4 Apr 2015 at 21:44 #1 timboooo timboooo Associate Joined 25 Sep 2014 Posts 43 I am rendering something on Cinema 4d and my CPU is constantly running at 100%. I just wanted to know if this is normal and will not harm my pc? My PC Specs: Intel i7 5820k 3.30ghz 16gb ram Cheers
4 Apr 2015 at 21:46 #2 stulid stulid Caporegime Joined 17 Jan 2010 Posts 66,731 Location weston-super-mare Thats what you want isnt it? full use of your CPU doing something like that.
4 Apr 2015 at 21:50 #3 timboooo timboooo Associate OP Joined 25 Sep 2014 Posts 43 Ah ok so it is a good thing. It is still really slow! Will overclocking my pc make much of a difference? thank you for the quick reply
4 Apr 2015 at 21:51 #4 stulid stulid Caporegime Joined 17 Jan 2010 Posts 66,731 Location weston-super-mare Yes.
4 Apr 2015 at 21:58 #5 Randomface74 Randomface74 Permabanned Joined 9 Aug 2009 Posts 12,234 Location UK what cpu cooler do you have? are you monitoring your cpu temperature?
4 Apr 2015 at 22:23 #6 timboooo timboooo Associate OP Joined 25 Sep 2014 Posts 43 I have the corsair h110 280mm liquid cpu cooler. I have not checked the temperatures. Not sure how to check it other than in the bios. Which would mean stopping the rendering to reset the computer.
4 Apr 2015 at 22:42 #7 varkanoid varkanoid Soldato Joined 31 Dec 2007 Posts 13,868 Location The TARDIS, Wakefield, UK Install coretemp or hw monitor for your temps. Can you not pause the render ? I thought you could in Cinema 4D?
4 Apr 2015 at 22:52 #8 timboooo timboooo Associate OP Joined 25 Sep 2014 Posts 43 Ok so I have installed hw monitor. Temperatures seem fine I think. I was not aware you could pause the rendering. I will look into that.
5 Apr 2015 at 11:27 #9 OracIe OracIe Associate Joined 10 Jun 2013 Posts 1,135 Those temps are fine, overclocking could speed things up but it will also run hotter.
5 Apr 2015 at 11:58 #10 Telecaster Telecaster Soldato Joined 17 Jun 2012 Posts 5,951 OracIe said: Those temps are fine, overclocking could speed things up but it will also run hotter. Click to expand... Surely the whole point of running such a CPU and a H110 is to overclock it? Otherwise why bother with the expense?
5 Apr 2015 at 12:25 #11 FloppyPoppy FloppyPoppy Soldato Joined 27 Jan 2012 Posts 8,120 Location The king of the north! Can cinema 4D utilise GPU power? Or does your system not have a dedicated GPU?
5 Apr 2015 at 12:38 #12 OracIe OracIe Associate Joined 10 Jun 2013 Posts 1,135 Telecaster said: Surely the whole point of running such a CPU and a H110 is to overclock it? Otherwise why bother with the expense? Click to expand... Indeed, I'm merely stating to the OP that overclocking will rise the temp.
