- 12 Jun 2010
I've changed my tactics a bit now for this game. Running 780ti in SLI by the way, at 1440p on a rog swift with gsync.
I'm finding it painful getting consistent stutter free performance across all locations. I think This game, like many, has slight weirdness when it comes to SLI, vsync and gsync. Gsync just isn't cutting it properly for some reason and isn't helping with stutter.
So I've changed my tactics to running the game at 60hz and shooting for a rock steady consistent 60fps at all times. Weirdly, to do this though I have to set my swift to 60hz, but use a framerate limiter and set it to 59.
Doing this, it really is smooth as silk and I can pretty much max out all the settings (except msaa which I'm not using anyway - using sweetfx and SMAA instead.)
I just need to get used to trying to live with 60hz bluriness, but it's the best solution I've found for now.
I was wondering if I was the only one to notice gsync doesn't seem to work right in gta 5.Something isn't quite right and the faintest amount of stutter in single card and sli seems to happen when panning round.Plays beautifully smooth at 60 fps on my TV ,but seems to suffer more from blur on my rog swift when locked at 60 hz.Dont get me wrong it's not gta 4 levels of stuttering and stammering but because it does run soooo smoothly at times it's quite jarring when it hiccups on the swift.its as if its occasionally drawing a frame twice or something.
Couldn't get radeonpro to work so tried borderless mode and it is much better than having vsync on in game.
but I'm just a bit fussy at times and because the game is beautifully smooth and really well optimised,the slight hiccups just make me sorry cos it would be otherwise perfect.
