- 9 Apr 2012
What's the best app to get SMSs on my Mac?
It's not an app, do get it like that the phone software has to support it. Most android phones now have some sort of battery % available in the status bar like that, if yours doesn't then you'd have to look at custom software (ROM's) and rooting the phone.
What phone do you have?
From settings, go in the battery options and in there is an option to turn on battery %.
It puts the % next to the battery symbol, guess the one I like must from a different manufacturer.
There are plenty of others available, but you'll need to be rooted for them.
You can change this with xposed modules. But the S6 is unable to use xposed on lollipop until they fix it which doesn't seem to be anytime soon.
There is a fix available but it only works on Deodexed ROMS![]()
The one in the image looks like Sony.
As other's have said, you can root the device and either used Xposed or Custom Rom's to acheive this, but make sure you're comfortable with rooting and what it means before going down that route.
That looks cool. Do you have to use it as a text app on your phone? Does it show other notifications (Gmail etc) on your PC?Pushbullet can send SMS and reply, but there's not really any way to see previous convo history.
I used this app before moving over to Pushbullet and works well: http://mightytext.net/#
It is however a browser extension instead of a native OS X app.
Is this battery display an app I can download?
