Nice setup you have there.
Which brand of TitanX are you using ?
I'll get my name on the hall of fame as well -
Would I be mad to change two 980's for two Titan X's for 3440*1440?
Or just wait for the Ti to come out?
Proper bios? Which bios are we recommending for cards on air with low ASIC?
On air the highest I'd go is the maxair BIOS, it locks the card to 1.255v though.
The EVGA SC 425 bios is fine for some but I was getting crashes due to voltage not being high enough for my clocks, could have just upped the voltage manually in PX but I flashed maxair instead.
Anything that gives you a higher TDP to stop power throttling is a good start.
I want 2 EVGA SC versions of these but can't find them anywhere. Any reason not to pull the trigger on a couple of ASUS ones? They don't seem to be as popular. From a warranty point of view it would be OCUK dealing with it would it not?
I have a normal titan, is it worth upgrading to a Titan X?
