**** The Official Note 4 thread ****
you need to re-enable the nova service in settings >> accessibility
Can't find this anywhere, I've never enabled any nova service in settings that I remember anyway. Can anyone help with this please? What setting am I looking for exactly and where is it.
Whatsapp is also totally screwed since I installed lollypop. I get popups for every bloody message including group messages now, how can I disable this. Everything is set to no popups in the whatsapp settings as it always was.
Then reinstall nova, you need the service to pull down notifications from anywhere.
All the other gestures seem to work fine, for example swipe up to bring up nova settings. Its all done within nova's settings, but expanding notifications with a swipe down is the only one that no longer works for me.
I've disabled all popups in WhatsApp notification settings yet I'm still getting a box pop up at the top of the screen above everything else. Am I the only one having these issues? Iv not wiped phone since installing lp.
Edit. Thanks James I may have to do that, I've never needed to go to those settings before for nova, they don't appear on my phone at present under services.
Anyone have any ideas on whatsapp?
Then reinstall nova, you need the service to pull down notification.
You missed a step. You need the beta version.
Go to Nova settings -> under Nova check for updates -> on the top right corner three dots will appear -> tap on beta and update..
After installing the full update.. enable the gesture setting for pulling down the notification and follow the steps for activating services under accessibility...
Is it just me or is the Gallery app borked? It takes a good few seconds for a photo to be taken and then view (sepcifically interact with) it straight after in the gallery. In fact, general Gallery operation seem sluggish on here (both with KK and LP).
Thinking I'm going to have factory reset and the root mine after LP update. Something is just constantly keeping it awake according to the power menu.
Quite the norm for LP users I'm afraid. There seems to be no pattern to all the forum posts etc that I've seen mention wake locks with LP users on the Note.
What is the file name for the BTU update? I downloaded one last night and flashed which is named N910FXXU1BOB4_N910FOXA1BOB4_N910FXXU1BOB4_HOME.tar yet after flashing my device shows itself as N910FXXU1BOC4.......is this correct or has summat gone hay wire?
EDIT:- My mistake.....getting mixed up with ROMs I have downloaded and not cleared up after use. The one I downloaded last night is N910FXXU1BOC5_N910FBTU1BOB2_N910FXXU1BOC4_HOME.tar.md5
