- 20 Apr 2014
- Herts/uk
Do you have this...
<use_all_gpus>1</use_all_gpus>
in your cc_config.xml file (in the ProgramData\Boinc folder) ?
Also, are you running multiple tasks on each card ?
These are set up in Einstein Preference.
i changed the 1 to a 3
<cc_config>
<options>
<use_all_gpus>3</use_all_gpus>
</options>
</cc_config>
working fine now
[url=http://imgur.com/EYLD5oB]
