ok but why have a server over something like a NAS or media storage device like WD Live ?
So it can be used as a pc and NAS ?
Would this not work with a pc ?
The HP Gen8 is much more powerful than the Synology
A server IS a pc... it's just one that's more generally designed for business applications.
I just bought two of the HP microservers with 4x main hard drive bays + one extra for less than the price of a single Synology 4-bay NAS... plus you can do more with it.
My *main* home server is a personal build "PC" running windows 7 with about 10 drive bays... using 8x 3TB drives + 1x 1TB + 1x 750GB.
I have 2x Synology DS214j with 4x4TB each
I am running out of storage.
With the recent cashback deals that are valid this month, you can buy an HP Gen8 Microserver for £120 after cashback... with 4x full size drive bays and an extra internal usb or internal sata for the operating system.
The HP Gen8 is much more powerful than the Synology, you can run the Synology OS on it if you would like to... otherwise you can run a fully fledged OS on it if you choose also & do a lot more with it than a basic NAS can do.
Currently, one is running Windows Server 2012 as a trial and the other is running Windows 7 like my primary server.
It's unlikely these will be used for more than fileservers and maybe a dev webserver for my wife... but they were under half the price of a Synology and more functional while drawing not much more power from the wall.
It's a no-brainer in my opinion... unless you're desperate for more drive bays in a single unit or more processing power (although the ram and cpu can be upgraded in the Gen8).. grab the deal while it's available![]()
There's a video of someone on Youtube taking out the Celeron and dropping a Xeon into one. That kind of blew my mind when I saw that. Compact Xeon power. Although it's probably a bitch to cool.
Now some info on my end,
I use my main pc store all my movies, images and music.
and I was also thinking of getting a small pc HTPC or media box like the android fire tv,
Im not sure when but I was thinking of getting a HTPC to use in the living room, is there I could do the same with Micro Server.
I know these 2 are unlikely but could I run 2 os at the same time from it ?
and use it from another room with a pc in the room just tv ?
What do you do with so much storage ?
I should be fine with 4 drive I only use 4tb, and knowing me I will still have my main PC for storage also,
are these fast as the pc to transfer data ?
1. How many cpus can they take, Im so use to assuming everthing has one slot.You can run 2OS simultaneously yes, although the basic CPU is not the most powerful... it can do basic tasks like fileserver & htpc as two seperate OS without much trouble.
Yes... you can drop a couple of decent processors into the unit without any change to the cooling...
Movies... mostly. I like full, uncompressed blu-ray rips rather than the web-encoded 4GB 1080p movies floating around... a movie is easily 20-25GB each.
TV episodes also take up about 9TB.
The HP Gen8 is faster than the Synology DS214j for transferring files, you can easily max out a gigabit ethernet connection with 4x drives if you set the server up correctly.
More speed than you'll need for a decade really... for media streaming, at least.
