** THE PHANTEKS ATX CASE YOU HAVE ALL REALLY BEEN WAITING FOR - TIME TO EVOLV **
OcUK Staff
26 Nov 2014
Stoke
I'm pleased to introduce the new Phanteks EVOLV ATX Chassis. This case, put simply, is absolutely stunning. It builds on the already excellent Evolv Micro-ATX case with full ATX compatibility, with all the excellent features found on the original Evolv such as the toolless side panels, removable fascia and all round aluminium finish. Added to that with the benefit of more space is more extensive watercooling support, a retractable radiator bracket, an innovative new HDD mounting system and better cable management options to name but a few. Basically, this case should be at the very top of your shopping list if you're planning to upgrade. It is that good.
Stock is going to be landing with us around the 3rd July, I suggest that you make a pre-order now to secure stock as we have obtained the very first stock off the production line, therefore it's extremely limited!
Phanteks Enthoo Evolv ATX Mid Tower Case - Gun Metal @ £139.99 inc VAT
Addressing the online community’s desire for the ATX verison of the Enthoo EVOLV case, Phanteks have released the new Enthoo EVOLV ATX to the EVOLV series. A premium mid tower chassis with an aluminum exterior with minimalistic design based on the original Enthoo EVOLV. The EVOLV ATX features the quick release side panel system, innovative top radiator bracket, and the new HDD mounting system.
Like the EVOLV, the EVOLV ATX retains the full 3mm thick aluminum outer panels with the quick release system. The EVOLV ATX features a 4 color changeable power LED. With the EVOLV series ranging from mini ITX to micro ATX, the EVOLV ATX features a large interior to support full ATX systems. Unleash unlimited possibilities with the Enthoo EVOLV ATX.
Features
- Aluminum body (3mm thick)
- Clean interior - Hidden PSU and HDD’s
- Power LED - Changeable to 4 different colors
- Retractable Radiator Bracket - Convenient Installation
- Toolless Sidepanel with swing door
- Side Window to show off your components
- Quick release panels for easy access
- Equipped with 3 x Phanteks PH-F140SP 140mm Fans, PWM Hub, 35mm Cable Management Space and Phanteks Velcro Ties
- Bottom and Front Dust Filters
- 2 x SSD Brackets Included
- 3 x Modular 3.5" HDD Bracket included
- Watercooling ready with Reservoir/Pump Mounts and space for up to 360mm radiators on Top/Front Panel
Specifications
- Form Factor: Midtower
- Colour: Gun Metal Grey
- Material(s): Aluminum (3mm), Steel chassis
- Motherboard support: E-ATX *(up to 264mm wide), ATX, Micro ATX, Mini ITX
- Front I/O: 2x USB 3.0, Mic, Headphone, Reset
- Side window: Yes
- Expansion slots: 7
- Internal 3.5”: 8x (5x included)
- Internal (dedicated) 2.5”: 3x (2x included)
- Air Cooling Support: Front - 3 x 120mm, 2 x 140mm (2 included) , Top - 3 x 120mm, 2 x 140mm, Rear - 1 x 120mm, 1 x 140mm (1 included)
- Liquid Cooling Support: Front 120mm - Up to 360mm, Top 120mm - Up to 360mm, Rear 120mm - 120mm, Front 140mm - Up to 280mm, Top 140mm - Up to 280mm, Rear 140mm - 140mm
- PH-F140SP Included Fan Spec: Speed (rpm) - 1200 ± 250 rpm,, Max Airflow: 82.1 CFM, Static Pressure - 1.33mm H2O, Acoustical Noise - 19dB
- Graphic card clearance: 420 mm (16.54 in) No HDD brackets, 300 mm (11.8 in) HDD brackets installed
- CPU cooler clearance: 194 mm (7.6 in)
- Cable management: 35 mm (1.38 in)
- Memory clearance (motherboard - fan): 120mm: 68 mm (2.68 in) , 140mm: 48 mm (1.89 in)
- Model: PH-ES515E
- Net Weight: 10.2 kg (22.0 lbs)
- Gross Weight: 11.9 kg (24.3 lbs)
- Package Dimension: 310 mm x 570 mm x 564 mm (WxHxD)
- Warranty: 5 Years
Only £139.99 inc VAT.
ORDER NOW
Phanteks Enthoo Evolv ATX Mid Tower Case - Black @ £139.99 inc VAT
Features
- Side Window to show off your componenets
Specifications
- Dimension: 235 mm x 495 mm x 510 mm (W x H x D) 9.25 in x 19.5 in x 20.1 in
- Colour: Satin Black
- Side window: Yes
- Model: PH-ES515E
- Warranty: 5 Years
ORDER NOW
Very nice. Is there a white one in the pipeline do you know, or is that going to be some time off yet?
There's a bit more info [removed link, images below]
Legend that link does a auto download might be innocent but I dont trust anyone on the net so having to do a full virus and malware scan now thanks!!!
Sorry didn't know that wasn't allowed. It's a harmless PDF file (asks me if I want to download, no stealth auto download my end). I've removed link and put images from it below anyway...
Ooooh... the gun metal one looks the biz, I think I like this more than the Luxe. Would have liked to see white also though, will it be so?
This could be the case that replaces my CM690 II.
Not that I'm buying, I'd still prefer the Enthoo Luxe, but why no USB 3.1 headers?
This or the new fractal define s?
Well the Evolv will have max 360 front and top where as the Define S you'll be able to have a 420 in the top however (A thickness limitation of 55mm for both radiator + fan applies on 420, 280 and 140 mm radiators).
Not a huge difference cooling wise, I guess it'll be down to which layout suits you best.
Gorgeous case, but £140? Seems a little steep considering the great value of the mATX and mITX versions. Shame.
Well they say less is more and this case is certainly that, compared to it's stablemate, the Enthoo Luxe.
Less space, less features, but higher price.
It'll sell loads!
Been waiting on this to see if it was worth getting over the Enthoo Luxe but with on sale at 105 this week its not worth for less features :(
