Hehe yea, but in their pictures of the case with hardware installed they are using a Corsair AX1200 which is 200mm long and it fits
 - also I have seen others mounting 200-225mm length psu's in that case without issues.My current Thernaltake is 225mm and it fit in the CM690 which only 'fits' 165mm PSUs if you want to use the bottom 120mm fan. I'm using a 80mm fan instead so the psu fits
