- 19 Jun 2012
m.uk.ign.com/articles/2015/05/08/no-ironsights-squads-or-classes-in-star-wars-battlefront
Good move in my eye loads of people seem to be complaining !
I'm on board with no ironsights, but no classes is going to be tricky.
Getting decent balancing in a game when anyone can use anything is going to be tough and will likely result in a bit of a mess with weapons being either OP or UP not to mention the potential for a P2W element similar to how Planetside 2 works.
That said, if they can make it work, it certainly gives the player a lot of freedom and it will also add a tactical element to how you approach the enemy. I would like to see several loadout slots available and I think it would be good if there was some mechanic by where you can quickly switch between them based on the needs of your team in a firefight. In Tribes you can k out and respawn as a new class (you respawn back at base - which is sometimes good depending on the situation), or you can call in an inventory station and change class during battle anywhere on the map so long as you have enough credits for one.
I think this would add a fluidity to the game and create some exciting play.
