Sniper Elite V3 Benchmark
8 Feb 2015
(2x) 295x2 1050/1500
5930k @4.5
14.12 Driver
Sniper Elite 3 Benchmark Report (DirectX)
Created: 2015-02-14 at 08:30:20
Version 1.15a Build Version: 2014.12.09.001
Average FPS:71.7
Minimum FPS:8.5
Maximum FPS:883.8
Number Of Frames:5453
Average Frame:13.942ms
Minimum Frame:1.131ms
Maximum Frame:117.864ms
Machine Name:GAMING_PC
Monitors:1
Operating System:Windows 8 Professional (build 9200), 64-bit
System RAM:16287MB
CPU:Intel(R) Core(TM) i7-5930K CPU @ 3.50GHz
Number of Cores:12
GPU Name:AMD Radeon R9 200 Series
Feature Level:DX11.0
Dedicated VRAM:3072MB
Resolution Width:2560
Resolution Height:1440
Texture Detail:ULTRA
Shadows Detail:ULTRA
Draw Distance:ULTRA
Anti-aliasing:HIGH
Supersampling:4.0x
Anisotropic Level: 16
Obscurance Fields:ON
Tessellation:ON
Ambient Occlusion:ON
Motion Blur: ON
Vertical Sync:OFF
Reduce Mouse Lag:OFF
Stereo 3D:OFF
20 Nov 2005
Redditch
i7 4770@ 4.5ghz
2x Gigabyte G1 970's SLI @ 1429/1853mhz
Drivers 347.88
1440P
Created: 2015-03-27 at 11:48:12
Average FPS: 63.6
Minimum FPS: 12.2
Maximum FPS: 653.0
Number Of Frames: 4848
Average Frame: 15.716ms
Minimum Frame: 1.531ms
Maximum Frame: 81.751ms
Machine Name:
Monitors: 1
Operating System: Windows 8 (build 9200), 64-bit
System RAM: 16327MB
CPU: Intel(R) Core(TM) i7-4770K CPU @ 3.50GHz
Number of Cores: 8
GPU Name: NVIDIA GeForce GTX 970
Feature Level: DX11.0
Dedicated VRAM: 3072MB
Resolution Width: 2560
Resolution Height: 1440
Texture Detail: ULTRA
Shadows Detail: ULTRA
Draw Distance: ULTRA
Anti-aliasing: HIGH
Supersampling: 4.0x
Obscurance Fields: ON
Tessellation: ON
Ambient Occlusion: ON
Motion Blur: ON
Vertical Sync: OFF
Reduce Mouse Lag: OFF
Stereo 3D: OFF
Man of Honour
OP
21 May 2012
Dalek flagship
4 x TX @1430/2002
5960X @4.0
347.88 Drivers
2160p
Created: 2015-03-31 at 08:46:08
Average FPS: 89.8
Minimum FPS: 11.1
Maximum FPS: 937.5
Number Of Frames: 6834
Average Frame: 11.141ms
Minimum Frame: 1.067ms
Maximum Frame: 90.047ms
Machine Name: HAL
Monitors: 1
System RAM: 16265MB
CPU: Intel(R) Core(TM) i7-5960X CPU @ 3.00GHz
Number of Cores: 16
GPU Name: NVIDIA GeForce GTX TITAN X
Resolution Width: 3840
Resolution Height: 2160
Anti-aliasing: HIGH
Supersampling: 4.0x
Tessellation: ON
Motion Blur: ON
Vertical Sync: OFF
Stereo 3D: OFF
Caporegime
24 Sep 2008
Essex innit!
1440P
3930K @ 4.625 - Titan X at 1396/4010 - 347.88
1080P
Edit:
settings used.
Created: 2015-04-02 at 16:18:55
Average FPS: 59.7
Minimum FPS: 17.8
Maximum FPS: 287.6
Number Of Frames: 4553
Average Frame: 16.742ms
Minimum Frame: 3.477ms
Maximum Frame: 56.044ms
Machine Name: GREGSTERS
Monitors: 1
Operating System: Windows 8 Professional (build 9200), 64-bit
System RAM: 16323MB
CPU: Intel(R) Core(TM) i7-3930K CPU @ 3.20GHz
Number of Cores: 12
Anti-aliasing: HIGH
Supersampling: 4.0x
Tessellation: ON
Motion Blur: ON
Vertical Sync: OFF
Stereo 3D: OFF
Created: 2015-04-02 at 16:20:53
Average FPS: 98.1
Minimum FPS: 21.3
Maximum FPS: 662.0
Number Of Frames: 7461
Average Frame: 10.192ms
Minimum Frame: 1.511ms
Maximum Frame: 47.000ms
Monitors: 1
System RAM: 16323MB
Number of Cores: 12
Resolution Width: 1920
Resolution Height: 1080
Anti-aliasing: HIGH
Supersampling: 4.0x
Tessellation: ON
Motion Blur: ON
Vertical Sync: OFF
Stereo 3D: OFF
