Please help with my network problem
Man of Honour
29 Mar 2003
Blurton
For the first couple of months with my Amazon Fire TV I was having no problems and then over the last month it's been a nightmare and hopefully somebody might know what's going on.
I have a k: drive on my PC that has 3 main folders called TV, Films and Documentary so I drop files into these for later viewing.
About 3 out of 5 times I will access a film/TV show from my Fire TV and a network problem will occur.
When I go downstairs my k: drive will have been removed :eek:
I reboot my PC, go upstairs and it might behave itself but the following day it might remove the drive again.
I have no problems accessing my NAS or VU+ satellite box, only my PC.
I tried it with the WDTV Live I replaced it with and that causes no problems.
There was also an AFT update about a month ago but I can't say if it starting happening after that.
Any help appreciated
Sounds like a windows networking services issue, not sure which ones are required for network discovery but that would be my guess.
I'm going to bed now but just looked at the Windows Event and in the System section there are many Error Logs from 23:18 when I last tried it and failed.
How do I get this info so that I can post it here?
Does this help?
Level Date and Time Source Event ID Task Category
Information 03/05/2015 23:27:15 Service Control Manager 7036 None The Application Experience service entered the running state.
Warning 03/05/2015 23:21:54 Disk 51 None An error was detected on device \Device\Harddisk1\DR1 during a paging operation.
Error 03/05/2015 23:21:54 iaStor 9 None The device, \Device\Ide\iaStor0, did not respond within the timeout period.
Error 03/05/2015 23:21:35 iaStor 9 None The device, \Device\Ide\iaStor0, did not respond within the timeout period.
Error 03/05/2015 23:21:15 iaStor 9 None The device, \Device\Ide\iaStor0, did not respond within the timeout period.
Error 03/05/2015 23:21:14 iaStor 9 None The device, \Device\Ide\iaStor0, did not respond within the timeout period.
Error 03/05/2015 23:21:13 iaStor 9 None The device, \Device\Ide\iaStor0, did not respond within the timeout period.
Information 03/05/2015 23:21:08 Service Control Manager 7036 None The Windows Connect Now - Config Registrar service entered the running state.
Error 03/05/2015 23:20:53 iaStor 9 None The device, \Device\Ide\iaStor0, did not respond within the timeout period.
Error 03/05/2015 23:20:52 iaStor 9 None The device, \Device\Ide\iaStor0, did not respond within the timeout period.
Error 03/05/2015 23:20:51 iaStor 9 None The device, \Device\Ide\iaStor0, did not respond within the timeout period.
Error 03/05/2015 23:20:31 iaStor 9 None The device, \Device\Ide\iaStor0, did not respond within the timeout period.
Error 03/05/2015 23:20:30 iaStor 9 None The device, \Device\Ide\iaStor0, did not respond within the timeout period.
Error 03/05/2015 23:20:29 iaStor 9 None The device, \Device\Ide\iaStor0, did not respond within the timeout period.
Error 03/05/2015 23:20:09 iaStor 9 None The device, \Device\Ide\iaStor0, did not respond within the timeout period.
Error 03/05/2015 23:20:08 iaStor 9 None The device, \Device\Ide\iaStor0, did not respond within the timeout period.
Error 03/05/2015 23:20:07 iaStor 9 None The device, \Device\Ide\iaStor0, did not respond within the timeout period.
Error 03/05/2015 23:19:47 iaStor 9 None The device, \Device\Ide\iaStor0, did not respond within the timeout period.
Error 03/05/2015 23:19:45 iaStor 9 None The device, \Device\Ide\iaStor0, did not respond within the timeout period.
Error 03/05/2015 23:19:44 iaStor 9 None The device, \Device\Ide\iaStor0, did not respond within the timeout period.
Error 03/05/2015 23:19:24 iaStor 9 None The device, \Device\Ide\iaStor0, did not respond within the timeout period.
Error 03/05/2015 23:19:23 iaStor 9 None The device, \Device\Ide\iaStor0, did not respond within the timeout period.
Error 03/05/2015 23:19:22 iaStor 9 None The device, \Device\Ide\iaStor0, did not respond within the timeout period.
Error 03/05/2015 23:19:02 iaStor 9 None The device, \Device\Ide\iaStor0, did not respond within the timeout period.
Error 03/05/2015 23:19:01 iaStor 9 None The device, \Device\Ide\iaStor0, did not respond within the timeout period.
Error 03/05/2015 23:19:00 iaStor 9 None The device, \Device\Ide\iaStor0, did not respond within the timeout period.
Information 03/05/2015 23:19:00 Service Control Manager 7036 None The Adobe Flash Player Update Service service entered the stopped state.
Information 03/05/2015 23:19:00 Service Control Manager 7036 None The Adobe Flash Player Update Service service entered the running state.
Error 03/05/2015 23:18:59 iaStor 9 None The device, \Device\Ide\iaStor0, did not respond within the timeout period.
Error 03/05/2015 23:18:58 iaStor 9 None The device, \Device\Ide\iaStor0, did not respond within the timeout period.
Error 03/05/2015 23:18:57 iaStor 9 None The device, \Device\Ide\iaStor0, did not respond within the timeout period.
Error 03/05/2015 23:18:36 iaStor 9 None The device, \Device\Ide\iaStor0, did not respond within the timeout period.
Error 03/05/2015 23:18:35 iaStor 9 None The device, \Device\Ide\iaStor0, did not respond within the timeout period.
Error 03/05/2015 23:18:34 iaStor 9 None The device, \Device\Ide\iaStor0, did not respond within the timeout period.
Error 03/05/2015 23:18:33 iaStor 9 None The device, \Device\Ide\iaStor0, did not respond within the timeout period.
Error 03/05/2015 23:18:32 iaStor 9 None The device, \Device\Ide\iaStor0, did not respond within the timeout period.
Error 03/05/2015 23:18:31 iaStor 9 None The device, \Device\Ide\iaStor0, did not respond within the timeout period.
Error 03/05/2015 23:18:30 iaStor 9 None The device, \Device\Ide\iaStor0, did not respond within the timeout period.
Error 03/05/2015 23:18:29 iaStor 9 None The device, \Device\Ide\iaStor0, did not respond within the timeout period.
Error 03/05/2015 23:18:28 iaStor 9 None The device, \Device\Ide\iaStor0, did not respond within the timeout period.
Information 03/05/2015 23:18:01 Service Control Manager 7036 None The WinHTTP Web Proxy Auto-Discovery Service service entered the running state.
Error 03/05/2015 23:18:01 iaStor 9 None The device, \Device\Ide\iaStor0, did not respond within the timeout period.
Error 03/05/2015 23:18:00 iaStor 9 None The device, \Device\Ide\iaStor0, did not respond within the timeout period.
Error 03/05/2015 23:17:59 iaStor 9 None The device, \Device\Ide\iaStor0, did not respond within the timeout period.
Error 03/05/2015 23:17:58 iaStor 9 None The device, \Device\Ide\iaStor0, did not respond within the timeout period.
Error 03/05/2015 23:17:57 iaStor 9 None The device, \Device\Ide\iaStor0, did not respond within the timeout period.
Error 03/05/2015 23:17:56 iaStor 9 None The device, \Device\Ide\iaStor0, did not respond within the timeout period.
Error 03/05/2015 23:17:55 iaStor 9 None The device, \Device\Ide\iaStor0, did not respond within the timeout period.
Error 03/05/2015 23:17:54 iaStor 9 None The device, \Device\Ide\iaStor0, did not respond within the timeout period.
Error 03/05/2015 23:17:53 iaStor 9 None The device, \Device\Ide\iaStor0, did not respond within the timeout period.
Information 03/05/2015 23:16:49 Service Control Manager 7036 None The Application Experience service entered the stopped state.
I went up to OCUK this morning and Mr Seabiscuit sold me a Seagate 3TB drive.
I'm just transferring stuff at the moment but there are certain folders that have been giving me problems.
eg
I've had problems accessing my TV folder with the Fire TV and when transferring, the computer hung when copying that directory several times.
