Don
- 20 Oct 2002
- In a house
Into the wind is when the wind is blowing into your face.
Always launch into the wind.
About 9-10 minutes. It peaked at pulling about 180A on full power holding about 46V, but average in flight current was only about 60A, which is still 2500-2800W or so, nearly as much as a kettleElectric? wow, how much flight time?
) and it may help but it didn't seem too bad.
got a new carbon rod for wing, just need to glue another rod on the inside of the tube. Then sort out the Velcro to hold the wing joins and put another elevator control horn on. And sort out the aileron as that wasnt working for some reason on my rate switch
YupAre you still coming out with your model?
Yeah. Luckily I have no kidsLooking goodcan't wait to see the f14
Sounds like you have your hands full at the momentI should have my bix ready in the week.
AWesome looking forward to seeing that fly!It's a little like flying heli's/multi rotors in as much as the controls will be reversed when upside down or front on to the plane.are they hard to fly?
) or get an EPP model which is pretty much indestructable.It's a little like flying heli's/multi rotors in as much as the controls will be reversed when upside down or front on to the plane.
Best thing is probably to find someone close to you to help or to buddy up with (they fly with one controller and pass over control to you and can take back control is things get hairy) or get an EPP model which is pretty much indestructable.
I started on slope soarers (gliders) under my old mans watch but I was lucky in picking it up very quick.
Do you have a copy of Pheonix RC?
