Caporegime
 - 18 Sep 2009
 - Dormanstown.
How poor?
Any comparisons?
Probably somewhere between that 4GHZ Phenom OC and the FX4300 stock.
You're basically running 4 Yorkdale cores @ 3.7 aren't you?
How poor?
Any comparisons?
I have managed to stop tinkering with settings now and am getting a solid 60FPS, with good temps so I don't need to monitor it anymore.
Im currently using:
Res: 1920x1080
Vsync in game Off
Vsync in Nvidia control panel - adaptive
All settings on High
FXAA - On
MSAA - off
Reflection MSAA - off
all three draw sliders - mid way
Antistropic filtering x16
Post fx - Normal(only disables motion blur which is fine by me)
This gives me 60FPS all day long with no drops(unless im online then it drops to about 57fps) with temps sitting around 50 for CPU/GPU1 and GPU2.
System:
CPU: AMD fx8350 @ 4.4
RAM: 8gb
GFX: Nvidia 770 4GB x2
SSD: Samsung EVO
I tested everything on very high and still got 60FPS consistently but my temps on both cards were breaching 70 and considering I have been playing for hours on end, I don't want them sitting at those temps for that length of time so put the settings down to high instead.
Biased.
Happy Spoffle?
Most of his claims are BS (Said as much previously), but I still find others to be as bad/worse. While Dave can talk crap (And does), there's an absolute truth in Intel have the higher performing CPU's, and this can come through in games, and while he may try and exaggerate, there's plenty of AMD owners who simply ignore it and pretend there's no truth in anything he'd say. Given the choice these people would take an FX83 over a modern i5 in gaming, despite the i5 being factually better. In order for one to do so, a bias must exist.
Infantile arrogance.Given the choice these people would take an FX83 over a modern i5 in gaming, despite the i5 being factually better. In order for one to do so, a bias must exist.
I wouldn't be expecting miracles.
But with a 7970 you're bottlenecked in nigh on every game you play anyway![]()
7970 will be strangled by the CPU?
Oh dear, looks like CPU/MOBO/RAM upgrade, could probably budget 150 pound for that, not up to speed with processors and all that I'm 7 years behind![]()
People chose an FX-83## because to them they are better, whether you agree or not.
Its because they don't agree with you that makes them in your mind bias.
So, a 8 core Piledriver is better than a modern i5 in gaming overall, yes or no? There's no opinion, it's fact. And the i5 is the better CPU overall in games.
To choose one in spite of the facts is bias.
That's logic rather than arrogance.
It is for me yes.
OK a post that seems helpful found:
This is based on:
* a real in game test by a persons system - not a benchmark
* the game being playable
* The FX actually not being overclocked to its potential (an 8350 should be capable of 4.7Ghz comfortably)
* note this is NOT an i3!
This is the usual backed into a corner remark, no one contests this martini - however you use it like the old top trumps cards spoilt kids used in the playground. Funnily enough this thread wasn't about i5's but then again if you want to argue that old chestnut again you will find they belong in a different price bracket and generally have games optimised to run on their hardware to stand out!![]()
When you turn up the Quality settings in a game your adding Physics, Lighting, Shading.... calc which is where low threaded performance becomes less important and high threaded performance more important.
Assuming it's threaded well. If not, it's the opposite.
So, an almost entirely irrelevant statement.
So is GTA5 well threaded or not? I heard it was.
Tell you what, I'm bored, I'm doing nothing, stuck in a rut, keeping an eye on BBC's coverage of the Boro game. I'll sort my MSI AB out and run some tests for you![]()
To choose one in spite of the facts is biased.
