- 21 Jul 2005
- Officially least sunny location -Ronskistats
Can't say I have but not been playing many games to test this out lately.
On a bit of a side note to the current discussion but still related to this thread. My OC throttles like hell under load and the only way I was able to resolve it was to install AMD Overdrive - Enable Turbo Boost then disable it and click OK and then it stopped throttling.
Anyone else experienced this?
Disable flash hardware acceleration in your browser.
Jesus 5ghz on stock FSB?
You really need to do it properly, I bet you could get stable at those speeds.
this 8320E - is a beast....very nice, hope your APM is disabled. Many people doing wrong OC with APM enabled.
you find some my FX in albums there:
https://www.flickr.com/photos/20698985@N05
Love your pictures dude! Is it okay if i pinch a couple of use on the AMD UK social pages? I'll be sure to link to your album.![]()
Send me it, I can join in
APM master has the eefect, the TDP of chip is still around 125W (For 125W chip). So example you did OC to 5 GHz with APM master enabled and in Superpi 1M your score will be around 16s, so the same as with APM Master disabled.
But you can run Cinebench R11 or R15 and all threads will be jumping up and down because APM Master ant keep your TDP around 125W and score will be low. Example around 7.7 points. With disabled APM Master it will be correct and it is around 8.6 points at 5 GHz OC.
btw, what link is AMD UK FacebooK?Send me it, I can join in
