The vast majority of users aren't doing that so it's a non issue.
/shrug, he asked a question so I answered it.
You can make the same argument for the 3.5gb GTX 970 and look what happened there !!!
So guys, 'How much VRAM do you really need at 1080p, 1440p and 4K?'
http://www.tweaktown.com/tweakipedia/89/much-vram-need-1080p-1440p-4k/index.html
Don't know what you guys with experience say.
Just out of interest, has anybody actually experienced any issue with the 970's memory yet, aside from running "that" synthetic memory benchmark or issues that are in line with 980 performance?
I seem to remember loads of raging at the time but nobody could actually find a real issue, including all the tech sites.
Because when you add more GPU's the FPS goes up, and memory then becomes a limiting factor.
IIRC Kaap or somebody said multi 290X 8GB was better at 4K than multi GTX980 4GB?
Thing is if you only need 4Gb as thats what the FurryX or whtever its called will have (Not sure if there are 8Gbs coming later on?) at 4k why put 8Gb on the 390X? why not just put 4Gb and save themselves the extra cost if they really believe only 4Gb is needed
The amount of hitching I managed to find with high and above texture presets with the 980GTX at 1440p, I'd rather have more than less...
Besides, if it's such a non issue why equip the 390x with 8GB at all. [EDIT] As the gent above me has just said lol.
Maybe GDDR5 and HBM don't equate to the same thing, i.e the way a GDRR5 works might not be not quite the same as HBM??
Can you explain this? as far as I know 1MB is 1MB in size regardless of whether it's FPM, EDO, SDR, DDR or Rambus...
Faster 4GB is still 4GB.
