- 9 Apr 2012
What root mods can I do on 4.4.4 to get better standby battery drain? I'm losing 10%+ overnight but I'd like to lose less.
10%!? On KK my idle drain was around 4% on LP its only about 5-6% (with now cards on)
You must have some wakelocks?
Battery graph and better battery stats.It was on Aeroplane Mode all night.
How do I check wavelocks?
14 April 2015?!?
have you looked at greenify?
I find it's always the iPhone users who are the ones looking for charges at work. So either this says something about iPhones or their usersNow that I've fixed the Google Play Services battery drain, standby loss is almost as good as the iPhone which I didn't think was possible on an Android device.
I have tried several cheap protectors from eBay and they all the same problem: if I put the OPO on a table, the screen becomes really unsensitive, with certain taps not being registered, scrolls being registered as taps, etc.
My OPO was like that without a screen protector on.
I've done the stuff to reduce the Google Play Services battery drain (I'm on KitKat) but I now keep being told that Google Play Services has crashed.
How can I stop this? I am rooted BTW.
