390/x under 400 euros confirmed?
Any idea what time the Fury reveal will be?
I've never used HBM or even seen it action. I'm holding judgement until we actually see the cards. HBM and GDDR5 are not the same things, they may not work in the same way. I have will wait until we get more info before deciding if it's a good or bad card. I had fun with my 4GB GDDR5 980, will probably enjoy using AMD's 4GB HBM Fury X to.
1 day to go until we find out. Let's try and hold it together guys.
*Maybe* they will have a new texture compression method but you will likely get 10% saving at most,
if it was possbile to squash down textures 50%-100% without impacting image quality it would have been done a long time ago when memory was at a premium.
A bit off topic (no less than half the BS fanboyism bickering in this thread) but damn, all those "Keep calm and.." are so stupid. They make no sense and just make me cringe.
Tomorrow?
If you where filling the glass at the same rate as you where drinking, you would have infinite beer :|
Thats really not true at all, take the 970 and its 3.5GB "full speed" issue.
If you where using <=3.5GB of vram the gameplay was buttery smooth, then when you when above that mark things slowed down. That wasn't to do with not having enough vram that was indeed due to how fast you can fill / empty it.
Now if you can fill / empty the buffer quick enough when you need to swap in / out the data needed after exceeding the maximum vram you have you could still have a high FPS
Is it true?
Can it be tomorrow that all these weeks and pointless debates of Gods finally come to a decision? That it be unveiled?
Are we humans worthy?
Backtrack! Backtrack!
Silent Scone logic.
TLDR.
Nvidia does rebrand =awesome even if rebrand is fighting for three years against multiple new cores including those one process node ahead.
AMD does rebrand = terribad if fighting against one single new core on the same process node.
So basically Boomstick was right.
This time tomorrow, Boomstick will make the 490X thread, and a whole new can of worms will be opened - 490X limited to 8GB VRAM - not enough for 12k resolution!
The hype is real.
I'm hoping Advanced Malfunctioning Devices can blow the nVidiots away (including myself). Another noticeable performance leap above the TX/980ti will be awesome.
Am expecting not just good GPUs but I have feelings amd is up to something else..
Amd gaming Facebook hinting at future of online gaming for example..
Something unexpected is about to happen..
