- 5 Aug 2003
- Essex
What would you do in this situation, the survey has reported some damp issues on a house I'm buying and a separate damp report has reported failure of the DPC and quoted £1600 to rectify. There's another problem with the chimney which needs repointing and new lead flashing. So in total I'm looking at about £2500 to get the repairs done.
At the moment I'm insisting that the current owners get the problem fixed as I'm concerned that when the damp proofing work goes ahead and they strip the walls back and look at the joists that they are going to find rot or other problems.
The current owners are saying they have no money left but I don't see why I should be footing the bill and I'd be much happier if the work was done before exchange in case there is any rot or damage to the joists.
I'm thinking as a compromise I could sort the chimney once moved in but they need to get the damp sorted. Would you agree or should they be paying the lot? The sale price is £700k so really £2500 shouldn't even be worth arguing about.
