8.0 or 8.1?
8.1 here on 2 laptops + 1 pc. on the pc it asked for a email address but both laptops didn't
but if i right click on the get windows 10 then click check upgrade status, i see it's done.
8.0 or 8.1?
I had to forcefully trigger it on mine.
1) Open the Control Panel, choose Administrative Tools, and then fire up the Task Scheduler.
2) Expand Task Scheduler Library, then Microsoft, then Windows, and finally scroll down to expand Setup
3) Click the folder GWXTriggers and on the far right hit Run.
Confused :
Windows 10 will be free (for the first year) so everyone will upgrade for free
but then , how much will it cost ? they are clever not mentioning any prices !!
also just had the pop up to reserve my free upgrade
anyone know if it still comes or keeps windows media centre? I need that to watch tv on
. Not sure what I will do on htpc. I think it will be worth upgrading to keep apps up to date and hopefully new apps. But I'll have ti replace media centre with something else.Could that possibly be because you are using the same product key on 3 machines?
Going to have to be patient I think...mine isn't showing up at the moment and doing the above doesn't work. Damn
nope. each have their own key
Confused :
Just had the Win10 box appear on my lads Win7 machine, have "Reserved" his Win10 copy for when it gets released.
Will stick to my Win8.1 for a while to see what 10 is about.
Is there a catch somewhere? Doesn't seem very MS to give away an OS for free.
I'll guest its using your Ms account somehow.
No catch, it's not where ma make there money from, it's a declining revenue source in the modern world. They make there money from all the subscriptions and stores. Skype, office, music pass, music, videos, app store etc.
Basically following what apple have done, get as many people on their os as possible and then sell the addons.
try doing a Windows update check.
I'm guessing going from 7 to 10 will require a fresh install? What if I want to do a fresh install in the future, how does that work? Will I be able to download an ISO from MS and use that to any future fresh installs for example? And if so where do I get the product key from?
Apologies for asking these as if this is the Microsoft support forum. I've just never done an upgrade install before, always a fresh one, so I'm not sure of the process.
