GTA V
Status
Not open for further replies.
Send me a invite plz as i cant request one due to privacy settings for some reason even tho it worked in other crew.
Same name as forum name.
It says the emblem has changed but I'm still seeing that default chattering teeth one... :p
Also Cainer and Josh you guys should be able to see pending requests and should be able to accept people. I've given you both the most privileges that it would allow me. :D
Can you delete the chattering teeth one then the new one should be the default one, unless theres a crew profile setting u missed to switch the default to or somit.
yeah im getting them again now, accepting requests ok as they come,
cheers :)
Have you seen that the GTA V maps you get have secrets only visible using black lights? God damn it looks so cool.. Don't get me wrong, getting off Steam is most definitely a good thing I won't regret, but the map... With black light secrets... Aaarghh
Edit: Sorry I see it's only collectors edition, BUT I WANT!! Here's the vid to prove: https://www.youtube.com/watch?v=QrSUUacykcM
You sure he hasn't just jizzed all over his map?
Status
