******Official War Thunder Thread*******
How does the match-maker work currently for Arcade silliness?
For tanks, it ONLY takes into account your top Battle Rating tank, so for example if you unlock a BR 4.7 tank you may be better off sticking playing at all 3.7's until you unlock another 4.7, otherwise you'll be facing much tougher tanks in mostly 3.7's. (And you'll have stock ammo, and no repair toolkit in your 4.7)
When I see a KV2, I normally scream and run away. I have however, managed to kill one in my mighty T50 (from very close range).
I've been playing this for the last month or so and I'm quite enjoying it, apart from having to play arcade mode (the wait for the other games is too long). I started with German tanks and worked my way up to a Stug III F and Panzer IV F2 but decided to try Russian tanks after continually getting smashed by T34s, KV1's and KV2's. Now I have my KV1, it feels like I'm continually getting smashed by Panzer IV F2's and Stug III F's :rolleyes: (<- aimed at myself).
Now I'm not expecting to be the dominant tank in any match I play, of course not, but I can't work out where I'm going wrong. I read a few pages back about the Battle Rating calculation, so looked at mine and saw that the KV-1 ZiS-5 was taking me into a higher bracket (I did have some matches against Panther and Tiger tanks) so I took it out. Now I'm not facing those tanks (phew!), but still struggling a bit.
I was going to ask for advice (any advice is still welcome of course), but I've just read a previous post by matt_fsr which has some good tips that I'll work on.
Any chance I can join the OcUK squadron?
See comments above on Battle Rating calculations. The KV1 Zis-5 is a 4.7 so will drag you up to higher battles, yet it offers little benefit over it's 3.7 sibling I find.
Soviet tanks are a mixed bag early on, some great fun, some are steaming turds - they seem to have a strong 2.7BR lineup and also around 3.3, but struggle above that until the appearance of the KV2 at 4.7, soon to be upgraded to 5.0 apparently. (45mm of armour on a T34 is great at a BR where a lot of stuff can't punch through it, but less great as your opponents improve)
At BR 5.0, stronk Russian tonk murders everything :D - if you use them correctly. KV2 and SU152 both throw 152mm of HE or AP death, which apart from the occasional really unlucky bounce off sloped armour, pretty much guarantees a kill. The 3rd tank can be either a KV1, or T34, or if you're brave bring along the ZUT37 of trollness :p
6.0 Soviet brings you IS-2. The Mjolnir of tanks. 'Nuff said.
To defeat tanks, you need to start learning weak spots, and where certain models store their ammo, so you're not wasting shots on just causing damage. Pz3 and Pz4's have vulnerable driver glass, so if you can stick a shell through their front where the driver sits - insta-kill.
Lots of tanks are also vulnerable to turret hits, especially ones that store ammo in the turrets. View the tank models in 'outline' mode or whatever it's called to see where shells are kept, and aim for that spot when you're taking them on.
Finally, accept that you're sometimes at the mercy of the Gaijin random number generator, where your 88mm cannon which could (in real life) reliably kill a Sherman tank at any angle, from over 1km away, simply bounces shots off a standard M4A2 while it mocks you with its' .30 cal. :p
(Apply in-game to squadron, we'll get you in)
More than welcome sir. Just search for OCUK on the games squadron screen.
Re the KV2, in a nice nippy T50, get in behind it and put a shell into the large panel at the rear of its turret. Job done. :D
OH GREAT! :eek:
You've gone and done it now!
His head was big enough after the last one (There are no hats that fit him anymore), but after THIS he's going to have trouble getting that cranium through the doors!
Bah!
:p:D
Cheers for the info Matt! :)
Makes perfect sense. I was slaying at BR 2.7 and BR3.3.
BR2.7 with the first t34 ACED was brilliant. Some dominant games!:D
T34's rock at those levels before you get many long barrelled 75's Only a few paper thin but hard hitting self propelled guns to worry about.:cool:
I've ground out a complete BR4.7 setup now and it seems a lot fairer. Pretty much all opponents have good penetration. oooh err:p
I might have to pop back to planes for a bit....
Seeing as we've had a few new members sign up it might be worth mentioning Friday night fun times. Which admittedly has declined somewhat of late due to non-participation (me being one of the guilty parties) but perhaps a reintroduction would be in order.
For those not aware, Friday nights used to be filled with much hilarity and mayhem. Running everything from biplanes to monster jets, baby pea shooter tanks through to the big daddies. Basically something for everyone. The only prerequisite for joining in on the fun is jumping on TS (even if no mic you can still listen in). Oh and one other prerequisite would be thick skin-the banter can be lively!!
Can we get a 'hell yea'if anyone is up for it??
Well, I know what I'll be signing up to when I get home.. although I'm more of a fan of the planes than the tanks, is always good fun dropping bombs from my Wellington Mk X.
If you're going back to planes and don't already know. The 3.3-3.7 Brit line up is looking to be quite awesome right now. Admittedly you may need to purchase a couple of premium planes to fill it out. But as I posted above it can potentially include the spit IIB, 2xboomerangs (premium planes) typhoon IB (premium again but everyone should buy the pack it comes in - it's a no brainer 10k golden eagles, premium membership for a month etc- the Eagles are worth more than the cost of the pack!). You've also got a couple of heavy hitting beaufighters in there too, although not as much fun as they once were they are excellent bomber destroyers as you can get up to bomber level petty quickly with them.
I have a full compliment of just about all the german planes upto about BR5.7, but sadly no british stuff. :-(
I'll look into British packs, but it spending EVEN MORE £££. Wasted far too much on WT already!:eek:
I can run some amusing planes at BR3.X tho. :-)
I'll try to get online Friday night. Its just the missus i have to work around... ;)
IIRC i have a new BR4.0 me410 with 50mm trolocannon to grind out. Should be an interesting mix of dogfight frustration and bomber destruction! :D
Also, while people are dishing out useful advice, I'm on a free account but have a few hundred Golden Eagles. What, if anything, is the best thing to spend them on?
If you have 250 Eagles or more, then on the orders of Comrade Stalin you must purchase Zhukovsky's i-153 Chaika premium biplane.
Allow me to explain why:
:D
Otherwise, you're best off spending them 10 at a time on crew points, upping the driver vitality, as well as the gunner and loader. Spend a few on the gunner accuracy and rangefinding, but they get expensive quick.
Early on, your aim is to get your total crew level up to a high enough number that you can 'Expert' your crew for free using Silver Lions, and this will give you a decent boost to several skills, including reload time.
You can spend 100 Eagles at once for a bigger % benefit, but bear in mind you've 3 tank crew slots per nation, and 3 nations with tanks so far - before you even touch crew slots on planes. :)
New aircraft in 1.49:
USA: Skyraider AD-2
USSR: IL-2 1943
Germany: Ar 234C-3, Hs.129 (Cockpit)
Britain: FireFly F.Mk.I, FireFly F.Mk.V, Seafire Mk.XVII, Sea Fury FB.11, Attacker FB.1, Canberra (Cockpit)
Japan: J2M2, Ki-21
New ground vehicles:
USA: M2A2, 75mm M3 GMC, M18 GMC, T95 GMC, Т28, М10 GMC, M18 Black Cat, M5A1 (5th Armored Division)
Germany: StuH 42G
USSR: 4М GAZ-ААА, SU-57, SU-122-54, Т-34-85E, Т-34E STZ, IS-2 "Revenge", SU-76М (5th Guards Cossacks Cavalry Corps)
I hadn't even realised that you can up the performance of the crew :eek:. I have done so now, a little bit.
I've also sorted my tanks out so that I am currently running the T50, T34, and SU-76, and I'm having great fun stacking up plenty of kills. Not too far off the KV2 now either.
USA: Skyraider AD-2
USA: T95 GMC
Well... I'm happy now!
A new plane to bomb ALL the things with, and an American Troll tank of truly epic proportions. That'll do, Gaijin. That'll do... as long as the tank is at 5.0. Otherwise you can sod right off, son!
USA: Skyraider AD-2
USA: T95 GMC
Can you imagine, the T95/T28 at 5.0. That would be ridiculous, just crazy. I don't think there is much chance of that ;)
