Will do mate, need more time as I'm busier than I'd like to be. Another reason I went Nexus 6 is that cos it's a Nexus and been out a while, the modding scene is thriving.
Cheers looks very handy. are you on 5.1? Is that battery % icon from Franco?
This the correct xda thread? http://forum.xda-developers.com/nexus-6/orig-development/kernel-franco-kernel-r1-t2987173
Yes I'm on 5.1 at the moment. If you install the FKupdater app you can flash the kernel from inside (Flashify on playstore is also useful).
Battery percent indicator is a little system tweak, I went for the lazy option and used this app (can uninstall after its toggled) -
https://play.google.com/store/apps/details?id=de.kroegerama.android4batpercent&hl=en_GB
When Xposed & mavity box works again on 5.1 there are many useful tweaks that can be enabled on the stock rom.
EDIT: the latest Franco kernel only works on 5.1
 I have ideas of a One, N6 or S6 currently
 Will look forward to your opinion tomorrow. IPhone screen is now almost half yellow :/
