497  497
353 ~362 : 526  526  591  526  542  542  469  591  469  443
363 ~372 : 483  443  469  497  497  558  483  512  443  512
373 ~382 : 574  526  526  574  591  542  591  558  574  574
383 ~392 : 558  591  443  406  591  456  430  430  406  430
393 ~402 : 430  443  469  418  443  430  430  430  497  418
403 ~412 : 443  497  483  558  558  483  497  512  483  542
413 ~422 : 558  512  443  497  542  542  526  558  526  591
423 ~432 : 542  542  558  526  542  558  591  574  558  591
433 ~442 : 443  512  443  574  469  469  591  456  443  497
443 ~452 : 512  483  469  497  574  497  497  591  512  526
453 ~462 : 558  558  542  497  512  526  542  542  526  542
463 ~472 : 591  558  591  558  558  574  430  574  542  542
473 ~482 : 558  558  542  430  469  526  558  456  542  497
483 ~492 : 574  558  456  443  558  443  574  430  574  512
493 ~502 : 591  558  558  469  526  483  558  558  443  430
503 ~512 : 574  542  591  443  542  558  574  558  483  574
513 ~522 : 469  443  574  456  443  497  443  542  512  443
523 ~532 : 526  430  526  497  483  483  483  443  456  591
533 ~542 : 483  456  591  591  430  591  558  574  591  542
543 ~552 : 558  558  443  558  443  558  574  574  574  469
553 ~562 : 591  558  469  574  558  574  430  430  469  443
563 ~572 : 591  430  443  443  574  430  443  591  558  456
573 ~582 : 443  574  574  497  456  483  430  558  497  456
583 ~592 : 443  430  430  526  430  591  443  591  443  456
593 ~602 : 497  591  558  542  430  430  430  591  497  430
603 ~612 : 497  430  483  512  591  443  443  574  469  469
613 ~622 : 558  443  591  574  456  591  574  591  574  591
623 ~632 : 456  469  469  591  430  443  430  591  430  574
633 ~642 : 430  456  469  443  430  443  430  483  469  574
643 ~652 : 483  526  469  469  456  483  542  456  443  497
653 ~662 : 526  591  542  456  497  418  497  497  469  497
663 ~672 : 497  469  558  483  469  526  418  483  469  469
673 ~682 : 512  469  483  526  526  497  512  512  483  526
683 ~692 : 542  512  483  542  469  512  512  591  512  483
693 ~702 : 512  542  512  526  497  542  497  558  558  526
703 ~712 : 591  512  574  526  512  558  526  526  558  542
713 ~722 : 558  542  542  574  542  542  558  526  558  542
723 ~732 : 591  526  526  574  574  542  558  542  526  574
733 ~742 : 574  542  542  591  558  512  591  526  443  558
743 ~752 : 558  542  591  574  558  430  591  443  526  574
753 ~762 : 558  558  558  418  542  430  558  542  542  558
763 ~772 : 574  558  542  430  574  418  591  558  574  574
773 ~782 : 542  558  591  574  542  418  574  526  443  418
783 ~792 : 591  574  443  574  591  558  456  456  430  430
793 ~802 : 558  443  591  591  591  591  456  418  456  418
803 ~812 : 542  591  430  443  574  418  430  574  430  574
813 ~822 : 430  591  574  483  418  574  574  558  558  591
823 ~832 : 430  456  574  418  558  574  558  418  574  574
833 ~842 : 418  574  591  542  469  418  558  558  418  443
843 ~852 : 574  430  430  418  591  591  430  591  443  574
853 ~862 : 591  497  574  574  574
1218~1227: 558  558  526  542  574  542  443  443  558  469
1228~1237: 574  443  574  542  574  558  469  591  558  558
1238~1247: 542  574  456  456  469  591  443  456  591  574
1248~1257: 443  469  574  591  574  542  526  591  456  483
1258~1267: 512  591  483  443  574  591  483  574  443  497
1268~1277: 497  512  456  483  469  443  443  591  483  443
1278~1287: 443  483  497  443  456  469  526  469  483  443
1288~1297: 591  591  497  574  469  483  456  591  443  483
1298~1307: 443  483  591  443  558  443  469  469  443  591
1308~1317: 483  469  483  443  512  512  456  591  469  591
1318~1327: 591  483  483  456  456  469  483  469  512  443
1328~1337: 483  591  456  483  526  483  469  483  469  591
1338~1347: 443  456  526  591  483  483  497  512  591  591
1348~1357: 591  469  591  483  483  497  591  591  443  443
1358~1367: 469  469  483  483  430  456  497  456  456  469
1368~1377: 483  443  443  558  469  483  591  526  443  443
1378~1387: 483  483  483  497  591  456  497  443  591  574
1388~1397: 469  483  574  443  456  591  469  483  497  483
1398~1407: 456  591  483  558  456  456  456  497  483  443
1408~1417: 483  469  443  497  497  483  497  542  443  456
1418~1427: 469  469  456  469  483  483  469  469  456  456
1428~1437: 469  483  512  443  443  456  512  497  469  512
1438~1447: 526  526  542  456  483  469  483  483  469  483
1448~1457: 558  469  469  574  469  512  456  456  591  558
1458~1467: 558  456  526  574  497  469  483  443  483  469
1468~1477: 574  469  574  591  497  469  558  558  443  469
1478~1487: 497  469  558  456  512  456  591  497  456  591
1488~1497: 526  497  469  526  443  497  469  456  469  456
1498~1507: 469  542  512  443  456  469  469  483  469  443
1508~1517: 469  526  497  512  443  469  591  469  483  512
1518~1527: 483  456  591  443  443  526  591  483  591  443
1528~1537: 469  574  469  497  456  574  443  591  512  456
1538~1547: 443  558  469  591  574  574  443  591  574  483
1548~1557: 443  558  469  483  443  456  574  591  456  443
1558~1567: 469  558  443  558  591  558  456  483  574  483
1568~1577: 483  443  497  443  574  443  591  469  574  469
1578~1587: 526  591  591  483  591  469  591  483  456  443
1588~1597: 469  497  443  443  469  443  456  443  526  443
1598~1607: 443  469  456  469  456  483  443  591  469  497
1608~1617: 443  526  483  497  483  483  542  483  483  443
1618~1627: 456  574  497  456  443  497  512  526  456  443
1628~1637: 456  469  512  512  469  456  483  469  456  456
1638~1647: 443  443  526  456  483  469  483  526  497  497
1648~1657: 483  542  456  526  443  456  443  497  542  574
1658~1667: 591  512  443  443  483  483  469  542  456  497
1668~1677: 443  469  469  512  526  443  512  483  456  443
1678~1687: 456  469  591  469  497  443  483  483  542  469
1688~1697: 497  469  469  512  469  497  497  574  456  469
1698~1707: 591  526  497  591  574  558  483  497  483  497
1708~1717: 469  469  456  526  469  591  591  591  542  542
1718~1727: 443  469  526  497  591  558  456  469  456  483
1728~1737: 497  456  591  512  469  469  469  456  456  526
1738~1747: 558  483  591  542  483  483  443  456  542  542
1748~1757: 483  512  483  469  512  512  512  469  483  497
1758~1767: 526  483  483  497  497  497  542  469  483  483
1768~1777: 526  526  591  512  591  483  497  497  526  512
1778~1787: 512  483  469  574  497  526  526  512  512  497
1788~1797: 542  526  418  542  497  558  574  526  512  558
1798~1807: 526  542  542  497  558  406  512  526  512  497
1808~1817: 558  542  483  574  542  512  469  512  469  469
1818~1827: 497  542  558  469  558  483  542  526  526  497
1828~1837: 558  443  574  558  497  497  483  574  512  469
1838~1847: 542  469  497  542  512  512  512  526  497  526
1848~1857: 526  512  542  526  558  497  542  512  542  512
1858~1867: 558  512  526  497  542  512  497  483  558  574
1868~1877: 574  558  512  430  526  526  526  542  512  526
1878~1887: 591  512  542  591  443  526  526  512  406  574
1888~1897: 456  558  469  558  542  406  526  591  558  558
1898~1907: 542  542  418  558  526  591  526  512  526  526
1908~1917: 456  591  526  430  591  591  558  574  526  526
1918~1927: 497  443  558  430  591  542  574  526  526  558
1928~1937: 542  542  558  430  558  526  558  526  574  526
1938~1947: 497  526  406  542  542  558  591  526  542  558
1948~1957: 406  542  558  526  574  526  574  558  542  558
1958~1967: 574  558
2795~2804: 406  591  418  456  430  443  443  483  443  443
2805~2814: 483  469  512  443  456  526  512  483  443  574
2815~2824: 542  469  469  456  469  469  469  497  497  483
2825~2834: 512  512  542  497  526  497  497  542  483  526
2835~2844: 497  512  512  469  526  526  591  483  483  526
2845~2854: 469  512  558  526  497  542  526  497  526  512
2855~2864: 456  526  483  483  558  558  542  512  497  483
2865~2874: 512  469  497  512  512  497  574  497  443  558
2875~2884: 497  591  558  512  512  483  574  591  483  542
2885~2894: 497  558  497  497  512  574  512  512  497  574
2895~2904: 483  456  483  542  591  526  497  526  558  574
2905~2914: 558  526  558  512  512  512  542  469  542  558
2915~2924: 526  574  497  526  526  526  526  542  497  542
2925~2934: 542  542  558  526  526  542  526  591  574  542
2935~2944: 574  512  542  512  542  558  526  542  512  574
2945~2954: 526  542  558  558  443  558  526  542  558  591
2955~2964: 443  558  526  558  542  542  526  542  574  591
2965~2974: 574  542  542  542  526  512  542  483  558  574
2975~2984: 542  512  526  591  591  469  574  574  526  558
2985~2994: 526  512  558  526  574  542  558  512  574  526
2995~3004: 558  526  542  591  542  558  591  591  443  542
3005~3014: 591  591  574  558  591  558  574  558  542  526
3015~3024: 542  591  542  591  574  558  591  574  456  574
3025~3034: 574  443  574  443  558  483  542  443  558  574
3035~3044: 574  574  542  443  526  591  542  574  526  542
3045~3054: 574  469  591  574  443  591  574  542  526  574
3055~3064: 558  526  542  591  574  512  526  542  443  497
3065~3074: 526  558  483  512  558  526  591  591  542  574
3075~3084: 542  558  574  574  574  591  591  443  591  526
3085~3094: 574  591  456  558  512  574  469  443  443  483
3095~3104: 542  542  456  542  512  512  558  574  512  526
3105~3114: 591  512  456  456  591  574  469  591  443  558
3115~3124: 558  574  526  443  542  591  443  512  456  558
3125~3134: 443  591  526  558  591  591  443  469  443  456
3135~3144: 574  591  526  574  574  591  512  443  443  469
3145~3154: 558  542  558  591  443  456  456  469  469  591
3155~3164: 469  574  443  469  456  469  574  591  469  443
3165~3174: 542  591  456  512  574  542  542  542  591  542
3175~3184: 558  443  542  483  469  497  512  574  574  558
3185~3194: 558  443  558  574  558  558  542  443  526  574
3195~3204: 574  558  542  512  558  574  526  542  526  542
3205~3214: 558  558  469  526  558  591  526  574  542  526
3215~3224: 443  574  574  542  558  542  542  558  512  574
3225~3234: 497  574  526  558  558  574  558  443  526  558
3235~3244: 591  443  558  574  558  469  574  497  558  542
3245~3254: 558  542  469  591  558  512  591  558  512  542
3255~3264: 456  558  512  483  574  591  456  591  456  456
3265~3274: 483  456  497  443  443  483  456  456  526  497
3275~3284: 443  443  443  456  483  558  542  591  456  542
3285~3294: 456  526  512  574  512  469  456  469  591  443
3295~3304: 526  469  512  512  591  526  456  456  574  456
3305~3314: 469  497  483  456  497  526  469  483  430  443
3315~3324: 443  456  443  456  456  483  469  591  512  497
3325~3334: 443  443  483  483  456  469  443  443  469  558
3335~3344: 542  456  469  558  558  574  591  497  512  497
3345~3354: 443  469  443  574  483  483  591  558  443  558
3355~3364: 512  591  483  443  512  526  469  456  456  483
3365~3374: 526  542  456  456  591  526  456  558  542  443
3375~3384: 526  497  483  456  591  512  443  558  469  542
3385~3394: 542  542  456  483  469  483  542  558  558  512
3395~3404: 542  430  558  542  542  483  574  497  591  430
3405~3414: 574  443  542  430  526  526  591  591  430  430
3415~3424: 469  591  591  443  574  591  574  430  558  443
3425~3434: 456  443  443  574  574  483  591  591  456  558
3435~3444: 497  497  591  456  483  574  591  591  430  574
3445~3454: 443  542  591  526  456  430  526  443  430  430
3455~3464: 497  591  443  443  456  456  456  591  469  483
3465~3474: 497  456  456  430  443  456  526  430  456  591
3475~3484: 443  456  430  497  469  591  456  456  483  558
3485~3494: 430  469  591  443  469  542  456  591  456  456
3495~3504: 456  526  443  443  483  483  456  456  512  456
3505~3514: 574  512  443  443  558  497  483  456  443  497
3515~3524: 430  430  443  430  542  443  591  443  483  469
3525~3534: 497  456  497  591  456  456  469  558  456  483
3535~3544: 430  542  558  512  526  574  456  526  430  512
3545~3554: 542  512  512  512  497  558  542  542  469  443
3555~3564: 469  526  542  483  542  526  591  591  574  526
3565~3574: 591  456  542  542  542  558  542  558  591  430
3575~3584: 574  591  456  443  512  526  456  591  542  542
3585~3594: 591  558  542  542  497  591  574  526  558  591
3595~3604: 591  591  574  430  574  558  443  430  558  591
3605~3614: 574  456  443  542  591  443  443  483  430  430
3615~3624: 574  430  558  456  591  591  430  591  430  430
3625~3634: 483  591  443  591  456  430  456  456  443  591
3635~3644: 443  512  430  443  430  469  574  574  591  443
3645~3654: 456  574  456  591  591  512  497  591  542  443
3655~3664: 443  430  469  430  591  456  430  483  512  443
3665~3674: 430  456  456  430  591  574  456  430  430  443
3675~3684: 591  456  469  469  456  430  456  430  456  469
3685~3694: 456  591  443  430  430  469  430  483  497  443
3695~3704: 456  443  512  483  430  483  526  430  443  497
3705~3714: 469  512  456  443  469  469  483  483  483  497
3715~3724: 443  512  456  483  469  469  512  483  443  497
3725~3734: 512  542  456  456  497  469  512  483  483  469
3735~3744: 456  574  456  469  469  526  456  456  443  497
3745~3754: 497  497  497  469  497  512  469  558  483  512
3755~3764: 574  497  456  526  526  483  469  574  497  469
3765~3774: 497  497  542  469  497  483  456  469  469  512
3775~3784: 574  483  512  497  443  469  469  497  469  558
3785~3794: 469  526  542  443  456  443  430  430  469  469
3795~3804: 469  591  430  483  574  456  430  526  456  591
3805~3814: 469  430  483  469  497  469  469  469  456  497
3815~3824: 469  443  443  526  469  497  469  430  512  497
3825~3834: 574  483  456  512  483  497  542  430  558  512
3835~3844: 483  469  456  574  512  443  542  574  469  469
3845~3854: 469  512  443  574  526  456  497  430  497  497
3855~3864: 443  497  443  512  512  574  512  512  483  574
3865~3874: 469  542  469  497  497  483  526  497  469  512
3875~3884: 526  469  512  497  512  542  483  512  512  591
3885~3894: 483  512  558  526  542  469  574  512  469  456
3895~3904: 469  469  483  497  558  512  483  512  542  558
3905~3914: 574  542  483  512  497  558  542  497  497  512
3915~3924: 512  542  469  526  512  483  512  456  483  542
3925~3934: 526  526  574  456  497  469  542  483  497  483
3935~3944: 558  483  469  512  456  483  469  456  542  526
3945~3954: 497  512  456  497  512  469  483  469  542  542
3955~3964: 574  456  483  512  497  469  574  526  469  542
3965~3974: 497  558  497  469  497  497  512  542  558  497
3975~3984: 469  558  497  469  469  526  469  469  591  574
3985~3994: 469  542  497  469  497  542  469  526  512  469
3995~4004: 469  469  558  526  497  497  469  430  512  574
4005~4014: 483  526  497  542  542  497  483  526  497  497
4015~4024: 483  512  526  542  512  512  483  456  483  497
4025~4034: 512  469  469  526  497  512  497  526  443  512
4035~4044: 497  483  469  469  526  497  526  574  526  512
4045~4054: 512  526  497  483  469  483  469  469  497  497
4055~4064: 512  542  512  456  542  456  469  456  512  430
4065~4074: 497  497  512  483  526  456  456  558  591  456
4075~4084: 469  456  591  430  456  558  430  512  469
w rts db on
RTS debug message ON!
tc>[OVHD_DBG] Rx MGCNT_READ Req(rx_sf=30, rx_sb=256)
[OVHD_DBG] Tx MGCNT_READ_ACK(rx_sf=30, rx_sb=256)
[OVHD_DBG] Rx PMD_TEST_SINGLE_READ Req(rf=30, rb=256)
[OVHD_DBG] Tx PMD_TEST_SINGLE_READ_ACK(rf=30, rb=256)
w ad p
near-end FEC error fast: 0
near-end FEC error interleaved: 290
near-end CRC error fast: 0
near-end CRC error interleaved: 0
near-end HEC error fast: 0
near-end HEC error interleaved: 0
far-end FEC error fast: 0
far-end FEC error interleaved: 0
far-end CRC error fast: 0
far-end CRC error interleaved: 0
far-end HEC error fast: 0
far-end HEC error interleaved: 0
ADSL uptime :2 min, 32 secs
tc>w ad c
near-end interleaved channel bit rate: 62353 kbps
near-end fast channel bit rate: 0 kbps
far-end interleaved channel bit rate: 19000 kbps
far-end fast channel bit rate: 0 kbps
tc>[OVHD_DBG] Rx MGCNT_READ Req(rx_sf=108, rx_sb=256)
[OVHD_DBG] Tx MGCNT_READ_ACK(rx_sf=108, rx_sb=256)
[OVHD_DBG] Rx PMD_TEST_SINGLE_READ Req(rf=108, rb=256)
[OVHD_DBG] Tx PMD_TEST_SINGLE_READ_ACK(rf=108, rb=256)
[ST_TASK] OLR_EXEC (1)
CG=7, NM=2, CG-NM=5
##TASK:Vdsl2TaskPMDSATN done [64 symbols]
[END] SSCN/STSSC (DS SSC) = 1024/1023 (0)
w rts db on
tc>w ad c
tc>[OVHD_DBG] Rx MGCNT_READ Req(rx_sf=186, rx_sb=256)
[OVHD_DBG] Tx MGCNT_READ_ACK(rx_sf=186, rx_sb=256)
[OVHD_DBG] Rx PMD_TEST_SINGLE_READ Req(rf=186, rb=256)
[OVHD_DBG] Tx PMD_TEST_SINGLE_READ_ACK(rf=186, rb=256)
[OVHD_DBG] Rx MGCNT_READ Req(rx_sf=7, rx_sb=256)
[OVHD_DBG] Tx MGCNT_READ_ACK(rx_sf=7, rx_sb=256)
[OVHD_DBG] Rx PMD_TEST_SINGLE_READ Req(rf=7, rb=256)
[OVHD_DBG] Tx PMD_TEST_SINGLE_READ_ACK(rf=7, rb=256)
[OVHD_DBG] Tx MGCNT_READ Req...(tx_sf=16, tx_sb=224)
[OVHD_DBG] Rx MGCNT_READ_ACK(rx_sf=17, rx_sb=256)(tx_sf=17, tx_sb=223)
[OVHD_DBG] Tx PMD_TEST_PARAM_SINGLE_READ Req...(tx_sf=17, tx_sb=224)
[OVHD_DBG] === Rx PMD_TEST_SINGLE_READ_ACK(rf=18,rb=256)(tf=18,tb=223)
[OVHD_DBG] latn (LATN*10 dB) =>    1  168  268    0    0
[OVHD_DBG] satn (SATN*10 dB) =>    1  166  268    0    0
[OVHD_DBG] snrm (SNRM*10 dB) => 62 76 66 60 0 0
[OVHD_DBG] attndr(ATTNDR) = 22016946 (bps)
[OVHD_DBG] Near-end actatp = 126 (ACTATP*10 dBm)
[OVHD_DBG] Far-end actatp = 47 (ACTATP*10 dBm)
Tx_CRC[0]  = 0
Tx_FEC[0]  = 0
Tx_ERR_SEC = 0
Tx_FEC_SEC = 0
Rx_CRC[0]  = 0
Rx_FEC[0]  = 290
Rx_ERR_SEC = 0
Rx_FEC_SEC = 5
Near-end total: los=0, sef=0, lpr=0
Far-end  total: los=1, sef=1, lpr=0
VDSL2 Sync-Up Time:  0 Day(s)  0: 2:41
[Vcxo]=10754902
##TASK:Vdsl2LogShowTimeErrPwr done [5 symbols]
Pilot info:[130] SNRM=48.06,SNR=50.56,Bit= 0,ErrPwr= 9,FFTout(274/-414)
SNRM:Ave= 5.67-> 5.8, Max[4072]= 8.75, Min[383]= 2.20
SNRM_Band[0]= 5.5-> 5.7
SNRM_Band[1]= 5.7-> 5.9
SNRM_Band[2]= 5.7-> 5.9
US SNRM = 6.2
##TASK:Vdsl2TaskPMDSNRSNRMCalc done [15 symbols]
CG=7, NM=2, CG-NM=5
ATTNDR = 97344000 (bps)
##TASK:Vdsl2AttNetDataRate done [5 symbols]
w ad p
near-end FEC error interleaved: 162185
near-end CRC error interleaved: 12
far-end FEC error interleaved: 419
ADSL uptime :10:04, 10 secs
tc>[OVHD_DBG] Rx MGCNT_READ Req(rx_sf=113, rx_sb=256)
[OVHD_DBG] Tx MGCNT_READ_ACK(rx_sf=113, rx_sb=256)
[OVHD_DBG] Rx PMD_TEST_SINGLE_READ Req(rf=113, rb=256)
[OVHD_DBG] Tx PMD_TEST_SINGLE_READ_ACK(rf=113, rb=256)
[OVHD_DBG] Rx MGCNT_READ Req(rx_sf=191, rx_sb=256)
[OVHD_DBG] Tx MGCNT_READ_ACK(rx_sf=191, rx_sb=256)
[OVHD_DBG] Rx PMD_TEST_SINGLE_READ Req(rf=191, rb=256)
[OVHD_DBG] Tx PMD_TEST_SINGLE_READ_ACK(rf=191, rb=256)
[OVHD_DBG] Tx MGCNT_READ Req...(tx_sf=208, tx_sb=224)
[OVHD_DBG] Rx MGCNT_READ_ACK(rx_sf=209, rx_sb=256)(tx_sf=209, tx_sb=223)
[OVHD_DBG] Tx PMD_TEST_PARAM_SINGLE_READ Req...(tx_sf=209, tx_sb=224)
[OVHD_DBG] === Rx PMD_TEST_SINGLE_READ_ACK(rf=210,rb=256)(tf=210,tb=223)
[OVHD_DBG] snrm (SNRM*10 dB) => 62 66 63 61 0 0
[OVHD_DBG] attndr(ATTNDR) = 22029210 (bps)
Tx_CRC[0]  = 0
Tx_FEC[0]  = 419
Tx_ERR_SEC = 0
Tx_FEC_SEC = 28
Rx_CRC[0]  = 12
Rx_FEC[0]  = 162207
Rx_ERR_SEC = 5
Rx_FEC_SEC = 4979
VDSL2 Sync-Up Time:  0 Day(s)  9:46:21
[Vcxo]=10739442
Pilot info:[130] SNRM=46.04,SNR=48.54,Bit= 0,ErrPwr=29,FFTout(272/-416)
SNRM:Ave= 5.70-> 5.9, Max[252]= 9.75, Min[1702]= 1.91
SNRM_Band[0]= 5.7-> 5.9
SNRM_Band[1]= 5.6-> 5.8
US SNRM = 6.2
CG=7, NM=1, CG-NM=5
##TASK:Vdsl2TaskPMDSATN done [66 symbols]
w ad p
near-end FEC error interleaved: 227106
far-end FEC error interleaved: 633
ADSL uptime :20:05, 40 secs
tc>Disconnect ADSL modem..
***   Çë ²» Òª ¹Ø ±Õ µ± Ç° ´° ¿Ú !!!   ***
*** PLEASE DO NOT CLOSE THE WINDOW !!! ***
Parsing Packets...
>>>>>>>>  ³Ì Ðò ÔË ÐÐ ½á Êø  <<<<<<<<
>>>>>>>>    END of program   <<<<<<<<
°´ ¼ü ÅÌ ÈÎ Òâ ¼ü ÍË ³ö ³Ì Ðò ...
Press any key to exit program ...
20 Oct 2014
I'll give it a week from now, if DLM for some reason doesn't perform a positive change in that time then I might force fastpath. However, with the ECI G.INP rollout supposedly coming up in a few days (which will probably take a few months), I'm reluctant to force fastpath incase someone at the DCoE notices this and doesn't like what they see (when G.INP is applied to the connection).
However, a fair test is to leave it connected for a week on interleaved. If FEC starts to rise suddenly and rapidly then it should indicate what you believe ASUS may have done. I hope however it doesn't happen.
I've further tweaked my transmit power and have now set target stability to 6dB. However, it appears with a high INP and delay that the modem won't sync much beyond a certain sync rate/SNRM even though the upper limit is actually 67Mbps.
Settings: http://i.imgur.com/Ha6Uxoi.png
Stats: http://i.imgur.com/ykJesQf.png
@mjgr33n: What's your cabinet, I presume it's a Huawei and not ECI?
25 Sep 2008
Looks like G.INP has been enabled on my cabinet now as not getting any CRC up or down errors any more.
25 Sep 2008
Not sure, it is new VDSL since XMAS, how do I tell which it is?
All I know is I was getting over 100~200 CRC Up/Down errors per day and I went on Holiday, when I came back I noticed the line had reset on Friday morning and no more CRC since then.
my speed is the same and ping rate is the same around 17ms.
20 Oct 2014
If you've seen your cabinet then it'll be one of the photos on here: http://www.robertos.me.uk/html/street_cabinets_etc.html
Each photo has a label to say which model it is. The ECI 128 is actually green, not black (as shown in the picture on that website), but it's unique as the design is slightly different to the Huawei 128 (e.g. ECI 128 has a large ventilation grill on the front door where Huawei 128 has a small ventilation grill on the door).
25 Sep 2008
Looks like ours is ECI 128, will double check later.
27 Nov 2014
to check the dslam vendor chipset (even if if huawei, juniper, eci etc) type at telnet
cat /tmp/adsl/info_adsl.txt
then you will see something like this (from previous posters up)
http://forums.overclockers.co.uk/showpost.php?p=27844409&postcount=1725
http://forums.overclockers.co.uk/showpost.php?p=27844745&postcount=1726
note the ATUCID and the middle highlighted numbers
ATURID=26005443434e0000
ATUCID=b5004946544eb204
Now using this convertor
http://ascii.cl/
49=I 46=F 54=T 4e=N which stands for IFTN = INFINEON
hope you can spot them in the convertor ... usually is the down ones & middle column
I have asked Asus & they said will add the vendor id sometime in dsl stats page
20 Oct 2014
http://ascii.cl/
Nice find. I was wondering how to convert those.
EDIT: Quicker method to convert is at http://www.rapidtables.com/convert/number/hex-to-ascii.htm
