It does void the warranty, but only if you completely brick the card so it doesn't work at all and you can't flash it back. Although there are ways of flashing the bios on a bricked card still.
Yeah, I wasn't talking about that card...We are now in stock and at NVIDIA's set MSRP for UK.
So we are at RRP not above it on the OcUK card that you are talking about.![]()
Do you guys use custom fan profile? I have a case with a good airflow (FT02) and I get 62/60'C idle in SLI with a standard profile.
Is your monitor at 144Hz by any chance? Anything over 120Hz and the NVIDIA cards don't go into powersaving mode so they stay at full baseclocks.
Im using the default fan profile in my H440.
Can I ask what boost clock is estimated in GPU Z for that OC? A Gripen rig wouldn't be complete without three green beasts![]()
Not badRunning a custom bios? I think my reference MSI boosts to 1160 so I'm thinking about flashing.
Just to show you guys that the Hydro copper comes with white leds to match EVGA's new sli bridges.
Well, mine was working strong last night, despite GTA V being a bit 'picky' on staying at 60fps with everything maxed... Still have to knock back grass density to very high from ultra.
Anyway, tit for tat haha.
So, I did stick an OC on the card, regardless of me saying I wouldn't...
I didn't up the voltage and I set the temp threshold to 85C.
With the default fan profile and volts, I managed to get 160mhz on the core and 200mhz on the memory.
Gave me a nice little clock, boost pushes up the core to about 1450mhz now.
As for temps, stays below 80C, mostly around the 75C/78C bracket. Fans never go above 45% and it's barely audible from my seat. In fact, I'm going to go as far as saying, it's the same as my old 780 Windforce 3x, if not, quieter...
In terms of performance. Witcher 3, my god, so, I had to crank a bunch of settings down on my 780 to get 60fps out and about, but mostly, it would sit around 45fps and down to 35fps in towns.
Now, it's a SOLID 60fps with everything max (aside from hairworks, sod that). But it's not just the frames, the game is DAMN fluid, smooth and just feels much better.
So, over all, very happy... And yes, I have decided. I'm going to watercool.
That's nice! My superclocked evga reference card is arriving on the 29th. Since it has a stated core of 1109 and boost of 1190 (off the top of my head) what actual boost should I be seeing?.
I'm coming from dual 7970s
