The AMD Driver Thread
Mei
Mei
3 Jan 2012
qkqkqkqk <3 ducks
you had a chance to play gta yet?
it needs mods but looks like it runs great
MKX has some online lag but more fun to watch i think
17 Jan 2007
Kent, UK
Matt, is it still the plan that there will be a driver release in April with the xfire Freesync update? I love my new BenQ monitor but am itching to try out Freesync now as well :)
Caporegime
OP
12 Jul 2007
United Kingdom
qkqkqkqk <3 ducks
Only a little bit, it looks so amazing though i can see myself playing it a lot...soon. Very busy with work atm. :(
I'll test Dying Light later and see what's what. Can I ask, I remember you stating that there may need to be a patch to enable CF properly due to the way they display textures? What exactly has the "better Dying Light" profile done? I'll find out later :)
There have been two Dying Light patches since then, but I've not personally had chance to test it myself. Either way, we've enabled it now. :)
As far as i know, yes. :)
21 Jan 2014
Matt, I'm still having issues with the corruption in the bottom right-hand corner. The problems in the video have disappeared. Also seen another person in the official GTA thread with the same issue.
23 Dec 2013
North Wales
BF4 is broken on both Mantle and DX11 for me on 15.4. Stuttering has completely gone but it is now flickering really badly, hurts my eyes. Anyone else getting the weird flickering corruption in BF4?
Matt: Do you mind seeing if your having this issue?
Think my post disappeared into the AMD Driver thread abyss. :p
MSAA appears to be the culprit. Disabled all AA and it disappeared. Enabled FXAA and reflection AA and it stayed away. Enabled MSAA and it came back.
I'm getting the exact same issue with MSAA turned on too.
25 May 2013
Kent.
4K Monitor, popping and flickering like no tomorrow. Latest beta drivers. Tried two DP cables. I'm probably going need to find a more expensive cable, i've no idea what to look for in DP, vesa certified etc.. ?
1440p on HDMI is fine.
Montior is the aoc u2868pqu.
14 Dec 2013
I am using a Startech Mini DisplayPort to DisplayPort cable and it works very well at 4K so I would recommend Startech.
Caporegime
OP
12 Jul 2007
United Kingdom
