- 19 Oct 2002
- Shakespeare’s County
Wow impressive! Looks nearly as naff as the new Civic though!
this what my exact first thoughtLooks nearly as naff as the new Civic though!
I've been getting some false messages on the Dashboard about the Bulbs, sometimes rear left, sometimes front right parking bulb and when checking they are working fine?
Any idea what could be the issue?
Looking forward to the power the facelift SLK is going to have with the new AMG engine - 500bhp+ rumoured![]()
You could always ask them? A lot of these premium manufacturers do fixed price servicing now, and it isn't actually that expensive.
[TW]Fox;28145416 said:Hahaha 50 quid for a loan car!?
Service reception protocol for service on vehicle - The service scope is only completely performed when all acceptance items and the maintenance items listed in the service sheet have been fully processed (To be performed by the service advisor) AP00.20-P-0009Z
Carry out brake test on test stand - Enter results in the table AP42.00-P-4290BA
Conduct additional operation “Top up with AdBlue”
Yes
No
Conduct additional operation “Replace dust filter” (MODEL 205) AP00.20-P-0047U
Yes
No
Conduct additional operation "Factory inspection work on driving aids" AP00.20-P-0047U
Yes
No
Fill up/replace perfume atomizers flacon
Yes
No
Interior
After confirming service in ASSYST/ASSYST PLUS make sure instrument cluster message changes to next service 15,500 miles (for AMG variants please check FIS guide within ESS) - For vehicles on Fixed Interval Servicing (FIS) Only SI18.00-P-0011A
Check warning and function indicator lamps in instrument cluster AP54.30-P-5449U
Check horn for proper operation
Read out map data status from navigation system, check update - Card data status: AP82.85-P-8249U
Read out maintenance data from instrument cluster, note and reset service indicator. AP00.20-P-0049U
Wheels
Check tyres for damage and crack formation, measure tread depth and enter in end table AP40.10-P-4051EW
Check condition and tread depth of tyres AP40.10-P-4052B
Assess condition of brake linings AP42.10-P-4248U
Assess condition of brake disks AP42.10-P-4249U
Underside
Check condition of vehicle underside AP60.00-P-6049U
Exterior
Check condition of vehicle exterior AP60.00-P-6048U
Check condition of windshield AP67.10-P-6750A
Check condition of wiper blades AP82.30-P-8253G
Engine
Air/water duct: Check water drain for passage - Record findings below AP82.35-P-8232A
Air/water duct condition: Blocked (If blocked clean soiled water drain subject to a separate repair invoice)
Air/water duct condition: Clear
Brake system - Inspect fluid level AP42.10-P-4210CW
Check coolant level AP20.30-P-2049U.
[TW]Fox;28146138 said:I've paid that to HIRE a Mercedes from a commercial rental firm, that's a complete ripoff for a courtesy vehicle at an already not cheap main dealer.
£50 collect and deliver?! 60 minutes work tops for a minimum wage driver!
Wayne Gates seemed good when I used them for my SLK brakes earlier in the year. Access to their yard can be pretty tight though, especially if you're used to the open expanses of main dealers!!
