Well, actually while my post you quoted doesn't change that "fact" it does prove it to be wrong and that they did not come first![]()
If you are incapable of following the context that the TitanX and 980Ti came after the 980/970 then yeah.
I was under the impression they were launching Fiji with 4GB first, with 8GB some time later... If that is incorrect, well, consider me corrected!
Not when I'm running a 1.5GB GTX580, either single card or SLI (depending on the game/temps).
Also it's the same story every time, "oh the next architecture will blow everything away, 40/50/60% faster!!!11!"
When it actually arrives, it's the usual increase of 15-30%.
If I was to wait for the next set of cards, it would be for the 2nd gen when the full fat chips are released (at least for the nvidia cards), so that's 18 months at least.
The 980 4GB and the 970 3.5GB came first, talk about short memory.
Well for calling it a fail lets just wait for benchmarks first.
BTW Its really funny that for many people the thing nv has an uper hand is above all. When amd has more vram no one cares, when nv has more vram its above all.
Same for power consumption....
8 months ago....
At least, once the 4GB version is released we'll get an idea of performance and whether it's worth waiting for the Fury 8GB.
8-9 months ago....
That's not the usual increase, or at least it's not meant to be.
The 5870 basically doubled the performance of the 4870.
The 7970 basically doubled the performance of the 6970 too.
Unfortunately the 6970 was a massive disappointment in performance over a 5870.
so the 7970's scaling wasn't linear like 4870-5870.
The 6970 was on the same fabrication as the 5870. That's why it was a poor performance gain.
What we're witnessing at the moment is unprecedented, three full generations (From both vendors) on the same fabrication is unheard of.
The 6970 was on the same fabrication as the 5870. That's why we've got slow progress.
I know 32nm half node was cancelled, just like half node.20nm.
But my linear point still stands. They had to.chop a lot out of the 6970 especially shaders to get it to work on 40nm. Humbug feels it's fine to use 28nm so it must be all ok.
