What do people do when running 3 or 4 sli as it can be tricky to run a soundcard.
Do they go for onboard sound or a USB type soundcard.
A sound card will not increase your benchmark scores.
Hardwarecanucks did a review on this card Kappa if you want to add it in here!
A sound card will not increase your benchmark scores.![]()
Mine arrived today
[Startup]
Format=2
PowerLimit=121
ThermalLimit=
ThermalPrioritize=0
CoreClkBoost=240000
MemClkBoost=400000
FanMode=1
FanSpeed=25
[Defaults]
Format=2
PowerLimit=100
ThermalLimit=
ThermalPrioritize=0
CoreClkBoost=0
MemClkBoost=0
FanMode=1
FanSpeed=25
[Settings]
CaptureDefaults=0
VDDC_Generic_Detection = 1
[Profile1]
Format=2
PowerLimit=121
ThermalLimit=
ThermalPrioritize=0
CoreClkBoost=235000
MemClkBoost=400000
FanMode=1
FanSpeed=47
Not sure what kind of AA peeps are using but I have found that using RadeonPro (free download) with custom SMAA settings at either 1440p or 4k works really great at making the image look jaggie free with only a 5fps loss. I use max custom settings of threshold - 0.05, max search steps - 98, max search steps diagonal - 20, corner rounding - 0. It works with both 32 & 64 bit games. Much better than in game AA.
Played Far Cry 4 for a bit. Really happy with the performance of one card at 2160p
Can't wait to slot card number 2 in tomorrow![]()
