- 21 May 2015
Just got the email, order shipped and will be with me tomorrow!
Good luck everyone else
Taken the plunge couldn't decide between the Ti and a Titan X but for 1440p I think it'll be enough, can always add another at a later date.
don't worry it will get update to correct amount when order gone to warehouse in the queue.
Wow hope my setup doesn't require that kind of fan RPM. Two ACX SC on a Maximus Hero VII in a H440 case. Hopefully if I take the front panel off I can get away with a 50-60% fan profile.
Looks like everyone's getting their cards
Me included
Put me on the roll of honor please Kaap.
what is your card ?
taken from overclock forums
"Hi,
at those who have the EVGA GTX 980 TI SC ACX 2.0: Can you tell me please which temperature you reach at 100% fan and 100% GPU load? Is the card then loud?"
"I have two of those. They are pretty loud actually. 100% is obnoxiously loud and you would never want that for extended periods. Over 70% starts to get really noticeable. With 1 card and fans at 70% you are looking at temps in the 69- 72 range at max load. Honestly Id personally go for a different card if I could do it again. Maybe the Windforce or wait for others."
I hope you have a better experience with the ACX 2.0.
Interested to see other people's opinions on the fan that comes with the Hybrid heatsink. Thinking I might replace it with a Corsair SP120 like I did for the H100i
Not good... I'll report tomorrow as well. Honestly, silence is an absolute must for me.
Definitely not ideal in sli, particularly on a mobo with a one slot gap. I found the wf cooler started to get noticeable once the fan hit 65%. Custom fan profile of a 1-1 setting, highest temp I ever got on the top card was 85c. Bottom one never once above 65c.
1-1 fan profile would be way too crazy for me, especially with temps still going to 75+.
Will find out tomorrow.
"Hi,
Ouch, 85 on the top card is 1 degree hotter than my Reference cooler. I'd say if you had a double spaced gap between the cards the top one's temps would be much lower.
Has it affected the mobo and CPU temps as well?
If the 980ti is anything like the TX, which it is, you aren't going to get silence under load on air. Some cards will be less audible than others but all models will be audible unless your room is 16c.
Cards are coming tomorrow will know on Wednesday when I have a chance to put them in.
