I'm looking at buying the Sapphire R9 295x2, which at under £500 seems a pretty good price, to upgrade from 2 x 7950 CF for eyefinity.
A couple of questions, I have a Corsair TX850W PSU, which has 1 x 12v rail of 70A, will this be enough?
Other bits are an Oc'd i7 930, an SSD and HDD, soundcard.
Also, what are the dimensions of the Fan/Radiator combo, is it really 64mm deep? As its in an Antec 1200 case with one of those stupidly massive Noctua cpu coolers and there isn't 64mm of clearance from the rear vents and the edge of the cooler
So where would I locate the radiator?
