Why are you using AFR? Can't you just use the default crossfire profile? The only flickering I get on my 7990 is in the inventory screen.
Lucky you! All shadows flicker during gameplay lighting effects within buildings, etc.
Had another go of Black Mesa earlier on, if anyone can remember, i had a problem where on the Dam level (where the first chopper appears), it kept hanging, and i had to hard restart (up to there, was absolutely perfect), anyway, soon as i started, wasn't on 20secs, just ran and opened a door, bombed, tried again, ran to the same door, opened it, was fine, so played for about 10/15 minutes or so, got to that minefield you have to get through, to get down the storm drain, bombed, so restarted, this time leaving Afterburner off, and i played for ages with no bombing, was fine.
Just played there again, for nearly 2hrs (again with Afterburner off), and it was perfectly fine again, so baffled, as i can't see it being an Afterburner problem, as it only started bombing on that Dam level, and it was perfectly fine up to there, with Afterburner running.
BUT the flickering was awful, just recovered from my 3rd fit of the evening
When crossfire works the 7990 is still such a beast, love it
Nah, the RTSS has to be running as well.
RTSS only needs to be running if you using OSD otherwise it can be disabled.
hello,
i have annoying stuttering on 15.5 and r9 290 tri-x (eg. when he runs or rides the horse)
is there some setting which can cause this or is game related?
thanks
Can it ? i right-click > close, but it just keeps coming back.
If it keeps coming back you have monitoring enabled. Even if osd isn't enabled you still running it. Un-tick all settings and then it will close.
Unticked everything, but still comes back
Amen Dave. I ended up buying another one just for a piece of history to show the grandchildren.
It's amazing how smoothly it handles GTA V at 4K at near maximum settings. (with AA disabled) Undervolted to 1.1v and temp sits at the low 80's in complete silence.
