Seriously who cares how it looks?? I care about does it fit in my case and what fps it has.
lol! but a lot of people do care or there wouldnt be so many cases with side windows
i think they might start to go out of fashion tho!?
im over them anyway
some of the old lian-li cases with no sidewindows still look the best to me, more....grownup
well what do you expect it to look like then, a water filled Durex or something![]()
No, hoping they've moved on from their old reference coolers![]()
If the single GPU uses a 120mm radiator, do that mean the dual will need a 240mm ?
Anyone half serious about water-cooling will be removing the standard block as I doubt that out of the box it will support Crossfire, too much of a faff. Unless, there is a sea change going on and Sapphire et. all want to take on EVGA in this space.
EVGA do an 'ok' job in this area but their supply chain is awful, maybe an opportunity here for an AMD vendor to step-up.
I would imagine that other vendors will provide variations on the theme over time, without the the pump etc. i.e. Powercolor LCS range uses EK blocks.
The standard 390X config will be aimed at the casual gamer who either has a CPU closed loop already or, who is air-cooling at present.
