- 1 May 2013
- M28
I don't do physical copies - bad for the environment.
OK
well only £21.84
@ CDKeys using 5% off, and is the digital version.I don't do physical copies - bad for the environment.
well only £21.84
@ CDKeys using 5% off, and is the digital version.Just got this too via CDKeys. Hope it works well with a pad.
Has anyone whos a Team/Junior/Senior member had their game removed from Steam and the discount code sent to them yet?
Very tempted with this, a question for those experienced with wheels; is the Logitech Driving Force GT a decent cheap wheel for a first wheel? I can pick a used one up locally for about the £50 mark, wondered if it's worth a punt.
. No messing Project Cars is a challenge, don't expect to win everything from the off, although you can turn the AI down to make it easier. Even slow AI will beat you if you're always in the gravel though, just like real life racing
OK![]()
well only £21.84
Doesn't say anywhere in the description its the digital le.
Your aware the website is called CD keys, right?
