Possible Radeon 390X / 390 and 380X Spec / Benchmark (do not hotlink images!!!!!!)
Status
Not open for further replies.
Umm how can a fan be on the hidden side if there is the PCB? Look at the pcie connectors they are on the lower (hidden) side. It is simply placed like a normal card backside down and we see the side where the fans should be on air cooling.
You are correct, there's just a lot of sarcasm going on.
I think it looks great, I find it hilarious how passionate people can feel about the look of a graphics card. I prefer to look at my monitor when I'm playing a game and not into a case window.
I don't think it looks great but nor does the 295 x 2 and you're right who cares :)
LED's were a thing for me when the matrix GTX 285 came out kinda moved on now :D don't care what colour it is as long as the light can be turned off.
Just seen that it has no DVI ports, about time :)
The only reason cards still had DVI ports was because they were necessary for connecting VGA adaptors (you can't go direct from HDMI/DP to VGA with a passive adapter like you can with DVI-I, it requires an active converter), but since AMD ditched DVI-I ports on the R290 in favour of digital only DVI-D they became superfluous as you can go direct from HDMI/DP to DVI-D.
well ok, but it does look pig ugly, it's too short and fat, it has no sense of style at all.
it's going to be very interesting to see the other side :eek:
Not sure why people are getting their knickers in a twist over 2x 8pin connectors.....my 7970 has them but then again this thread is just......well..........you know....... ;)
Status
