- 4 Nov 2011
- N.I
The most I got out of a 480 was 7000 points, around the same as a 7950 running it at 960mhz under water. IIRC the stock 580 scored around 6000 points making both it and the 7970 far faster than a single 580.
The 750ti runs both the 480 and stock 580 close so even running two they will not come anywhere close to the 780.
Those numbers I pulled are from 3Dmark's website so are irrefutable. Going by those numbers (because SLI scales perfectly in 3Dmark 11) it would take three 580s scaling almost perfectly to get close to the 780.
Sorry man in this instance you are clearly wrong. I still own a GTX 480 Lightning which is every bit as good as any 580 and compared to any modern card it's ancient history.
I really don't understand why you are giving the OP false hope.
It's saturday night and i have gaming to get on with but in closing i will say this, you are wrong. The 580 sli will compete with a single 780 in most circumstances. Dont take my word for it though, i am sure someone else has made the upgrade from 580 sli to 780 and can share their findings.
