I love how you are using the engine lift for the exact opposite of its intended function.![]()
How else you going to get an engine designed to come out the bottom out on your drive?![]()
That MR2 sure is a lovely colour![]()
Had a successful day of unseizing the height adjustment collars on the coilovers and raising the car by 10mm.
It took lots of swearing and bashed knuckles but got them free in the end, the collars are looking battered now though.
Shouldn't seize again though as ive coated the threads with copper grease, which is something i should have done when i fitted them and would have saved a whole lot of hassle.
Is that a GT30 or similar, Dale V? Looks sizeable![]()
it should go....
Its a GTX3076Rit should go....
good spot!
